My Simple Clock Divider
Page 3 of 3 [64 Posts]
Goto page: Previous 1, 2, 3
cablebasher
PostPosted: Tue Mar 18, 2014 2:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey, just wondering if any PCBs were ever made for this module and if so, are they for sale. Could really use one in my euro setup.
If not, does anyone have any photos of breadboards or perfboards of the circuit that I could use for reference.
Following schematics was never my strong point.
Thanks.
PostPosted: Tue Mar 18, 2014 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
not yet. just my prototypes, however, i could revive this project. and offer eurorack front panels as well.
fonitronik at
LFLab
PostPosted: Wed Mar 19, 2014 3:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Made one on perfboard, quite simple. But my perfboard layouts are done on the fly, and are hardly exemplary!
cablebasher
PostPosted: Fri Mar 21, 2014 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I would definitely buy a PCB and panel if an order was placed.
If not, a breadboard or perfboard photo would be great for reference to build my own.
Cheers.
philoop
PostPosted: Sat Mar 22, 2014 7:55 am    Post subject: clock divider Reply with quote  Mark this post and the followings unread
hallo fonik! i got some spare cd 4020....could i extend the resoulution to 64 128 256? and how?
Deploying dual-wavelength fNIRS, we interrogate 16 locations in the forehead when eight able-bodied adults perform deception and truth-telling scenarios separately.
roglok
PostPosted: Fri Mar 28, 2014 4:52 am    Post subject: Reply with quote  Mark this post and the followings unread
matthias, i have a working stripboard layout for your divider (thanks for sharing!). are you OK with me posting the layout here?
PostPosted: Fri Mar 28, 2014 7:39 am    Post subject: Re: clock divider Reply with quote  Mark this post and the followings unread
shure. one could even add an additional switch to select certain divisions. however, the 4020 is not pin compatible...
BTW the inverters are not needed, they are just my appreoach/idea to divisions.
fonitronik at
PostPosted: Fri Mar 28, 2014 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
go ahead. this is the DIY forum Very Happy
fonitronik at
roglok
PostPosted: Fri Mar 28, 2014 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
kewl! here goes!
fonik_divider_2.pdf
 Filename:  fonik_divider_2.pdf
 Filesize:  841.69 KB
 Downloaded:  491 Time(s)
roglok
PostPosted: Fri Mar 28, 2014 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
it's been a while since i've done this one, so it's not as compact as my newer layouts, but unless you are building a tight skiff, it should work...
acidblue
PostPosted: Mon Jan 09, 2017 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Forgive me for asking a stupid question in an old thread.
But what is the 4069 for?
Couldn't you take the signal from the 4024 into the transistors??
PostPosted: Mon Jan 09, 2017 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
you could. i use the 4069 inverters to invert the logic.
a normal divider goes to all OFF when receiving a reset, mine goes to all ON.
you may want to have both options?
fonitronik at
acidblue
PostPosted: Mon Jan 09, 2017 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ohhhh, pretty clever of you.
Thanks Fonik.
Audio files: 19
PostPosted: Mon Jan 09, 2017 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just saw this part of the citcuit and I noticed that the switch S1 is connected wrong in this picture: the switch is drawn in rest position indicated by the small arrow in the pushbutton, but in this position (NC) the way it is connected the Reset pulse coming into connector J2 will have no effect since R1 is at +15V level.
So the resistor R1 should be connected to the other now unconnected pin of the switch S1 being the normally open (NO) connection of the switch.
I thought this might be helpfull for any diy-er who likes to build this module.
Other than this nothing but kudos for Fonik Very Happy
