 Forum index » Clavia Nord Modular » G2 Performances - Experimental
InsidePianoG2
Page 1 of 1 [6 Posts]
G2 patch files: 626
PostPosted: Fri Jan 27, 2006 11:40 pm    Post subject: InsidePianoG2 Reply with quote  Mark this post and the followings unread
I was searching the NM archives for piano related posts and came across a Classic Patch that was supposed to recreate putting your head inside a piano and dropping something heavy on the lower part of the keyboard. The linked sample was gone unfortunately.
I translated the patch to G2 and it is a nice-ish electric piano sound but when simulating the missing formant oscillators, you only get 7 voices on an unexpanded G2. Apparently, the demo sound was made with 2 or 4 pass multi tracking and gobs of eq and reverb in the post processing.
Here is my G2 version, I replaced the piano patch with a nice lean FM piano, the original patch used 3 random modules clocked by the key gate to give nice variation in tone for each key press. I have left the key sync off the PM oscillators which lets the free running oscillators vary the tone. Slot B has 24 midi zone modules that take a single key press and transmit 24, semitone spaced notes to slot A. Slot A audio is bussed to slot B where it gets a two stage chorus/compressor/EQ/reverb.
No post processing required.
InsidePiano.prf2
head in a piano
 Filename:  InsidePiano.prf2
 Filesize:  6.8 KB
 Downloaded:  2234 Time(s)
inside.mp3
audio sample, direct from G2
 Filename:  inside.mp3
 Filesize:  134.95 KB
 Downloaded:  1923 Time(s)
Ivity
G2 patch files: 57
PostPosted: Sat Jan 28, 2006 6:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent performance! Very Happy
Igor
www.myspace.com/phoiod
www.bl-project.com/Ivity.html
Audio files: 235
PostPosted: Sat Jan 28, 2006 10:13 am    Post subject: Re: InsidePianoG2 Reply with quote  Mark this post and the followings unread
Laughing Yes, that appears to be the case.
G2 patch files: 626
PostPosted: Tue Jan 31, 2006 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Found a link to the classic version mp3 sample on Synth DIY of all places, first time I have actually heard it. Spooky Shocked .
http://home.att.net/~elhardt3/Inside_The_Piano_Nord.mp3
TheRain
G2 patch files: 9
PostPosted: Thu Feb 02, 2006 11:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey man, I really liked yours better... that's a really cool effect.
3phase
G2 patch files: 141
PostPosted: Sun Mar 19, 2006 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
very cool sound....
