richard s
Posted: Thu May 12, 2005 3:12 pm Post subject:
G2 midi auto assigment is crap? |
I'm disappointed to report that the G2 automatic midi assignment is a mess and doesn't make much sense.
Or are others using it successfully?????
On some patches I find it will start 3 4 6 8 then go to 10 12 etc, on another it will go 2 3 5 6 8 9 and so on. It will even use different controllers on the same patch at different attempts. It doesn't seem to have much relationship to whether or not controllers are already used. For example I associated cc2 with a morph group to stop the auto assign using it but sometimes it uses it anyway... there is no way I can rationally plan a midi control surface around it.
so I can't see any coherant use for this feature - unless I can control exactly which assignments (basically those I already assigned to my doepfer) it will use. Ultimately I repeat my request for a fully configurable midi map in which the user not Clavia says what CC80, cc19 etc are associated with...
the current system is an ugly compromise and the auto-bit errmmm doesn't work properly. Unless somebody knows better?
Richard |
Joined: Jan 31, 2003 Posts: 18198 Location: Durham, NC
Audio files: 213
Posted: Thu May 12, 2005 3:31 pm Post subject:
I have tried to use the MIDI auto assign feature. Unfortunately, I have to concur with your observations. This feature could be very powerful, but it would take a lot of development. I think it is there as a quick convenience and as such is useful, or at least better than nothing. _________________ --Howard
my music and other stuff |
Afro88
Joined: Jun 20, 2004 Posts: 701 Location: Brisbane, Australia
Audio files: 12
G2 patch files: 79
Posted: Thu May 12, 2005 4:21 pm Post subject:
Yeah it sucks . The big problem is the way it assigns the buttons for knobs. It goes through and assigns the knob, then the associated button (for example osc pitch and pitch type), and if the knob has no associated button it will go to the next midi cc number for the next knob instead of skipping it. You could get it to work predictably if it would map out the midi cc's to go knob, button, knob, button etc., and then if a function it was mapping didn't have a knob or button, it would leave that knob or button unassigned and move to the next. That way everything stays in order and things don't go weird the way Richard described.
Hmmm, I'm not sure if that makes sense, so I'll do a quick diagram...
Osc Pitch [knob] 2
Osc Pitch type [button] 3
Osc Fine [knob] 4
Osc KBT [button] 6
Osc Wave [knob] 8
Osc Shape [knob] 10
This is how the G2 currently assigns midi to these functions. The reason why it skips some cc's is because it only uses cc's that aren't already being used for other things (like mod wheel which is usually cc 1 for example). The way it should work is this:
Osc Pitch [knob] 2
Osc Fine [knob] 4
Osc KBT [button] 6
Osc Wave [knob] 8
unused [button] 10
Osc Shape [knob] 12
unused [button] 13
That way, if you have your controller mapped out so each knob has it's own button, and the button is assigned to the next available cc from it's associated knob, you can get predictable, usable assignments. This would make things a hell of alot better for us engine/controller users. |
Jason
Joined: Aug 12, 2004 Posts: 466 Location: Los Angeles, CA. USA
Posted: Thu May 12, 2005 8:59 pm Post subject:
Please excuse my confusion but are we talking about the G2 keyboard or engine? Or does that not make a difference?
I assign midi stuff manually in the editor to my controller.
I am using the engine.
I wish this had a midi learn function like some soft synths , that is another topic though. I want to understand this issue more.
Thanks |
Afro88
Audio files: 12
G2 patch files: 79
Posted: Thu May 12, 2005 10:14 pm Post subject:
This is applicable with either one. If you go into parameter overview in the tools menu, there's a "assign midi" function which automatically assigns controllers to anything that has been assigned to the G2 front panel.
I'm not sure if this is what you're asking for, but there is a learn function for assigning midi. Just select the knob/button you want to learn midi for, turn the knob/press the button on your controller and then press the L key. Done!
I usually manually assign midi too with the learn function, but it would be handy when trying out other people's patches to be able to quickly assign the midi in one go in a straight forward and predictable way. Actually, if the auto assign worked properly I'd probably end up assigning functions to the software g2 panel first and then use the auto midi function with my own patches. It would make things really easy because the BCR's and the G2's knobs are in groups of 8 (so are many controllers), so it would be nice to visually see where everything could go first, then assign it all to midi in one go. |
Jason
Posted: Thu May 12, 2005 10:49 pm Post subject:
Wow , I can not believe I over looked that learn function.
Anyway, now I understand this and thank you very much.
rnp
Posted: Fri May 13, 2005 1:04 am Post subject:
wow, I overlooked this too.. I never imagined this would be a feature in the first place, got used to doing cc assignments manually (and the interface for that is crappy already). pity it doesn't work properly, might just as well forget it exists again. _________________ http://www.regicide.org
deer music
offering temporary solutions |
Audio files: 213
Posted: Fri May 13, 2005 5:58 am Post subject:
How's this for an idea on improving the auto-design. It should just be consistent. For every knob and button on the paramater pages there should be a corresponding CC that is used no matter whether there is a knob assigned there or not. That A1/knob1 is always CC2 (or whatever), E3/knob8 is always CC111 (or whatever). That way, when you assign a knob to a particular knob, it would almost automatically be associated with a particular CC. Then you could program up your MIDI controllers with only one preset to take over controlling the G2. This would make the MIDI auto-assign work in a logical and predictable manner.
There would be the case where you had already manually assigned a function on the parameter pages to a CC. I'd say, if you do this, then don't use the auto-assign else it will be reassigned. _________________ --Howard
Afro88
Audio files: 12
G2 patch files: 79
Posted: Fri May 13, 2005 5:04 pm Post subject:
That's a great idea Mosc. That'll make it so easy: every patch that has stuff assigned to the parameter pages is able to be controlled right off the bat. And people with fixed cc controllers can still assign knobs and stuff manually. That's one for the wishlist...
Done: http://www.electro-music.com/forum/topic-6391.html |
Audio files: 213
Posted: Fri May 13, 2005 6:53 pm Post subject:
Thanks, Kid. I think I could have explained it better, but I'm glad you got the gist of it.
Wait, you changed your username!
Very confusing, but I hope you feel better with the new identity. Thanks for not changing the avatar at the same time. _________________ --Howard
Afro88
Audio files: 12
G2 patch files: 79
Posted: Fri May 13, 2005 7:02 pm Post subject:
mosc wrote: | Thanks, Kid. I think I could have explained it better, but I'm glad you got the gist of it.
Very confusing, but I hope you feel better with the new identity. Thanks for not changing the avatar at the same time. |
Haha, yeah, this is my usual username. I think when I joined electro-music I was having an identity crisis
Actually, I think I liked that name at the time and grew tired of it a week later. I only realised you could change your username on these forums recently, so I reverted back to the old Afro88, which I'm more comfortable with. I was considering changing it to "mosc v2" or "Red Hell" or something for a day as a joke but thought better of it |
Audio files: 213
Posted: Fri May 13, 2005 7:04 pm Post subject:
Most forums don't allow the changing of usernames. Now I see why! _________________ --Howard
