MIDI Channel & CC# selectors should be morph assignable
Page 1 of 1 [5 Posts]
You need it ...
... badly
12%
 12%  [ 1 ]
... very much
12%
 12%  [ 1 ]
... not much
62%
 62%  [ 5 ]
... not at all
12%
 12%  [ 1 ]
Total Votes : 8
Nodular
G2 patch files: 7
PostPosted: Tue May 02, 2006 8:56 am    Post subject: MIDI Channel & CC# selectors should be morph assignable
Subject description: 1 knob to control several NoteSend modules
The Channel selector and the Ctrl (CC#) selector can't be assignable to a morph group.
Why? I really don't understand this.
When I use my NMG2 as a MIDI controller for external stuff I'd really like to change those parameters on a group of NoteSend or CtrlSend modules contemporarily.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue May 16, 2006 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
well, you can do it by using up an extra cc#.
just assign a midi cc# to the ctrlsend cc knob and then add a level knob which is connected to another CtrlSend (which sends midi to this slot, in order move the cc knob). then morph the level knob. i know it sounds confusing (so many cc references) ...
/Dasz
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue May 16, 2006 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
That works with the channel control thanks, but the CC# selector can't have a morph or MIDI CC assigned to it. I know I have wished for this as well, but I can't remember why.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue May 16, 2006 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Doh -- my appologies Embarassed ! I did not have my g2 in front of me to test it.
That is inconsistant. But I guess if you could use a cc to modulate the CC assignment, then the cc send module could potentially be chaning it's own cc# accidentally sometimes.
Another solutn -- Why not use as many cc sends as you think you'll need and use a switch (with morphing) to route the signals to different cc#?
/Dasz
Nodular
G2 patch files: 7
PostPosted: Wed May 17, 2006 2:26 am    Post subject: Reply with quote  Mark this post and the followings unread
dasz wrote:
... Another solutn -- Why not use as many cc sends as you think you'll need and use a switch (with morphing) to route the signals to different cc#?
/Dasz
Thanks for feedback.
Indeed I use switches to easily choose different destinations for all my CC# send modules. But it consumes much memory.
dasz wrote:
... I guess if you could use a cc to modulate the CC assignment, then the cc send module could potentially be chaning it's own cc# accidentally sometimes ...
Now I see the point.
