 Forum index » Clavia Nord Modular » G2 Patches - Completed » FX
New guitar amp simulation
Fozzie
G2 patch files: 49
PostPosted: Tue Jun 27, 2006 3:40 pm    Post subject: New guitar amp simulation
Subject description: distortion & FX
Yeah, finally had an entire evening to do some old fashioned patching. As I'm into distorted guitars again lately (good for getting rid of frustrations), I had another go at some amp simulation. I try to stand on the shoulders of synth-giant Rob here as I used almost all distortion-circuitry from him. I also incorporated my FDN reverb as well as an updated version of early reflections. I did some semi-precise calculations on the spacing of delay times for a small to medium sized room, and am quite happy with the result. Adds impact or punch (to my ears at least). I will also include a small mp3 with the reverb a bit overdone just to (over)demonstrate the point. The reverb tail can still be optimized further, but this is it for now.
If interested, have fun and shred away Cool
edit: added a second version of the patch some 8 hours after first post, to fix some inaccuracies I thought of while sleeping Laughing
edit2: you might want to add a rectifier between the lowpass output of the multi-filter and the mixer it feeds back into (it is an idea from the music-dsp archives in which low frequency energy of the signal influences the distortion by adding it as a sort of tube-bias signal; by including a rectifier this effect becomes assymetrical as it should be in tubes, however this is probably not very accurate. Listen and add to taste.
FozzieAmp.mp3
Strat played into cheap behringer (mic)preamp into G2.
 Filename:  FozzieAmp.mp3
 Filesize:  566.17 KB
 Downloaded:  1645 Time(s)
FozzieGuitarFXnAmp.pch2
Newer version of the patch; contains better extra 'bias' and feedback circuit. Nothing scientific, more judged by ear. Amp sim with some included FX and my own ER and FDN reverb.
 Filename:  FozzieGuitarFXnAmp.pch2
 Filesize:  9.22 KB
 Downloaded:  2052 Time(s)
