Masa921 Micro VCO
Page 1 of 2 [38 Posts]
23isgood
PostPosted: Sat Mar 03, 2007 4:34 pm    Post subject: Masa921 Micro VCO
Subject description: Micro VCO
Hi folks. I recently received the parts I needed to build this VCO so I built it on my breadboard. When I power it up nothing comes out. When I touch some of the resistors and capacitors it starts oscillating. In particular R3 (10k) and the 47k resistor at the CV input, and it starts oscillating when I touch C1 the 470pf cap. Whats going on here? Why is it not oscillating on its own?
Also I noticed from the pics on Masa'a site that his VCO has a different value resistor than stated on his schematic. It looks like a 332 ohm resistor.
Can you guys share some tips on what I should do? When I touch a resistor is it creating more of a resistance? Does this mean that a higher value resistance is required?
thanks
pete
Masa Micro VCO
 Filesize:  14 KB
 Viewed:  28044 Time(s)
23isgood
PostPosted: Sun Mar 04, 2007 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nobody has any advice Sad
G2 patch files: 626
PostPosted: Sun Mar 04, 2007 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Touching a resister will not increase it's resistance. It might fix a bad connection on the breadboard, or introduce your body capacitance into that part of the circuit.
332 ohms does not seem like a probable value for a resister.
Sorry cant be of much help.
23isgood
PostPosted: Sun Mar 04, 2007 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well it clarifies the issue of touching a resistor. So our bodies act like a capacitor when touching things. I will try rebuilding the circuit. This will be the third time. Though its not to bad since this is such a simple circuit.
thanks
Audio files: 297
PostPosted: Sun Mar 04, 2007 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure how exactly this oscillator is supposed to work.
I see a current source built arounf Q4,5 sending current into C1. To make the circuit oscillate C1 will have to be dischared again. Apparently this is done by the voltage rising over C1 making the part around Q2,3 go into conductance until the voltage drops enough to make it restart (and that's the part I don't quite understand).
When however this is true the emitter of Q1 should be at some positive voltage to make it work I'd think, which means that one of the alternatives from the (R, Vr, Vr) box should be connected - preferably the R opion to keep things simple.
Would this give any clues for investigating things further ?
23isgood
PostPosted: Sun Mar 04, 2007 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well I built it again with the same results. Has anyone else tried to build this? I know there where a few people interested. I think I will try one more time with different transistors.
PostPosted: Sun Mar 04, 2007 8:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree with Jan. Try connecting one of the options in the top left box. If that connection is left floating it would be very susceptable to body capacitance effects. Well, that's what I think! Very Happy
23isgood
PostPosted: Sun Mar 04, 2007 8:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well I did try it. I connected R2 to a 100k resistor then to +12v and that didn't work then I connected R2 straight to +12v with no difference. I did not add the hard synch circuitry, i'm not sure if that would make a difference? Though I had added it before.
I am using a 7812 and 7806 for the +12v and +6v. I'm feeding +15v into the 7812 which is feeding the 7806. I checked the voltages coming out of those and they are correct.
When I touch the resistors and it starts oscillating I noticed that the tracking is backwards. On the left of the keyboard the octaves are high and to the right of the keyboard the octaves are low.
G2 patch files: 626
PostPosted: Sun Mar 04, 2007 10:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is interesting. I would have expected the 6V to be derived from a simple resistive divider, (12V)--[100K]---(6V)---[100K]---(GND)
Probably not the problem but will save the cost of a 7806.
Audio files: 297
PostPosted: Mon Mar 05, 2007 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
If it doesn't oscillate what is the voltage over C1 ?
23isgood
PostPosted: Mon Mar 05, 2007 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I finally got it to oscillate but it wont track pitch. The CV input doesn't sound like its working. If I increase the resistance going to R2 from R the pitch goes down. At the low freq's it sounds very meaty as Andrew had said. Lots of bass. This could be a nice VCO if I could get it to work properly.
CJ Miller
PostPosted: Mon Mar 05, 2007 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some interesting circuits from this person! Could be perfect for some kind of portable EMS-like noisemaker. Don't know if I'll try this one though. Reminds me of the old ARP VCOs. I read online that there is another VCO which uses 2SC1583s for the expo pair, anybody have a diagram for that one?
Adam-V
PostPosted: Mon Mar 05, 2007 7:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is this the one you were thinking of?
René Schmitz VCO3 http://www.uni-bonn.de/~uzs159/vco3.html
EDIT:
Oh, and greetings from down under. I just realised I hadn't introduced myself here yet!
Adam-V.
andrewF
PostPosted: Tue Mar 06, 2007 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I seem to remember Masa saying (via Takeda's San's translation), control is best thru the Hz/volt (linear) control. I find the setup for the linear pots strange, wouldn't it be better to wire the pots as voltage dividers, as per the v/oct pot? Smile i'm just pondering, not a technical deduction.
glad you got some noise coming out of it at least.
with the 2SC1583, I've used them in many VCOs, also Takeda San has some VCOs with them and PCB layouts too
http://www.aleph.co.jp/~takeda/radio/homemadesynthE.html
PostPosted: Tue Mar 06, 2007 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Adam-V wrote:
EDIT:
Hey Adam! welcome to electro-music.com Very Happy
ACHTUNG!
23isgood
PostPosted: Tue Mar 06, 2007 5:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok I finally got it working. I followed Andrews advice and I just removed the Oct/V CV circuitry and placed it in the LIN CV and now it works! Its a falling saw tooth wave shape. It sounds great, though it does not track all that well but it could be used for all sorts of things. Check out the sample I just recorded. I'm using a CGS Sequential Switch to trigger the VCO and I got the VCO going through a CEM3320 filter and thats it. Now I going to make some PCB's. I love it when things work after spending time troubleshooting. I still have to test the hard synch.
thanks for the help folks
pete
micro VCO sequence.mp3
micro VCO sequence
 Filename:  micro VCO sequence.mp3
 Filesize:  3.4 MB
 Downloaded:  1387 Time(s)
andrewF
PostPosted: Tue Mar 06, 2007 8:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
well done Pete
sounds good
you'll probably never be able to play Bach with it, but should be useful for many patches.
If you make a PCB, consider getting the transistors close enough to touch each other, or at least gloop the whole thing once its finished and working. I'm sure Masa921 originally made this cct as a little blob in an attempt to maintain some thermal stability and reduce drift.
just curious, did you leave the V/oct input floating or is there still a pot there?
23isgood
PostPosted: Tue Mar 06, 2007 10:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I left out all the V/oct circuitry including the trimmer. I have been designing the PCB with all the transistors close toghether. I'm fairly new to designing PCB's so I hope it works ok. I will let ya know how it comes out. I noticed that when I blow on the transistors the pitch changes slightly so as you mentioned I will cover it using some kind of goop. I'm going to try designing the PCB to hold a few VCO's on it.
Fernando
PostPosted: Tue Mar 13, 2007 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
maybe Magnus Danielson V/oct to V/Hz converter will work fine here...
andrewF
PostPosted: Fri Mar 30, 2007 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
hi
i was hunting thru my Takeda files for a schematic and found this forgotten gem
a dual discrete VCO based on masa921's miniVCO
plus a PCB layout
http://www.aleph.co.jp/~takeda/radio/harvest/img/schem/DualTBVCO3a-schem.gif
http://www.aleph.co.jp/~takeda/radio/harvest/pdf/DualTB-pattern.pdf
and while you are there check out the dual 555 VCOs
http://www.aleph.co.jp/~takeda/radio/harvest/ExpSchems.html
Fernando
PostPosted: Fri Mar 30, 2007 9:52 am    Post subject: Reply with quote  Mark this post and the followings unread
hey, the dual discrete VCO looks great, so simple!
thanks!
Scott Stites
Audio files: 96
PostPosted: Fri Mar 30, 2007 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah! Forgot about that - Motohiko sent me some samples he'd done with it at the time (it's my firm belief if there was a God, Motohiko would be the reigning rock and roll king in all of Japan and beyond).
His electronics projects certainly are outstanding, as well.
Dang, I've still got a Steiner VCF board around here somewhere that he did for me.
Scott
23isgood
PostPosted: Fri Mar 30, 2007 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey cool a PCB! I guess im going to build this one.
thanks for posting it.
pete
Check out my music
janvanvolt
PostPosted: Wed Apr 18, 2007 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
andrewF wrote:
hi
plus a PCB layout
May i ask for assistance ?
I am a bit lost which Trannies are which on this PCB.
I have: SK118, SA1175, SC2785 (micro vco). Do the Dual TB uses others ?
Is there a more detailed BOM ?
--jan
andrewF
PostPosted: Wed Apr 18, 2007 4:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
I see on the schematic one FET is a p-channel - 2sj103, the other fets are ordinary n-channel, i used the sk30 on most VCOs i built from CGS and Takeda San.
The npn and pnp transistors - Often Takeda San used C1815 and A1015, which are general purpose audio, I don't know if he used any special types in this design, presumably he would have labelled them if he did.
Probably safe to use your favorite npn and pnp transistors but the FETs will be fussier.
