110-115V to 220-230V or visa versa
Page 4 of 4 [76 Posts]
arneyz
PostPosted: Sat May 28, 2016 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have a 230V Nord Lead 2 that I'd like to convert to 120V and I just need some clarification.
The OP made it sound like to make the board 120V compatible you need to connect the two terminals labeled "110" but in kiwibirch's photo it appears the 110V jumpers are connected to both of the 220V terminals. Is this what I should do?
Also, would it be possible to simply replace the power supply for a newer one (from a NL2X) with the switch?
Thanks
