| Is there an interest in Super Controller PCBs? |
| Yes, by all means. |
95% |
[ 23 ] |
| No, it just doesn't cut the mustard, i think. |
0% |
[ 0 ] |
| I don't know. I mean, i... er... |
4% |
[ 1 ] |
| Total Votes : 24 |
Posted: Mon Apr 16, 2007 4:50 am Post subject:
Thomas Henry's SN76477 Super Controller Module Subject description: PCBs are SOLD OUT |
hi all,
there was a lot of talk about the SN76477 lately and there are a lots these ICs waiting for salvation, i guess.
i got thomas henry's permission to do a PCB run for his Super Controller design, published in "polyphony" and his book "build a better music synthesizer" (many thanks to our broadminded mr henry!).
boards are now available. the PCBoards size is 4.65x3.1in (118x79mm) and provides +5V onboard source and MTA.100 connectors for almost all switches, potentiometers & sockets. it will take both wide and narrow body ICs.
all who placed an advance-order will have received a PM now. if you changed your mind PM me to cancel your advance-order, please!
EDIT: documentation uploaded. hope that's sufficient. if not, comment please.
documentation r3
prices:
PCB 18.-USD/13EUR each
1x S&H 7.-USD worldwide/3EUR europe
SOLD OUT
It utilizes the SN76477 to build a versatile CV source unit:
one gated/delayed LFO (with hold function!) providing triangle and square, trigger and gate outputs.
one noise source with selectable frequency range and sweep
one sample & hold with portamento and attenuation
a great companion to the SN76477 Voice!?
short description:
there is the LFO section to the left. you will choose mode of operation with a switch selecting delay, gate or switch. in delay mode the LFO will start when triggered depending on the delay time - so you can create delayed modulation. in gate mode the lfo is alway on until you plug a cord in (switching jack socket). from now on the LFO is on when a gate signal is present. in switch mode you can perform a "hold". the LFO stops as soon as you close the connected (foot?)switch. a status LED above the mode selector indicates the LFO working. there is a selector for the LFO range, a rate control and a LED indicating the speed of the LFO. there are four outputs: triangle and square wave, the gate and the trigger outputs a derived from the LFO. the gate is derived from the square wave output but going from 0V to approx 10V (or whatever, depending on a resistor value). the trigger is derived from the triangle and delivers a 1ms pulse. don't forget: the output is gateable or controlled by delay or switch!
the S/H section in the middle: the S/H is clocked from the LFO trigger and provides a portamento (lag) and depth control.
the noise section is to the right: the frequency range of the noise source is selectable by a switch. furthermore there is a filter control (known from the SN voice) and a attenuated cv in for the sweep, which base is set by the initial control. you can select external or internal (LFO) sweep modulation.
hope i got it right.
The Alison Project
Posted: Mon Apr 16, 2007 6:10 am Post subject:
I'll take two
Chris |
andrewF
Posted: Mon Apr 16, 2007 6:25 am Post subject:
two for me too
cheers |
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Mon Apr 16, 2007 6:35 am Post subject:
I'm in  |
fluxmonkey
Posted: Mon Apr 16, 2007 7:05 am Post subject:
i'd be up for one, please...
b |
krisp14u
Posted: Mon Apr 16, 2007 9:28 am Post subject:
I got a copy of that book 2 weeks ago and was thinking a Super Controller would make a nice addition to the modular
put me down for 2  |
alfiollett
Posted: Mon Apr 16, 2007 11:42 am Post subject:
| I'm interested in one |
bubblechamber
Posted: Mon Apr 16, 2007 12:26 pm Post subject:
| i'll take at least 1 |
bugbrand
Posted: Mon Apr 16, 2007 2:08 pm Post subject:
OMG!!!!
Another board?!?!?
Will someone do a board for the Paia Ribbon controller? They seem to have 'dropped' that project
I suppose I should say YES, but I've still got to pay for the last one  _________________ ACHTUNG!
goodrevdoc
Joined: Sep 11, 2006 Posts: 288 Location: Philadelphia, PA
Posted: Mon Apr 16, 2007 3:23 pm Post subject:
Can't say I'm not interested, but my sole SN is taking up residence in me SN-voice. Also I have only heard about the supercontroller, never having seen the documentation for it. Posting it here or anywhere is out of the question, but maybe a panel mock-up could display the general idea, beyond Fonik's description. Just 2 cents in the pot...
-justin |
Posted: Mon Apr 16, 2007 3:34 pm Post subject:
I wouldn't mind seeing the Supercontroller mk2- which doesn't contain an SN  _________________ ACHTUNG!
Posted: Mon Apr 16, 2007 3:43 pm Post subject:
Sure, I will take 2 for myself !!
Thanks !!!
Bill |
ickystay
Posted: Mon Apr 16, 2007 5:42 pm Post subject:
I'm interested!
Can you design with something other than the 4136? I loved your resonator board, but wonder if there could be wider cap spacing to fit little AVX box caps.
No big deal as 4136's are still around and I have a variety of caps. Just a thought...
Edit- Something onboard to regulate +5vdc off the +15 rail would be cool. Last edited by ickystay on Tue Apr 17, 2007 4:10 pm; edited 2 times in total |
shawn
Posted: Mon Apr 16, 2007 6:14 pm Post subject:
| I'd consider 2 boards. |
Thomas Henry
Joined: Mar 25, 2007 Posts: 298 Location: Southern Minnesota
Posted: Mon Apr 16, 2007 7:58 pm Post subject:
Re: Thomas Henry's SN76477 Super Controller Subject description: is there an interest in professional manufactured PCBs? |
| fonik wrote: | hi all,
Matthias makes an interesting point here. Just imagine if we lived in the halcyon days of cheap SN76477 chips at Radio Shack again. With a pair of these and not too many extra parts we could have come up with a very complete synth voice on an extremely small foot print. Apart from the missing VCF, such a combination would have been the equivalent of the Octave Plateau Kitten synth whose PCB was easily 10 times as big! I'm not kidding, either, having ripping into those those things quite a bit to tweak and tune them. |
Thomas Henry
Posted: Mon Apr 16, 2007 8:04 pm Post subject:
| goodrevdoc wrote: | Can't say I'm not interested, but my sole SN is taking up residence in me SN-voice. Also I have only heard about the supercontroller, never having seen the documentation for it. Posting it here or anywhere is out of the question, but maybe a panel mock-up could display the general idea, beyond Fonik's description. Just 2 cents in the pot...
-justin |
Actually, it's not out of the question. As I've mentioned before, a person need only ask and I almost always give permission (unless I'm planning on doing something with the circuit myself).
So, if someone actually asks me if it's okay to post SuperController stuff, I'll probably say yes, as long as it doesn't conflict with Matthias's plans to run off a PCB and cut into his hard work designing it. |
chonald
Joined: May 17, 2006 Posts: 63 Location: des moines, iowa, usa
Posted: Tue Apr 17, 2007 12:03 am Post subject:
| I would like one or two. |
Posted: Tue Apr 17, 2007 1:49 am Post subject:
| Thomas Henry wrote: |
As the DIY moderator at electro-music.com, I grant you full permission to post your SuperController stuff
I'm sure the kind folks here would be more than pleased Thomas
(I'll also okay it with Mosc- seeing that this is his forum) _________________ ACHTUNG!
Scott Stites
Audio files: 96
Posted: Tue Apr 17, 2007 6:28 am Post subject:
| Quote: | | Apart from the missing VCF, such a combination would have been the equivalent of the Octave Plateau Kitten synth |
I would be willing to bet the missing VCF would be another small footprint hiding up the sleeve of Thomas Henry
Put me down for one, Matthias.
Scott |
Wild Zebra
Posted: Tue Apr 17, 2007 8:04 am Post subject:
| Quote: | | Will someone do a board for the Paia Ribbon controller? They seem to have 'dropped' that project | Yeh thated be cool it's too bad they don't have a kit
I voted but didn't post. So yeh, and I still need to muster up some scratch for a resonator pcb _________________ "your stripes are killer bro" |
Posted: Tue Apr 17, 2007 9:00 am Post subject:
(I'll also okay it with Mosc- seeing that this is his forum) |
Great guys !!! Thanks !
Bill |
Thomas Henry
Posted: Tue Apr 17, 2007 6:16 pm Post subject:
| v-un-v wrote: |
I'm sure the kind folks here would be more than pleased Thomas |
Well, actually, I don't have any SuperController stuff anymore. What I was getting at is that if anyone wants to post what they have here, it wouldn't bother me. The main thing is, don't post anything that would interfere with Matthias being able to make a PCB run worth his while.
Thomas Henry |
CJ Miller
Posted: Thu Apr 19, 2007 2:21 am Post subject:
Wow, Thomas Henry's SN76477 frenzy continues!
Please do put me down for two PCBs.
A couple of suggestions - pads for both the regular DIP and shrink-DIP versions of the 76477 would be very helpful, most of only have one or the other. Also, replacing the 4136 with an op amp using a more standard TL074 type pinout would help most people out.
Huge respect and gratitude to Thomas and Matthias! |
Posted: Thu Apr 19, 2007 4:34 am Post subject:
EDIT:
info moved to 1st post... _________________
Tech Buddy at Random*Source Last edited by fonik on Fri Apr 20, 2007 2:19 am; edited 1 time in total |
