cablebasher
Posted: Tue Mar 18, 2014 2:04 am Post subject:
Hey, just wondering if any PCBs were ever made for this module and if so, are they for sale. Could really use one in my euro setup.
If not, does anyone have any photos of breadboards or perfboards of the circuit that I could use for reference.
Following schematics was never my strong point.
Thanks. |
Posted: Tue Mar 18, 2014 3:56 am Post subject:
not yet. just my prototypes, however, i could revive this project. and offer eurorack front panels as well. _________________
Tech Buddy at Random*Source |
LFLab
Joined: Dec 17, 2009 Posts: 497 Location: Rosmalen, Netherlands
Posted: Wed Mar 19, 2014 3:26 am Post subject:
| Made one on perfboard, quite simple. But my perfboard layouts are done on the fly, and are hardly exemplary! |
cablebasher
Posted: Fri Mar 21, 2014 9:53 am Post subject:
I would definitely buy a PCB and panel if an order was placed.
If not, a breadboard or perfboard photo would be great for reference to build my own.
Cheers. |
philoop
Posted: Sat Mar 22, 2014 7:55 am Post subject:
clock divider |
hallo fonik! i got some spare cd 4020....could i extend the resoulution to 64 128 256? and how? _________________ Deploying dual-wavelength fNIRS, we interrogate 16 locations in the forehead when eight able-bodied adults perform deception and truth-telling scenarios separately. |
roglok
Posted: Fri Mar 28, 2014 4:52 am Post subject:
| matthias, i have a working stripboard layout for your divider (thanks for sharing!). are you OK with me posting the layout here? |
Posted: Fri Mar 28, 2014 7:39 am Post subject:
Re: clock divider |
| philoop wrote: | | hallo fonik! i got some spare cd 4020....could i extend the resoulution to 64 128 256? and how? |
shure. one could even add an additional switch to select certain divisions. however, the 4020 is not pin compatible...
BTW the inverters are not needed, they are just my appreoach/idea to divisions. _________________
Posted: Fri Mar 28, 2014 7:40 am Post subject:
| roglok wrote: | | matthias, i have a working stripboard layout for your divider (thanks for sharing!). are you OK with me posting the layout here? |
go ahead. this is the DIY forum  _________________
roglok
roglok
Posted: Fri Mar 28, 2014 9:30 am Post subject:
| it's been a while since i've done this one, so it's not as compact as my newer layouts, but unless you are building a tight skiff, it should work... |
acidblue
Joined: Jun 26, 2009 Posts: 226 Location: The Darkside
Posted: Mon Jan 09, 2017 1:37 pm Post subject:
Forgive me for asking a stupid question in an old thread.
But what is the 4069 for?
Couldn't you take the signal from the 4024 into the transistors?? |
Posted: Mon Jan 09, 2017 1:50 pm Post subject:
you could. i use the 4069 inverters to invert the logic.
a normal divider goes to all OFF when receiving a reset, mine goes to all ON.
you may want to have both options? _________________
acidblue
Posted: Mon Jan 09, 2017 1:57 pm Post subject:
Ohhhh, pretty clever of you.
Thanks Fonik. |
Joined: Nov 23, 2015 Posts: 1319 Location: Netherlands
Posted: Mon Jan 09, 2017 3:43 pm Post subject:
I just saw this part of the citcuit and I noticed that the switch S1 is connected wrong in this picture: the switch is drawn in rest position indicated by the small arrow in the pushbutton, but in this position (NC) the way it is connected the Reset pulse coming into connector J2 will have no effect since R1 is at +15V level.
So the resistor R1 should be connected to the other now unconnected pin of the switch S1 being the normally open (NO) connection of the switch.
I thought this might be helpfull for any diy-er who likes to build this module.
Other than this nothing but kudos for Fonik  |
wahee
Posted: Mon Jan 31, 2022 1:17 pm Post subject:
clock divisions and the original clock coming through |
hi bit of a post revival
my device seems to have an issue when using clock or low frequency notes. The original clock is also present in the output signal as well as the division. Like a sort of distortion alternating with the main output. Any idea of what could be wrong. I have built it right as far as I can tell. I have tried various brands of 4024 but they're all the same. Possibly the 4069?
cheers |
