 Forum index » Clavia Nord Modular » G2 Performances - Experimental
spira
G2 patch files: 626
PostPosted: Wed Oct 12, 2005 3:22 am    Post subject: spira Reply with quote  Mark this post and the followings unread
This rhythm section is a restructure of that in the 3080 prf. The way I handled the percentages was using an 8 in mux. Three pairs with 25% probability each with the last 25% being distributed dynamically to one of the three, kick, snare and HiHat.
This worked but I was curious as to what it would sound like to smoothly adjust the percentages. This version uses three sets of three window switches, the from/to points can be morphed from the 50%/25%/25% setting through to 100%/0%/0%.
The 100% position sounds really bad but the intermediates offer another dimension to the variation.
The instrument in slot A is an experiment with applying the wave wrapper to a variable sub section of each wave cycle.
Slot D is noise, mostly just noise but it does drift into some interesting textures occasionally.
spira.prf2
some experiments
 Filename:  spira.prf2
 Filesize:  8.74 KB
 Downloaded:  2177 Time(s)
SPIRA-eDIT.mp3
audio sample
 Filename:  SPIRA-eDIT.mp3
 Filesize:  2.01 MB
 Downloaded:  1817 Time(s)
cebec
G2 patch files: 31
PostPosted: Wed Oct 12, 2005 8:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
awesome! thumleft
it sounds so good and it's a cool piece
varice
G2 patch files: 54
PostPosted: Fri Oct 14, 2005 12:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow! This is a very dreamy perf. Such a nice tone and atmosphere. Cool
Thanks Ian!
varice
