dm
Posted: Sun Jan 15, 2006 12:41 pm Post subject:
Syncing LFOs |
Hi.
First post, I just got my G2 a few days ago and have had a blast programming patches for it. I've run into one slight problem. In a particular patch I have three LFOs of different waveforms. I can't seem to figure out how to get all three synced to the same rate, using the sync output and reset input I''ve only had messy results.
Ideally I'd like to have all three LFO rates controlled by a single knob on the G2, I initialy I figured I could do this using a morph group, but again the results are not workign correctly.
Do any of you seasoned Nord modular users have any tricks to do this?
thanks
-don |
Axiom
G2 patch files: 28
Posted: Sun Jan 15, 2006 12:56 pm Post subject:
can you post the patch?
Luca _________________
dm
Joined: Apr 03, 2004 Posts: 24673 Location: The Netherlands, Enschede
Posted: Sun Jan 15, 2006 2:05 pm Post subject:
Welcome don to electro-music.com
It all depends on what you want to do exactly, so it's best indeed to post the patch here.
Some genral remarks then :
You could indeed use the morphs to tune several LFO's with a single knob, but its easier usually to use a constant module that you run to the frequency control inputs of the LFO's. Alternatively you could use LFO's synced to the master clock, only LFO B and the shape LFO can do that but since you tried syncs you'll probably be using such an LFO already.
You could try to sync the LFO's with a reset pulse so that they only get syncedwhen the patch is loaded (or changed), A reset pulse can be just a constant module set to some positive value. This way they can run at more complicated frequecy ratios without doing strange. _________________ Jan
Oops, posted too late :-) _________________ Jan
dm
Posted: Sun Jan 15, 2006 2:07 pm Post subject:
| Blue Hell wrote: |
You could indeed use the morphs to tune several LFO's with a single knob, but its easier usually to use a constant module that you run to the frequency control inputs of the LFO's. Alternatively you could use LFO's synced to the master clock, only LFO B and the shape LFO can do that but since you tried syncs you'll probably be using such an LFO already. |
It seems that the LFO-B module does not have a random waveform, which is critical in this application. Maybe the morph is the way to persue this, I'll hit the manual again  |
dm
Posted: Sun Jan 15, 2006 2:26 pm Post subject:
| Works perfectly! thanks, I knew I was missing something elementary, I'm going to give myself a pass though, being I've only had it for four days!!! |
Posted: Sun Jan 15, 2006 2:39 pm Post subject:
| dm wrote: | | I've only had it for four days!!! |
Not doing bad then, have fun with it :-) _________________ Jan
