wheely
Posted: Tue Oct 16, 2012 4:09 am Post subject:
M audio finger trigger |
Hi, does anyone know if i can replace the slider and nobs of my finger trigger with better ones?
If yes, what kind and where can i get them in the UK?
thanks in advance. |
telbonic
Posted: Mon Oct 29, 2012 2:36 am Post subject:
Re: M audio finger trigger |
wheely wrote: | Hi, does anyone know if i can replace the slider and nobs of my finger trigger with better ones?
What's wrong with the ones you have - are they faulty? Do they stick? What kind of knobs and sliders are in there already? How are they mounted? On the circuit board or on the front panel?
Of course even then I've made an assumption - do you mean the potentiometers themselves or the plastic bits that fit onto them?
Give us some more info!  |
wheely
Posted: Mon Oct 29, 2012 3:18 pm Post subject:
ok ok clever clogs, you got me..
the sliders and nobs as in the potentiometers, and not the plastic bits or id have said plastic bits. We all know u can to take the plastic bits off and replace them, we all did that as kids remember.
notice im asking a question about the finger trigger, if i knew loads about electronics id know all about the type of components in it, and where to find the relevant information......
but i don't, so im asking.
some of the nobs (pots) are faulty, and sliders, are just shit quality, and i use this alot for gigging.
thanks |
telbonic
Posted: Tue Oct 30, 2012 12:21 pm Post subject:
wheely wrote: | notice im asking a question about the finger trigger, if i knew loads about electronics id know all about the type of components in it, and where to find the relevant information...... |
I haven't got a clue what's in the trigger finger, but as you've got one, you could always open it up and take a look.
The pots and sliders should have some values printed on them which will give you a clue - googling "potentiometer values" gives a nice spot to start reading:
http://sound.westhost.com/pots.htm
Once you have thier values it's a lot easier to start finding replacements. The shape/size, mounting, shaft size, taper and so on are all things you may have to check on to find the right parts.
Take your time - it's a nice first project if you're totally new to electronics. |
wheely
Posted: Tue Oct 30, 2012 12:41 pm Post subject:
Thanks man, ill check that out.
finger trigger is just a midi drum pad unit from maudio with some cheap pots and sliders.
thanks for the info. |
dshay
Posted: Tue Jul 14, 2015 8:01 pm Post subject:
wheely wrote: | Thanks man, ill check that out.
I'm pretty good at sourcing components, if you give me the throw in millimeters and a picture of the leads for spacing and the ohms resistance on the linear pots I might be able to source that. Panasonic was used in a lot of this kind of equipment. |
wheely
Posted: Wed Jul 15, 2015 2:10 am Post subject:
Thank dshay!, however the unit is long gone and replaced. thanks tho. |
