today> Various Artists September equinox Concert
Changing the slope of pot movement on the A6 filters
Page 1 of 1 [7 Posts]
davros303
PostPosted: Sun Oct 25, 2015 3:31 am    Post subject: Changing the slope of pot movement on the A6 filters Reply with quote  Mark this post and the followings unread
Hi all,
Is there a way to change the slope of the pot movement on the Andy's filters? I find the sweet spot is typically in quite a small range of movement on each pot, so tracking subtle filter changes over time is sometimes a challenge by hand. I know there's loads of slope control for the envelopes and portamento, and I couldn't find any reference to this in the manual.
davros303
PostPosted: Mon Oct 26, 2015 2:48 pm    Post subject: Improving filter sweep range - from the tips and tricks Reply with quote  Mark this post and the followings unread
Found it, here's an extract from the awesome tips and tricks document... The more I learn the more I love this synth.
FILTER SWEEP RANGE:
One thing that is different about the Andromeda, compared to some synthesizers, is that the filters have a very high range. This means that it is possible to have the filters “sweep” in a way where only part of the knob is useful.
When doing patches that involve filter FM, you may find that high range useful. But, in other situations, having a high range is more of an annoyance, especially when modulating the cutoff realtime.
To change this, simply click “View” in the desired filter window. Then, adjust the “Offset” of the filter (soft knob 5) downward. Then adjust the filter cutoff frequency back to a desireable level. This will allow you to control the degree of how much you want to sweep the filters.
sunny pedaal
Audio files: 12
PostPosted: Sat Oct 31, 2015 3:04 am    Post subject: Reply with quote  Mark this post and the followings unread
lots of places to adjust offsets, i use it as a kind of second nature all the time
one of the great things on the a6
Daveyp
PostPosted: Thu Mar 02, 2017 8:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just got an A6 and this behavior drives me crazy. The useable range of filter 2 is like the bottom 10% of the knob's travel. Could somebody explain why Filter 2 would need to go to 48 KHz? It doesn't seem to me you'd ever be able to hear anything over 30 K, so why bother? Am I just dense?
sunny pedaal
Audio files: 12
PostPosted: Thu Mar 02, 2017 11:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Adjust one of the OFFSETs to find a more pleasing working range
On my roland sys 100 the filterrange goes to 100000hz, some pipeorgans go even higher which b.e. Makes audible notes by the interference/ difference in unaudible frequencies. Its a feature, don't see the problem (specially not when the working-range of the pots can be adjusted to your likening ...)
deleted user on request
PostPosted: Mon May 15, 2017 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
One thing to remember is that the A6's INIT patch is programmed with over 63% ENV2 modulation on Filter 2. Filter 1 is set to 100% by default! When I start a new patch the first thing I do is remove the envelope send to the filter. The default setting gives you terrible range for the cutoff, 10% of the knob as mentioned in the OP. Turning ENV2 modulation down to 0 gives you much wider range with the filter knob, closer to 65%. And of course you can use the offsets as you dial in your envelopes to control the filters' range.
sunny pedaal
Audio files: 12
PostPosted: Wed May 17, 2017 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
good tip !
one more:
make your own default patch as soon as possible , great fun and learning a lot .
ps : i'm on version 4 myself already Smile
