 Forum index » Clavia Nord Modular » g2ools utilities
Problem with sounds converting
Page 1 of 1 [7 Posts]
radek tymecki
PostPosted: Sun Mar 22, 2009 6:02 pm    Post subject: Problem with sounds converting Reply with quote  Mark this post and the followings unread
Sadly this converter (dx2g2) doesn't work for me... I've tried so many ways but still no result. Can somebody help me please with those?
http://www.sendspace.com/file/ptzpku
Audio files: 297
PostPosted: Sun Mar 22, 2009 6:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome radek.
What is the problem? cant you get the software to work or don't you like the results of the conversion?
The link points to the patches you want to convert?
Did you check out http://electro-music.com/forum/topic-15905.html to see if they are in there already ?
radek tymecki
PostPosted: Mon Mar 23, 2009 1:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello Smile
I've downloaded g2ools and g2gui. Program converted for example factory rom, but no other patches....
simply wrote sth like that [for example]
bell.syx
bell.syx 1 voice
Sad
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Mar 23, 2009 1:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Apart from the factory roms (that have been converted already), the only other 'bank' files are moog and maybeEno.
The others seem to be single patch dumps, which the converter doesn't accept.
I have converted what I can. The others you may be able to load into a dx editor program and save as a single bank file.
dxg2patches.zip
moog and MaybeEno banks (MaybeEno only has 9 patches)
 Filename:  dxg2patches.zip
 Filesize:  24.53 KB
 Downloaded:  894 Time(s)
radek tymecki
PostPosted: Mon Mar 23, 2009 3:46 am    Post subject: Reply with quote  Mark this post and the followings unread
do You know any editor that i can use to make soundbank ald later convert it?
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Mar 23, 2009 5:17 am    Post subject: Reply with quote  Mark this post and the followings unread
There are a few here. Sorry I have not tried the single patch dump feature so cannot recommend anything specific.
radek tymecki
PostPosted: Sat Mar 28, 2009 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK I managed to do it Very Happy
All You have to do is to collect all needed sounds into syx bank.
Program doesn't convert single sounds
