sebber
G2 patch files: 33
Fozzie
Joined: Jun 04, 2004 Posts: 875 Location: Near Wageningen, the Netherlands
G2 patch files: 49
Posted: Thu Apr 06, 2006 4:51 am Post subject:
Hey Sebber, I think it's due to the very short notes you are sending. Help says this about the note-send module's trigger input:
| Quote: | | A signal which goes from 0 units or below to anything above 0 units on the yellow Gate input will force the module to send out the current Velocity and Note values on the selected MIDI channel. When the Gate signal goes back to 0 units or below, the module sends a MIDI Note Off message on the selected MIDI channel. |
You are sending a note on signal only for the duration of the clock pulse, followed very soon by a note-off. If you use the trigger-row at the bottom of the sequencer module in gate mode (or with a pulse delay set to lengten the pulse to the desired length), and use the output from that row to drive the trig input on the note-send, I think it should work fine.
My untried & semi-educated guess.... |
sebber
G2 patch files: 33
Posted: Thu Apr 06, 2006 5:14 am Post subject:
Thanks, but that's not it. I forgot to mention that I tried that, too. _________________ Fish don't swim. They dive. |
Joined: Jan 31, 2003 Posts: 18306 Location: Durham, NC
Audio files: 235
Fozzie
G2 patch files: 49
Posted: Thu Apr 06, 2006 10:10 am Post subject:
| mosc wrote: | | To fix it, take the Gate/Trigger out from the sequencer to clock the MIDI out module. This solves the problem for me. |
Yeah, that's what I tried to explain. Gate mode should make the notes sustain for the duration of the sequencer step, trigger out should be short notes (which could be lengthened by other modules).
If this doesn't work, check your midi cable (or rather, another). |
sebber
G2 patch files: 33
Posted: Thu Apr 06, 2006 11:24 am Post subject:
Hm, that's what I tried. Are there differences in the quality of MIDI-cables? I thought they work or they don't. I'll try another one and tell you about it. Thanks already! _________________ Fish don't swim. They dive. |
Fozzie
G2 patch files: 49
Posted: Thu Apr 06, 2006 11:33 am Post subject:
On a re-read of this thread, I saw you already mentioned the pulse lengthening in your first post. Missed that, sorry . It would be weird if the midi cable were to blame, but bad cables can cause all kinds of strange behaviour, therefore I'd check another before doing anything else. If it's not that, it would be really strange. It should be very well possible to send 16th notes at 120 bpm over midi without hickups. |
Audio files: 235
Posted: Thu Apr 06, 2006 1:32 pm Post subject:
I think it's a module evaluation situation. If you use the same oscillator to clock the sequencer that you use to send the MIDI, then you run the risk that the MIDI get clocked out before the sequencer changes. You could run the clock to the MIDI send module through a couple of inverters to delay it. _________________ --Howard
my music and other stuff |
sebber
G2 patch files: 33
Posted: Fri Apr 07, 2006 8:26 am Post subject:
Well, I thought I did do it with the event button row, but obviously I did something else. Hm.
Anyway, it works. Howard's trick works as well, but only when I use one inverter, not a couple of them (2 or 4 that is, maybe it works with 3).
Thanks everybody, especially Howard, you saved me from 2 hours of really boring patching. _________________ Fish don't swim. They dive. |
