Stereo dance style looper
Page 1 of 1 [5 Posts]
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Thu Jun 02, 2005 5:14 am    Post subject: Stereo dance style looper Reply with quote  Mark this post and the followings unread
This patch loops audio to a specified time at the press of a button. This is how it works:
When the button isn't pressed, audio flows into the delay but isn't recycled, and you don't hear it. When you press the button, audio stops flowing into the delays, the feeback is turned to maximum so it recycles the audio indefinitely and the signal is changed from dry to wet so you can hear it. The time of this loop is selected by the 8-switch on the right. This delayed audio flows through a couple of filters and there is also the option to let some of the dry sub audio through as well.
I've included a little electro loop so you can hear how it works. I think it's a bit of fun to play around with, especially when you have a whole performance running through it Cool
dance looper.pch2
Dance style audio looping patch
 Filename:  dance looper.pch2
 Filesize:  7.88 KB
 Downloaded:  2082 Time(s)
General Elektrick
PostPosted: Thu Jun 02, 2005 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
Hey Afro, I begin to fear for your Uni stuff!
Second Killer Patch in some days!
Thanks for sharing!
Best,
General Elektrick
"If something is boring after two minutes, try it for four. If still boring, then eight. Then sixteen. Then thirty-two. Eventually one discovers that it is not boring at all." --John Cage.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Fri Jun 03, 2005 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks GE - I'm worried too! Laughing
Wan
G2 patch files: 46
PostPosted: Sun Jun 05, 2005 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
How very clever is this Exclamation
I'm gonna experiment with this one further. Thank you.
Grtz Wan
sawtooth
PostPosted: Thu May 31, 2007 1:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Didn't see this before. Brilliant fun! Smile
