today> Twyndyllyngs reschedule: Sunday, Dec 6 Chez Mosc
Quantize toggler
Page 1 of 1 [7 Posts]
moom
PostPosted: Thu Dec 14, 2006 3:36 pm    Post subject: Quantize toggler Reply with quote  Mark this post and the followings unread
Can anyone help me here on this patch I have started.
It is designed to toggle between 2 sequencer modules but only on the first beat of a bar.
I have got as far as getting the switch to toggle and quatize correctly, but the logic pulse is only momentary and so the gate closes after a 16th then re-opens every first beat - Sad
I have tried a few ideas with no avail. Is it possible to create more logic gates than is available? Can you link logic gates to create other gate forms? that would work I am sure.
Here it is:
qUANTIZE TOGGLE.pch2
 Filename:  qUANTIZE TOGGLE.pch2
 Filesize:  1.98 KB
 Downloaded:  1468 Time(s)
G2 patch files: 626
PostPosted: Thu Dec 14, 2006 4:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can combine the gates to make more complex logic structures but in this case you could just use the flip flop to do the toggle as shown.
The 'sequencer examples' section in the editor help also has a serial connection example that does this without any additional modules at all.
quantize_toggle2.pch2
example
 Filename:  quantize_toggle2.pch2
 Filesize:  1.75 KB
 Downloaded:  1814 Time(s)
PostPosted: Thu Dec 14, 2006 5:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or like this
seq-toggle.pch2
 Filename:  seq-toggle.pch2
 Filesize:  1.88 KB
 Downloaded:  3064 Time(s)
moom
PostPosted: Fri Dec 15, 2006 1:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for this but the most important aspect of the patch is the switch used to toggle between sequencers.
I wanted one seq looping endlessly and then when I flicked the switch, the patch would wait til the first beat of a bar to start the second seq.
Aren't your patches more like glorified 32 step sequencers. However, the do leave scope for other thingsthat a normal link wouldn't allow.
thanks, but any more advancements?
G2 patch files: 626
PostPosted: Fri Dec 15, 2006 1:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Exactly like Smile
Sorry, missed your point somehow. Is this what you wanted?
The D type flip flop syncs the switch state change to the start of the bar.
quantize_toggle3.pch2
example
 Filename:  quantize_toggle3.pch2
 Filesize:  1.8 KB
 Downloaded:  1946 Time(s)
moom
PostPosted: Fri Dec 15, 2006 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
That is exactly what I wanted!!! Laughing
Thankyou Mr g2ian.
You managed to do it with minimum fuss and speed might I add. I did pull up that flip flop module and thought it should be used for this, but I just don't have much experience or knowledge at this stage. I managed to make a complete mess of the other one, eh Smile
How long have you been using the G2 then?
All the best my friend and many thanks again.
BTW: check out my website to hear the sorts of sounds I make. This knew module will be part of a new project that i am working on. I'll post it up on the site when done and let you know about it. This wasn't meant to be a gratuitous plug by the way Wink
G2 patch files: 626
PostPosted: Fri Dec 15, 2006 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Your welcome
I've been using a G2 for a long time, and other modulars before that.
I look forward to checking out your new project.
