V/Hz state variable filter
Page 1 of 1 [12 Posts]
nicolas3141
PostPosted: Tue May 19, 2009 4:06 am    Post subject: V/Hz state variable filter Reply with quote  Mark this post and the followings unread
Here is a filter to match the VCO http://electro-music.com/forum/topic-32689.html and ribbon controller http://electro-music.com/forum/topic-32651.html
This circuit is pretty much the standard state variable design from the LM13600 datasheet, but with a Q pot and diode clippers added that allows it to oscillate reliably so that it can be used a sine VCO as well as a filter. It has bandpass and lowpass outs.
A fairly basic circuit that sounds okay and is simple enough to understand and be built in a couple of hours on stripboard. It runs off +/-9V (ie two batteries). It expects a CV in the 0-6V range. The output is about a volt or so which won't blow anything up if you run it directly into effects pedals, etc.
It is V/Hz which means that if you set it up to give you C at 1V, you should get C an octave higher at about 2V and an octave higher again at about 4V.
I built mine last year, but have only finished tidying up the drawing, so if you notice anything amiss, please let me know.
Nicolas
 Filesize:  204.98 KB
 Viewed:  1816 Time(s)
drapdap
PostPosted: Tue May 19, 2009 4:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank You for sharing this Nicolas, these circuits are really nice work.
I haven't got round to building any of them yet, but this filter was the last straw, im gathering parts now...
i'm not shure i understand the +6v switch on the input tho. Is it just to boost the signal so the resonance behaves well?
Does it tolerate +/- 12 volts, or do i need to raise some resistors?
(Of course i'll try it, but a firsthand answer really won't hurt my ego.)
is there more of these? Smile
thank you a gain
róbert
nicolas3141
PostPosted: Tue May 19, 2009 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
That switch to +6V is my crude way of showing a switched socket that sees +6V when nothing is attached. It doesn't really need to be +6V, any stable +ve voltage would be fine.
To run it on higher voltage up to +/-15V should be fine, but increase the value of R4, R15 and R17 proportionally (say 6k, 14k and 14k or similar).
Nicolas
loss1234
PostPosted: Sun May 31, 2009 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks so much for these great circuits!!!
Dego
PostPosted: Thu Jun 11, 2009 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Built the filter today. But ran in to some problems.
The q pot does not work properly Sad
It just work a little bit of the pots axel. I use a 100k pot just like in the schematics but should it be 10k?
What could else be wrong?
nicolas3141
PostPosted: Thu Jun 11, 2009 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am not quite sure what you mean. When I turn the Q pot to 100% my filter rings (oscillates if there is no input). If I back it off a bit to around 70-90% the filter has that resonant wah type sound. Then as I turn it down further it loses the resonance and becomes more like a tone control type filter. Between 0-70% the changes in the sound of the filter are not very dramatic.
Perhaps a log pot would be better here so that we could get better control over the high resonance end and waste less rotation on the low resonance end.
This general type of filter is quite common, but what distinguishes one from the next is the feedback arrangement to provide Q control. So I encourage you to experiment with different pots and types of feedback. Let us know what you find that works.
Nicolas
Dego
PostPosted: Sun Jun 14, 2009 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
It works now. I have the same result when I turn the Q pot now. I think that was what puzzled me was that there was not much action until you get to 70% turned Q pot. After 90 it goes crazy... Smile
I will try later on with a log pot....
So that is number 4 of your designs Very Happy
ADSR
LFO
VC-LFO
FILTER
Now I look forward to the Sample & Hold and VCA. Is there a ringmodulation as well? Wink
Thanks for your educational and fun designs!
ogg
PostPosted: Thu Oct 01, 2009 5:23 pm    Post subject: Filter simulation online Reply with quote  Mark this post and the followings unread
Hello, I've put an interactive simulation of this filter online at Music circuit simulations. It seems to be working but not entirely, I'm not sure which input is which and I don't think I have the op-amp voltages right. Thought you might like to see it, please send me corrections if you can see any mistakes.
I've credited you, nicolas3141, and linked to this discussion.
Ollie
PostPosted: Fri Oct 02, 2009 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Ollie! welcome to electro-music.com! Very Happy
I'm afraid this isn't working here (Safari on a MacIntel running OSX). Says it can't read a text file- although I'm getting a screen. A black screen I should add Smile
ACHTUNG!
Audio files: 116
G2 patch files: 317
PostPosted: Fri Oct 02, 2009 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm .. but it does here ... you have an old Java version?
ogg
PostPosted: Fri Oct 02, 2009 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Smile
Occasionally I find the applet doesn't start properly and shows a black screen, usually when I click or right-click on it before it's finished setting up. So you might like to try refreshing, or as Blue Hell suggests you could check you have the latest version of Java, the OS X software update should show you if you don't.
nicolas3141
PostPosted: Mon Apr 12, 2010 3:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Dego
one more uploaded. Sorry for the delay, but it has been summer down here and I have not been indoors so much Smile
http://electro-music.com/forum/topic-41277.html
Nicolas
