triggerin the note seq - arpegiator style.
Page 1 of 1 [4 Posts]
shavers
PostPosted: Mon Dec 26, 2005 4:02 pm    Post subject: triggerin the note seq - arpegiator style. Reply with quote  Mark this post and the followings unread
Hi list.
Just now I was trying to trigger/toggle the note seq so that with each key down on my controller, the sequence starts - note-off - it stops.
Basically like triggering an arpeggio but using the note seq.. but I can't work it out. I assumed that I'd be able to switch the clock gen on/off with gate messages from the keyboard module.. but no.
Cheers.
S
G2 patch files: 626
PostPosted: Mon Dec 26, 2005 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
It works in mono as shown here. If you dont want the sequence reset on each new key press, disconnect the gate->rst cord.
The two gates stop both the clock in and the gate out so you dont get held notes if your key up timing is not exact.
keyedseq.pch2
start/stop seq with gate
 Filename:  keyedseq.pch2
 Filesize:  2.04 KB
 Downloaded:  1673 Time(s)
We can dance if we want to, we’ve got all your life and mine.
Tim Kleinert
G2 patch files: 236
PostPosted: Mon Dec 26, 2005 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
et voilà.
triggergatingseq.pch2
 Filename:  triggergatingseq.pch2
 Filesize:  1.16 KB
 Downloaded:  1654 Time(s)
shavers
PostPosted: Mon Dec 26, 2005 7:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool. Thanks guys!
Example worked straight-off.
Peace. S Very Happy
