Spectralis- Modelling the Filterbank?
Page 1 of 1 [5 Posts]
TheRain
G2 patch files: 9
PostPosted: Sun Jan 01, 2006 10:06 pm    Post subject: Spectralis- Modelling the Filterbank? Reply with quote  Mark this post and the followings unread
Hi, I am wondering if you guys think it would be possible to model the Filterbank in the new Radikal Technologies Spectralis. Also, if there are any discussions or existing patches that might help me to construct something like it that would be cool. Here is a link to radikal's explaination of the filterbank http://www.spectralis.de/english/Guided_TourE/FilterbankE/filterbanke.html
It's like 10 fixed filters with no cutof control, but each spans a certain frequency range and is fixed at allowing that bandwidth through... then there is amplitude control for each filter so you can allow a very specific band of frequencies to pass... it sounds very cool, here is a quick audio demo, one not processed and one processed.
http://www.collinmeyermusic.com/unprocessed.mp3
http://www.collinmeyermusic.com/processed.mp3
TheRain
G2 patch files: 9
PostPosted: Tue Jan 03, 2006 8:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've realized after scouring this forum a little that there is a LOT of material on filters written or linked to here. So I'm trying to understand and figure out if this is possible, but it's a lot to take in (not that I won't have to learn it eventually anyhow being an engineering student).
G2 patch files: 626
PostPosted: Wed Jan 04, 2006 2:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is one based on Rob's description of how to do it.
The 8 controls on the right set levels, if you set alternate bands to negative gain, the results are interesting.
Lots to experiment with, maybe modulate the filter frequencies or try different slopes etc.
formantFilter.pch2
10 band stereo FFB
 Filename:  formantFilter.pch2
 Filesize:  3.82 KB
 Downloaded:  1936 Time(s)
TheRain
G2 patch files: 9
PostPosted: Wed Jan 04, 2006 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is so totally great... I've got a very cool sequence running through it as I type Smile I'm trying to figure how to impliment resonance.
TheRain
G2 patch files: 9
PostPosted: Thu Jan 05, 2006 9:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here it is with resonance and per filter pan control. The resonance control is on page E3... be warned to use responsible resonance levels as this will begin to self oscillate and hurt your ears. I have attempted to give the res factor a reasonable limit but still allow people to use their own discration.
Thanks a bunch to Ian for the original, which I was quite impressed how he busted it out. I don't really understand it full actually, but was able to get it enough to impliment these few extra functions.
formantfilterpan.pch2
Ian's Formant Filter with added resonance and pan settings.
 Filename:  formantfilterpan.pch2
 Filesize:  4.57 KB
 Downloaded:  1499 Time(s)
