gmeredith
Joined: Jun 28, 2006 Posts: 82 Location: Tasmania, Australia
Posted: Fri Apr 19, 2013 2:42 am Post subject:
interesting,. I have an SK1 myself that still needs to be modified, and memory expension would be great
As for the displays, I wanted to drive a couple of displays a while back and if I remember correctly this either needed some special cmos/TTL chips
(which are no longer available) or a lot of extra logic which wasn't worth it in my opinion. So eventually I did use a PIC (not what you want).
So I'll keep my eye on this thread in case someone offers a solution.
you could do something else, that is use the dot on the display to indicate higher numbers. So use 3 bits to control the display from 0-7 and use the
4th bit for the dot which indicates 8-15. _________________ "My perf, it's full of holes!"
gmeredith
Posted: Fri Apr 19, 2013 3:52 pm Post subject:
Actually, yes, that's what I had been doing before I went with the 4029 counter - I had the 4511 hooked up to the lowest 3 address lines and the 4th to the dot. It's okay, and simple, but I just wanted something more aesthetic and user-friendly. If I can't find anything simple I'll go back to that.
Is there anyone out there that sells pre-programmed PIC chips to do this?
I'm amazed to find out how difficult it seems to be to do such a simple job. Surely there's some driver counter chip that simply overflows any number over 9 to another digit?
Cheers, Graham |
-minus-
Posted: Fri Apr 19, 2013 4:17 pm Post subject:
| I recently built a two digit counter using the same IC's. there is an incorrect schematic somewhere on the web where the cascading will not work correctly. I'm away from home for a couple more days but I will check and see how I did this. I think you replicate your counter and decoder for the second display and take the carry out pin (pin 7) of the single digit/units, to the carry in pin (pin 5) of the double digit/tens. The reset pins of the two counters are tied to set the count to 00. |
gmeredith
Posted: Sun Apr 21, 2013 5:22 pm Post subject:
Wow, thanks, minus! I'll give it a try soon and see how it works out. Thanks for your help!
Cheers, Graham |
-minus-
gmeredith
Posted: Mon Apr 22, 2013 4:16 pm Post subject:
| Seems good - but where do you output the 4 address lines for a RAM chip? |
analog_backlash
Joined: Sep 04, 2012 Posts: 393 Location: Aldershot, UK
Audio files: 21
Posted: Mon Apr 22, 2013 6:12 pm Post subject:
| PHOBoS wrote: | interesting,. I have an SK1 myself that still needs to be modified, and memory expension would be great ... |
I've got an SK-5 which I would love to do a memory expansion on, but I'm not currently up to that standard . I'd be very interested in any postings on this subject as it may eventually give me the required knowledge to bite the bullet on that one! The 2-digit display should useful as well.
I'll watch this space...
Gary
P.S. I also have a PT-1 is pieces, which I'm planning to do some bending on. I've so far sprayed the (white) case black, so that usefully, you can't read what any of the buttons are for (didn't think that one through). I did this, because I was only going to use the keyboard for a tiny synth. I still might do this. |
gmeredith
Posted: Mon Apr 22, 2013 6:21 pm Post subject:
The memory expansion for SK5/SK8 is well established and documented - I wrote up a guide for it:
http://www.warningwillrobinson.com.au/index_files/SKexpansion.htm
The chip that is specified is no longer available for it (32x chip) but there is still a smaller one of the same kind that gives 16x expansion, and is used exactly the same way.
Cheers, Graham |
-minus-
Posted: Mon Apr 22, 2013 11:01 pm Post subject:
| gmeredith wrote: | | Seems good - but where do you output the 4 address lines for a RAM chip? |
Ah yes. Sorry about that. I now see what you are trying to do. |
analog_backlash
Audio files: 21
Posted: Tue Apr 23, 2013 6:32 am Post subject:
Thanks for the excellent guide Graham! When I'm feeling brave one day, I will have a go at this .
Gary |
gmeredith
Posted: Tue Apr 23, 2013 4:32 pm Post subject:
I forgot! Here's an even better guide, with photos, taking you through every step of the process - it's for my DM100 keyboard - which has an sk5 as the upper keyboard:
http://www.warningwillrobinson.com.au/index_files/Professor.htm
It's down the bottom of the page, under the DM100 info.
So it will be exactly the same for your keyboard, except for a couple of hookup places on the board, which I could walk you through when you want to do it. |
