G2:Sequencer,VoiceMode,Triggering
Page 1 of 1 [8 Posts]
rosn
PostPosted: Tue Jul 18, 2006 6:01 am    Post subject: G2:Sequencer,VoiceMode,Triggering Reply with quote  Mark this post and the followings unread
How do I have to patch a Sequencer and an Envelope(triggering an Osc), so that, playing triads on the keyboard, there is no note or even more notes hanging over to the next triad ? ( i.E.: in 4 VoiceMode, always one note
is hanging over into the next triad?)
Audio files: 235
PostPosted: Tue Jul 18, 2006 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome rosn
I don't quite understand what you are asking. Maybe someone else will understand, or maybe you can post a patch that is giving you a problem.
rosn
PostPosted: Tue Jul 18, 2006 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
hello mosc
I am trying to be more specific:
posted Patch: the SeqA is triggering the Envlope; I play a triad(C-E-G) on G2 keyboard and then another one(Bb-D-F), expecting that the first triad ist getting cleared. But instead there is always a note from the first triad hanging over into the second one.(i.E. Bb-D-F-G)
If 4 voices, then it`s one note, if 5 Voices it`s 2 notes etc......)
I coud solve the problem with another Envelope, but there must be a better
solution....
Thanx
example.prf2
 Filename:  example.prf2
 Filesize:  13.71 KB
 Downloaded:  1447 Time(s)
Audio files: 235
PostPosted: Tue Jul 18, 2006 10:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I think the problem is that when there is no keyboard key pressed, you are still hearing the synth being gated by the sequencer. Here is a little fix that only allows the sequencer trigger signal though an AND gate when the keyboard has a key pressed.
MsClkInTrigSwitc.pch2
example patch
 Filename:  MsClkInTrigSwitc.pch2
 Filesize:  1.47 KB
 Downloaded:  2905 Time(s)
rosn
PostPosted: Tue Jul 18, 2006 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
the thing is:
I want the Seq to keep gating the synth even when no key is pressed
(like some good old Farfisa rhythm comping), using the keyboard only
to change pitch.
thanks for thinking
Audio files: 235
PostPosted: Tue Jul 18, 2006 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Then press the KB Hold key on the front panel. Very Happy
rosn
PostPosted: Tue Jul 18, 2006 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Damn Right!
thanx
Audio files: 235
PostPosted: Tue Jul 18, 2006 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool... Glad to help.
Moving this to NM Discussion as it's not a FAQ, really...
