revised 292c LPG PCB layout...
Page 1 of 4 [85 Posts]
Goto page: 1, 2, 3, 4 Next
PostPosted: Tue Nov 27, 2007 5:06 am    Post subject: revised 292c LPG PCB layout...
Subject description: ... ready for (not only) press'n'peel blue.
just revised the layout and documentation on the 292c LPG:
http://www.modular.fonik.de/pdf/LPG_em.pdf
(if it does not show up right, try to download it before opening)
etaoin
PostPosted: Tue Nov 27, 2007 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.casia.org/modular/
Funky40
G2 patch files: 5
PostPosted: Tue Nov 27, 2007 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
ouhh, thanks,
But Matthias, can you please leave the old one also on your site ?
I personally love the very fast building on your modules because of Printmounted Pots or Sockets.
For Euro/Frac use it allows a real fast building.
PostPosted: Tue Nov 27, 2007 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
okay funky, i will compile it into the new PDF...
ericcoleridge
PostPosted: Tue Nov 27, 2007 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
This is so great Fonik, thanks for another great layout!
Do you have any other projects in the works (so I can plan ahead)?
The only small problem I have with printing your layouts is that I can't cut and paste from a PDF (as far as I know). I have to print the whole page--which wastes alot of valuable press and peel real estate.
PostPosted: Tue Nov 27, 2007 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
no need on wasting press'n'peel: just print it out on paper. fix a piece of p'n'p blue on the printout using scotch tape. put it into your printer again and print again!
photo essay
krisp14u
PostPosted: Tue Nov 27, 2007 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hay matthias cheers for this
there wil be 2 going in the modular this week Smile
cheers paul
Paul Darlow
www.krisp1.com
ericcoleridge
PostPosted: Tue Nov 27, 2007 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
photo essay
Well, I wish I asked you about this sooner... I've been using whole sheets for each layout. I'm not always the brightest bulb in the box.
PostPosted: Wed Nov 28, 2007 2:07 am    Post subject: Reply with quote  Mark this post and the followings unread
i incorporated the old docs into the file available via my site (different than link above)...
goldenechos
PostPosted: Wed Nov 28, 2007 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I built the original layout of this 292, and I have to say, it sounds great.
Very useful.
Glad to see you tied up the unused op-amp in this layout!
Tony
loss1234
PostPosted: Thu Nov 29, 2007 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
i am a bit confused as to how this circuit works or what it does. is it just a gate or is it more like a filter?
thanks
goldenechos
PostPosted: Thu Nov 29, 2007 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks
Either or a a little of both. There are sound examples at the Plan b website.
Tony
PostPosted: Mon May 26, 2008 11:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
corrected BOM for the revised 292c LPG layout:
R4, R9, R10 are 100k!
asafnetzer
PostPosted: Tue May 27, 2008 3:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks great Fonik,
Just wondering, if anyone here is willing to etch me a board as well I'll pay for the work and shipping.
Press'n'peel is unavailable in Israel and I don't have any other components for the etching process, Stripboard is my thing Wink
Asaf
guitarfool
PostPosted: Tue May 27, 2008 5:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
NOW you tell me Shocked
(Actually, I went by the values on the schematic).
I didn't do the resonance modification. Has anyone tried it yet?
zthee
PostPosted: Wed May 28, 2008 12:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I just started to build 2 of these, but with the old documentation Smile
Just need the vactrol and the usual wires to pots and stuff like that. Hope to be done within a week or so!
Coriolis
PostPosted: Wed May 28, 2008 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I can't get it directly from a vendor in my country either, but smallbear.com has it in single sheets, and I actually splashed some cash and bought a pack of 20 sheets direct from the manufacturer techniks.com
The rest of the gear for etching is easy too: I use ferric chloride (should be available from where ever you go to buy household chemicals), some tupperware for the etching bath, rubber gloves, etc. Only thing that might cost a bit is a Dremel or similar (I have a Proxxon) drill with a stand. I suppose you can use a normal electric drill, but the stand for it is mandatory, because those tiny 0,8mm drills break easily.
C
Edit: Just found this!
http://www.pcb-store.com/
PostPosted: Wed May 28, 2008 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
some people get very good results with paper from weekly magazines or catalogues. google for it (don't have the link on hand right now).
ericcoleridge
PostPosted: Wed May 28, 2008 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
For me, press n' peel works the best; But I've successfully used glossy inkjet printer paper in the past. I've also read where people describe glossy magazine paper (just ripped from a magazine) as working best of all.
asafnetzer
PostPosted: Thu May 29, 2008 3:12 am    Post subject: Reply with quote  Mark this post and the followings unread
If I'll walk to a store in Israel and ask for chemicals I'll get arrested Wink
No actually I really don't have any more space in my apartment for anything, even the dog is afraid to sit on the floor cause all the stuff laying there.
zthee
PostPosted: Wed Jun 25, 2008 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Just finished my dual LPG!
I think something is wrong with the gate part though. Does anyone who built it got a sound sample of it?
I just wanna verify that it sounds like it should! Smile
PostPosted: Thu Jul 10, 2008 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
helo zthee,
my apologies for this late reply. hope you have some fun with your LPGs anyways.
here is a short sample of the LPG.
square wave into LPG, offset fully clockwise, pulse from CGS utility LFO into LPG.
8 pulses in each mode: 1st filter mode, 2nd gate mode, 3rd both.
LPG_01.mp3
the three modes of the LPG: filter, gate, both
 Filename:  LPG_01.mp3
 Filesize:  131.25 KB
 Downloaded:  1803 Time(s)
widdly
PostPosted: Thu Jul 10, 2008 8:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
I built one of these last night on a piece of perf board using a bunch of parts I had in my junk box.
I added a 100k attenuator on the trigger input. It's handy in filter mode.
I left out C5 and R5. I can't quite work out what they are for. Anyone tell what they are meant to do?
For D1, I didn't have a 3.5v zener so I used a 5v. I'm guessing the zener here is to stop the LED's from getting blown by too much voltage. Any the zener is for?
I didn't have a 20k trimmer so I left out R7 and used a 50k trimmer.
I made my own vactors using two LEDs and two LDRs. The LDRs were two different sorts Shocked . Only problem is getting the LED/LDR combo light tight..at the moment it works ok if I put it under a t-shirt Embarassed I think I'll do something with heat shrink and lots of electrical tape.
It sounds really great, much like the samples from fonic above. I was kind of surprised given the hokey nature of my "vactrols" and my liberal interpretation of the schematic.
zthee
PostPosted: Fri Jul 11, 2008 9:36 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
helo zthee,
Sounds exactly as mine!
What a relif Smile
Thanks for the upload!
PostPosted: Fri Jul 11, 2008 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
good to hear. i am using the LPG in filter mode most of the time. only sometimes i use it at VCA...
