cappy2112
Joined: Dec 24, 2004 Posts: 2448 Location: San Jose, California
Posted: Thu Aug 03, 2006 9:27 pm Post subject:
Patch Volume vs Perf Volume (starting all over again) |
After loading a perf which had the volume up pretty high, I had frantically tried turning down the volume in the editor, but nothing happened.
After looking through the G2 manual, I couldn't find a reasonable explanation for this.
Is there a logical reason why this is, other than "that's the way it was designed"?
Wouldn't it be trivial for Clavia to add a perf volume knob in the editor, or make the patch volume work for perfs as well? |
Afro88
Audio files: 12
G2 patch files: 79
Posted: Thu Aug 03, 2006 9:34 pm Post subject:
There are a few basic functions missing from the engine. Global variation changes and global volume are among them unfortunately. |
cappy2112
Posted: Thu Aug 03, 2006 9:38 pm Post subject:
Afro88 wrote: | There are a few basic functions missing from the engine. Global variation changes and global volume are among them unfortunately. |
Are you saying the editor works differently on the KB version, or are you referring to the HW volume control on the KB? |
Posted: Thu Aug 03, 2006 9:57 pm Post subject:
Functions that the keyboard can do, are not available in the editor (whether it be an engine or keyboard connected, the engine is the same). |
gomidas
Joined: Jul 09, 2004 Posts: 365 Location: La Ciotat, France
G2 patch files: 6
Posted: Fri Aug 04, 2006 3:26 am Post subject:
Quote: | Functions that the keyboard can do, are not available in the editor (whether it be an engine or keyboard connected, the engine is the same). |
So there is no cc# to do that?  |
dasz
Joined: Oct 16, 2004 Posts: 1643 Location: vancouver, canada
Audio files: 29
G2 patch files: 56
cappy2112
Posted: Fri Aug 04, 2006 9:32 am Post subject:
gomidas wrote: | Quote: | Functions that the keyboard can do, are not available in the editor (whether it be an engine or keyboard connected, the engine is the same). |
Yes of course. But do you want to go in and modify all the perfs you downloaded? |
cappy2112
Posted: Fri Aug 04, 2006 9:37 am Post subject:
dasz wrote: | gomidas is pointing to the solution.
Use a set of mult modules (for stereo outs) before each out module and use a CCRecv to modulate the volumes (level). Now when you switch variations the last recieved cc sets the volume thus you have no sudden jumps in volume (as it was programmed for each variation).
Repeat accross other slots (even use the same cc# and midi channel for one overall volume control. It's a hack, but works.
Here's a prf2 to illustrate. Slot 2 changes the Overall volume of slot a (yes it is affected/multiplied by the variation volume, but the 2nd volume control is not affected by variation changes). I included a variation switch so you can see that your volume is taken into account.
In order for this arragement, i had to change my approach to patch volume during patching. IE i keep it cranked across every patch and variation (in other words I do not use CC7 to control volumes at all). The patch inner/contained instrument) volumes are controlled by mixers within each patch. the master volume (as illustred in the prf2 controlled by cc#8 ), keeps volume consistent across varations.
I use an extrnal midi controller as my G2 slot "mixer" - i use the g2 knobs for fun stuff . Hope this helps.
/Dasz |
Yes this obviuosly would work, but if it's not already in everyones mind to add these to their perfs, it's not practical, and it doesn't help the thousands of perfs already in existence.
A centralized way to control perf volume in the editor would be ideal, to eliminate having to go back and edit all your perfs. And as Jan pointed out, an individual patch volume control (knob) would also be helpfull.
These are mainly for Engine users. |
Joined: Jan 31, 2003 Posts: 18012 Location: Allentown, PA
Audio files: 163
Posted: Fri Aug 04, 2006 11:26 am Post subject:
On the KBD models, there is no global volume control either except for the volume knob on the front panel. I use this a lot in just auditioning patches and in live performance. If I had an engine, I would run it through a mixer and use the faders. _________________ --Howard
my music and other stuff |
gomidas
G2 patch files: 6
Posted: Sat Aug 05, 2006 11:57 am Post subject:
Or you can also MORPH ASSIGN ( morph 8 ) the 4 Patch Level knobs of your perf to the 2d Modwheel (morph 8 ) and use a midi controller (bcr2000 ) with a dedicated cc# 97 knob on the global midi channel of your G2.
But you'll also have to modify all your patchs, maybe do it one by one as you use them... |
