Posted: Sun Jul 13, 2008 5:28 am Post subject:
5-channel Attenuverting Mixer 2nd run Subject description: SOLD OUT (28 NOV 08) |
since i got some request for a 2nd run lately i decided to do a 2nd run of these PCBs. i got enough advance orders to let it happen now.
SOLD OUT - 28 NOV 08
i am taking advance orders. i am not taking money until the PCBs arrived from manufacturer and i found them to be okay...
i will order the PCBs from manufacturer on 1 AUG 08. so there will be time left to place an advance order for those who are currently on vacation. the PCBs should be available on 14 AUG 08 then. hope that's okay for all involved?
original thread
Recommendations for PCB offers on electro-music.com
this is an attenuverting mixer. one attenuverter for each input. all attenuverted signals where summed, as long as the appropriate single output is not used (switching jack sockets). the summed signal is switchable from AC to DC. in AC mode the summed signal goes goes thru a cap. in DC mode the the cap is bypassed and the signal is also routed to a LED driver indicating the positive or negative parts of the signal.
this is an easy to build project, no obsolete, expensive or hard to find parts.
so here is the updated documentation for the 2nd run (v3):
Attenuverting Mixer Rev2
pricing (paypal preferred):
europe
9.-EUR each PCB
+1x p&p 3.-EUR (2.50EUR germany)
worldwide
13.-USD each PCB
+1x p&p 7.-USD
PCB preview 1st run:
. Last edited by fonik on Fri Nov 05, 2010 9:33 am; edited 17 times in total |
Posted: Sun Jul 13, 2008 8:28 am Post subject:
if you are interested, post your call here, or PM. i will use the 1st post of this thread to update pricing (if necessary) and documentation and such... _________________
Tech Buddy at Random*Source |
mistercooper
Posted: Sun Jul 13, 2008 2:37 pm Post subject:
I'm most likely down for a pair. |
sduck
Posted: Sun Jul 13, 2008 5:39 pm Post subject:
I'd like a pair of these boards - I already posted this on the other thread, not sure if I need to double post it or not, so here it is again. |
Peake
Joined: Jun 29, 2007 Posts: 1113 Location: Loss Angeles
Posted: Sun Jul 13, 2008 7:23 pm Post subject:
Four, please. Thanks! |
ericcoleridge
Posted: Sun Jul 13, 2008 7:36 pm Post subject:
I'll go in for 2, please. would probably take more also, if they could be available for a while... |
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Mon Jul 14, 2008 2:56 am Post subject:
Already posted in the other tread but may do it hear as well.
I'll take 4 off these. |
ericcoleridge
Posted: Mon Jul 14, 2008 7:34 pm Post subject:
I posted for 2, but I'd like to reserve 2 more. So, 4 total. Thanks |
ericcoleridge
Posted: Mon Jul 14, 2008 7:35 pm Post subject:
Also, does anyone here have a link handy for the center tapped pots that could be used in this circuit? |
insider
Posted: Mon Jul 14, 2008 9:08 pm Post subject:
2 for me.
Thank you Fonik for this 2nd run  |
Posted: Tue Jul 15, 2008 3:53 am Post subject:
ericcoleridge wrote: | Also, does anyone here have a link handy for the center tapped pots that could be used in this circuit? |
alpha 16mm potentiometer center detend 50k, mouser part # 313-2000F-50K
(...2000F... is for center detend) _________________
scriptstyle
Posted: Tue Jul 15, 2008 7:02 am Post subject:
2 for me also, but you already know this from the other thread!!! |
cliq
Posted: Tue Jul 15, 2008 7:08 am Post subject:
i am in for 4 pcbs... |
a.b.o.z.
Joined: Feb 07, 2007 Posts: 351 Location: Zagreb, Croatia
G2 patch files: 4
Posted: Tue Jul 15, 2008 7:43 am Post subject:
scriptstyle wrote: | 2 for me also, but you already know this from the other thread!!! | to be on a safe side me too |
Photon
Posted: Wed Jul 16, 2008 5:53 am Post subject:
Great! I'll take 2. |
panele
Joined: Apr 13, 2008 Posts: 19 Location: mainz, germany
Posted: Wed Jul 16, 2008 10:44 am Post subject:
i`ll take two  |
Posted: Wed Jul 16, 2008 2:21 pm Post subject:
panele wrote: | i`ll take two  |
ei gude wie?
we are at 46 so far. so the 2nd run should happen, i think  _________________
philpeery
Joined: Nov 08, 2006 Posts: 137 Location: new jersey, usa
Posted: Wed Jul 16, 2008 4:53 pm Post subject:
Hi Fonik,
Glad to see there's another chance to get these, I have been interested in them since your first run! I'll push it over the top, put me down for 4, most definitely!
Regards,
Phil |
Posted: Thu Jul 17, 2008 4:11 am Post subject:
great phil, thank you very much.
i am taking orders until 1 AUG 08, 12:00 UTC
i will order the PCBs from manufacturer on 1 AUG 08. so there will be two weeks left to place an advance order for those who are currently on vacation. the PCBs should be available on 14 AUG 08 then. hope that's okay for all involved? _________________
a.b.o.z.
G2 patch files: 4
Posted: Thu Jul 17, 2008 4:12 am Post subject:
yeah thats very much ok,
thnx M. |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Thu Jul 17, 2008 2:18 pm Post subject:
Works for me. Thank you Matthias. |
panele
Posted: Fri Jul 18, 2008 1:48 pm Post subject:
fonik wrote: | panele wrote: | i`ll take two  |
ei gude wie?
we are at 46 so far. so the 2nd run should happen, i think  |
prima, resonator funzt auch, hab zwar wenig zeit aber bischen diy kann man immer mal zwischenschieben, also zweimal bitte  |
a_guy_called_tom
Posted: Tue Jul 22, 2008 12:21 am Post subject:
i'm very interested, but my setup is +-12v. Do you think this circuit works with 12v and will it fit into an eurorack? |
Posted: Tue Jul 22, 2008 12:27 am Post subject:
a_guy_called_tom wrote: | i'm very interested, but my setup is +-12v. Do you think this circuit works with 12v and will it fit into an eurorack? |
no problem at all. you won't have to change anything!
the PCB itself is rather small (3.8 x 2.3) and will fit into eurorack quite well. BTW i am using eurorack myself  _________________
a_guy_called_tom
Posted: Tue Jul 22, 2008 12:31 am Post subject:
Great! Count me in for 2 then, please! Good to know that your designs can be used in eurorack, there are some others which are on my wishlist  |
