<on air> Various Artists September equinox Concert
5-channel Attenuverting Mixer 2nd run
Page 1 of 9 [214 Posts]
Goto page: 1, 2, 3, ..., 7, 8, 9 Next
PostPosted: Sun Jul 13, 2008 5:28 am    Post subject: 5-channel Attenuverting Mixer 2nd run
Subject description: SOLD OUT (28 NOV 08)
since i got some request for a 2nd run lately i decided to do a 2nd run of these PCBs. i got enough advance orders to let it happen now.
SOLD OUT - 28 NOV 08
i am taking advance orders. i am not taking money until the PCBs arrived from manufacturer and i found them to be okay...
i will order the PCBs from manufacturer on 1 AUG 08. so there will be time left to place an advance order for those who are currently on vacation. the PCBs should be available on 14 AUG 08 then. hope that's okay for all involved?
original thread
Recommendations for PCB offers on electro-music.com
this is an attenuverting mixer. one attenuverter for each input. all attenuverted signals where summed, as long as the appropriate single output is not used (switching jack sockets). the summed signal is switchable from AC to DC. in AC mode the summed signal goes goes thru a cap. in DC mode the the cap is bypassed and the signal is also routed to a LED driver indicating the positive or negative parts of the signal.
this is an easy to build project, no obsolete, expensive or hard to find parts.
so here is the updated documentation for the 2nd run (v3):
Attenuverting Mixer Rev2
pricing (paypal preferred):
europe
9.-EUR each PCB
+1x p&p 3.-EUR (2.50EUR germany)
worldwide
13.-USD each PCB
+1x p&p 7.-USD
PCB preview 1st run:
Posted Image, might have been reduced in size. Click Image to view fullscreen..
PostPosted: Sun Jul 13, 2008 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
if you are interested, post your call here, or PM. i will use the 1st post of this thread to update pricing (if necessary) and documentation and such...
mistercooper
PostPosted: Sun Jul 13, 2008 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm most likely down for a pair.
sduck
PostPosted: Sun Jul 13, 2008 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd like a pair of these boards - I already posted this on the other thread, not sure if I need to double post it or not, so here it is again.
Peake
PostPosted: Sun Jul 13, 2008 7:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Four, please. Thanks!
ericcoleridge
PostPosted: Sun Jul 13, 2008 7:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll go in for 2, please. would probably take more also, if they could be available for a while...
mono-poly
PostPosted: Mon Jul 14, 2008 2:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Already posted in the other tread but may do it hear as well.
I'll take 4 off these.
ericcoleridge
PostPosted: Mon Jul 14, 2008 7:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I posted for 2, but I'd like to reserve 2 more. So, 4 total. Thanks
ericcoleridge
PostPosted: Mon Jul 14, 2008 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also, does anyone here have a link handy for the center tapped pots that could be used in this circuit?
insider
PostPosted: Mon Jul 14, 2008 9:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
2 for me.
Thank you Fonik for this 2nd run Smile
PostPosted: Tue Jul 15, 2008 3:53 am    Post subject: Reply with quote  Mark this post and the followings unread
alpha 16mm potentiometer center detend 50k, mouser part # 313-2000F-50K
(...2000F... is for center detend)
scriptstyle
PostPosted: Tue Jul 15, 2008 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
2 for me also, but you already know this from the other thread!!!
cliq
PostPosted: Tue Jul 15, 2008 7:08 am    Post subject: Reply with quote  Mark this post and the followings unread
i am in for 4 pcbs...
a.b.o.z.
G2 patch files: 4
PostPosted: Tue Jul 15, 2008 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
to be on a safe side me too
Photon
PostPosted: Wed Jul 16, 2008 5:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Great! I'll take 2.
panele
PostPosted: Wed Jul 16, 2008 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
i`ll take two Very Happy
PostPosted: Wed Jul 16, 2008 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
ei gude wie?
we are at 46 so far. so the 2nd run should happen, i think Very Happy
philpeery
PostPosted: Wed Jul 16, 2008 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Fonik,
Glad to see there's another chance to get these, I have been interested in them since your first run! I'll push it over the top, put me down for 4, most definitely!
Regards,
Phil
PostPosted: Thu Jul 17, 2008 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
great phil, thank you very much.
i am taking orders until 1 AUG 08, 12:00 UTC
i will order the PCBs from manufacturer on 1 AUG 08. so there will be two weeks left to place an advance order for those who are currently on vacation. the PCBs should be available on 14 AUG 08 then. hope that's okay for all involved?
a.b.o.z.
G2 patch files: 4
PostPosted: Thu Jul 17, 2008 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah thats very much ok,
thnx M.
Danno Gee Ray
PostPosted: Thu Jul 17, 2008 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Works for me. Thank you Matthias.
panele
PostPosted: Fri Jul 18, 2008 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
ei gude wie?
prima, resonator funzt auch, hab zwar wenig zeit aber bischen diy kann man immer mal zwischenschieben, also zweimal bitte Wink
a_guy_called_tom
PostPosted: Tue Jul 22, 2008 12:21 am    Post subject: Reply with quote  Mark this post and the followings unread
i'm very interested, but my setup is +-12v. Do you think this circuit works with 12v and will it fit into an eurorack?
PostPosted: Tue Jul 22, 2008 12:27 am    Post subject: Reply with quote  Mark this post and the followings unread
no problem at all. you won't have to change anything!
the PCB itself is rather small (3.8 x 2.3) and will fit into eurorack quite well. BTW i am using eurorack myself Very Happy
a_guy_called_tom
PostPosted: Tue Jul 22, 2008 12:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Great! Count me in for 2 then, please! Good to know that your designs can be used in eurorack, there are some others which are on my wishlist Smile
