monobass
G2 patch files: 12
davep
Joined: Jul 05, 2004 Posts: 467 Location: Oakland, CA
Audio files: 10
G2 patch files: 73
Posted: Sat Nov 12, 2005 4:45 pm Post subject:
I don't know if i can tell you anything that will get these specific shapes, but I have some general guidelines.
You can do a lot of subtle shaping tricks with just a shaper and crossfader. For example:
Say you want to flatten or round off the top of a saw wave but not the bottom (lots of analog synths have a saw wave with this kind of asymetrical shape). Connect the saw to one input of a crossfader. Also connect it to a shaper module set to INVx3 and connect the shaper output to the second crossfader input. Now here's the trick - also connect the saw to the CONTROL input of the crossfader and set both crossfader controls to 12 o'clock. Now, when the saw goes positive, the crossfader output passes the shaped saw, and when the wave goes negative, it passes the unprocessed saw. So the final wave is only 'shaped' on the top half.
You can use this idea for lots of variations to make waveforms that are shaped differently on the top & bottom. Try using two different shapers on the two inputs. Try overdrive modules or wavewrappers. Try a triangle wave instead of a saw. Try using a saw wave on one input and a sync'd pulse wave on the second input. Etc.
Another way to get asymetrical shaping is to pass the wave through a level shifter to make it positive only, then through a shaper, and then another level shifter to make it bipolar again.
Another way to shape raw waveforms is by using a filter that tracks the waveform frequency. Try using a highpass filter set to a relatively low fc with a good bit of resonance. Normally, we think of HPFs as something you use to make a signal sound thin, but when you set it to a low fc and crank the resonance, it will emphasize the fundamental or one of the low harmonics, which can make the waveform sound more big & bassy.
Enjoy! _________________ Dave Peck |
monobass
G2 patch files: 12
monobass
G2 patch files: 12
ian-s
Audio files: 42
G2 patch files: 626
Posted: Sat Nov 12, 2005 8:06 pm Post subject:
That’s looking good, the funny spike I think is a Sinc pulse and is part of Clavia’s anti-aliasing, they pop up sometimes when doing wave shaping.
I had a think about this question while waiting in the supermarket car park. Here is the result. Using a compare to get a rectangle from the sawtooth and then using the sawtooth to AM the square or a saturated sawtooth.
What soft scope are you using BTW?
2.63 KB |
| Viewed: |
40960 Time(s) |
 Download (listen) |
| Filename: |
WaldPulse.pch2 |
1.4 KB |
| Downloaded: |
2275 Time(s) |
monobass
G2 patch files: 12
Posted: Sat Nov 12, 2005 8:26 pm Post subject:
Hey G2Ian,
Ah nice technique... and I'm stunned as to how close the pulse wave sounds to the real thing in a side by side comparison!.. and the saw will only take a little tweaking to get it spot on I think.
Great stuff (hope you didn't forget any shopping due to contemplating this )
I'm using a softscope in OSX called Wavewindow
http://www.macmusic.org/softs/view.php/lang/EN/id/3262/ |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Sat Nov 12, 2005 10:10 pm Post subject:
| monobass wrote: | (hope you didn't forget any shopping due to contemplating this)
Elise (3) fell asleep on the way so I got to sit in the car with her while her mum and three brothers did the shopping
| monobass wrote: | I'm using a softscope in OSX called Wavewindow
Mac, pitty, it looks very nice. |
davep
Audio files: 10
G2 patch files: 73
dasz
Joined: Oct 16, 2004 Posts: 1644 Location: victoria, canada
Audio files: 29
G2 patch files: 56
Posted: Sun Nov 13, 2005 11:37 am Post subject:
Hey Dave,
Your discussion of Shaping tricks made me try out something in a patch which I was going to post (a digiridoo-ish thing), but I have once again screwed up and you can't open it in the editor ...
But time will heal this I hope ... unless the file format changes again ...
/Dasz |
dasz
Audio files: 29
G2 patch files: 56
davep
Audio files: 10
G2 patch files: 73
dasz
Audio files: 29
G2 patch files: 56
Posted: Sun Nov 13, 2005 5:51 pm Post subject:
Dave,
Thanks for the kind words ...
| Quote: | | BTW, how can you screw up a patch so that it won't open in the Editor?? That sounds really annoying and I'd like to know how to avoid that. |
Uhm, the patches do not open in v1.32 ... but they do open on one of my G2's ...
I like the modded patch ... I should do more variations ...
/Dasz Last edited by dasz on Mon Nov 14, 2005 1:10 am; edited 1 time in total |
Joined: Apr 03, 2004 Posts: 24555 Location: The Netherlands, Enschede
Audio files: 303
Posted: Sun Nov 13, 2005 6:06 pm Post subject:
| davep wrote: | | That sounds really annoying and I'd like to know how to avoid that. |
Avoid beta testing then :-) _________________ Jan
and70it
Posted: Mon Nov 14, 2005 12:42 am Post subject:
wave window |
| can wave window work in OS X 10.3 as standalone? |
monobass
G2 patch files: 12
Posted: Mon Nov 14, 2005 5:14 am Post subject:
Re: wave window |
| and70it wrote: | | can wave window work in OS X 10.3 as standalone? |
Yep, that's how I use it. It might be too simple for some peoples tastes, but great for just scoping waves, check out the demo. |
G2DREAM
Joined: Apr 27, 2005 Posts: 171 Location: Athens,Greece
Posted: Tue Nov 15, 2005 4:46 am Post subject:
Is there any so simple and good looking software for windows?
_______________
cyber-evolution |
Audio files: 303
Posted: Tue Nov 15, 2005 8:37 am Post subject:
| G2DREAM wrote: | | Is there any so simple and good looking software for windows? |
Maybe http://www.sonicspot.com/wavetools/wavetools.html ?
It says it needs windows 3.1, but once I had it running under XP, although that was before installing SP2 I think. _________________ Jan
G2DREAM
Posted: Tue Nov 15, 2005 5:02 pm Post subject:
yeah, doesn't work on me but thanks anyway for the info man!
______________
cyber-evolution |
cebec
G2 patch files: 31
ian-s
Audio files: 42
G2 patch files: 626
Posted: Tue Nov 15, 2005 8:54 pm Post subject:
| I use the first one (VA.EXE) but not the latest version which looks better but mysteriously won't run on my XP machine. |
cebec
G2 patch files: 31
Posted: Tue Nov 15, 2005 9:42 pm Post subject:
yeah, VA's latest version gives me all kinds of trouble, lately... maybe due to XP updates? i'm not sure... it worked fine once upon a time...
G2DREAM
Posted: Wed Nov 16, 2005 2:04 am Post subject:
Ok guys i will chek them out,thank you!
_____________
cyber-evolution |
BobTheDog
Posted: Thu Nov 17, 2005 4:37 am Post subject:
Does anyone know of one that uses ASIO?
Andy |
foxystoat
Joined: Nov 18, 2005 Posts: 1 Location: Midway City, CA
Posted: Fri Nov 18, 2005 5:05 pm Post subject:
| BobTheDog wrote: | Does anyone know of one that uses ASIO?
Andy |
This one isn't stand-alone, but it will run in ASIO if your host is set up for it:
s(M)exoscope
Regards,
Benjamin W. |
monobass
G2 patch files: 12
