aquanaut
Posted: Tue May 04, 2004 11:20 am Post subject:
Microwave XT (before i buy) |
I'm planning to buy this synth. does anybody have experience using it?
i've read on a site that some parameter (osc 1 semitone...) will click when you edit them. is it still the case when the parameter is modulated? |
Mohoyoho
aquanaut
Posted: Wed May 05, 2004 2:24 am Post subject:
| the manual convinced me. sounds like a very flexible synth. i'm gonna try it tommorow but i'm afraid i'm not going to be able to test it properly in the music store. the micro q is an option too. |
Mohoyoho
aquanaut
Posted: Wed May 05, 2004 11:38 am Post subject:
| do you know if the micro q is seamless with program change |
Mohoyoho
aquanaut
Posted: Wed May 05, 2004 1:55 pm Post subject:
| the latency between the command from cubase and the response of the synth. |
Mohoyoho
Posted: Thu May 06, 2004 5:40 am Post subject:
Cubase has some "latency" settings... at least on the mac. You checked in those? As far as I know the XT is not known to be "late"  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
aquanaut
Posted: Thu May 13, 2004 7:56 pm Post subject:
i bought the xt...now i have to reload the factory preset. i have the file from waldorf. do i simply load the file in cubase and press play...sounds to simple.
in list edit i see (F0,3E,0E,00,10,)
Thanks in advance
N[/quote][/b] |
seraph
Editor
Audio files: 33
Posted: Thu May 13, 2004 11:52 pm Post subject:
| niko_91 wrote: | | F0,3E,0E,00,10, |
that's the beginning of a system exclusive message in hexadecimal....that's how it should be Press play and enjoy  _________________ homepage - blog - forum - youtube
| Quote: | | Don't die with your music still in you - Wayne Dyer |
aquanaut
Posted: Fri May 14, 2004 1:40 am Post subject:
how come i don't see the entire message...i moved the column to see if i can enlarge it to see the entire mess...it look incomplete when i wrote the post.
tks
n |
seraph
Editor
Audio files: 33
Posted: Fri May 14, 2004 1:53 am Post subject:
| niko_91 wrote: | | how come i don't see the entire message...i moved the column to see if i can enlarge it to see the entire mess...it look incomplete when i wrote the post. |
those kind of system exclusive messages start with "F0" and end with "F7"
F7 is called EOX (End Of Exclusive). if you see an F7 at the end it means the message is complete, otherwise it could mess up your beloved XT  _________________ homepage - blog - forum - youtube
Mohoyoho
aquanaut
Posted: Fri May 14, 2004 3:37 pm Post subject:
ohh seraph i feel so confident now on another matter...is there a way to edit a wavetable with mac os9? oh and did'nt found the stop levitation button...where is it  |
Norm Vogel
Posted: Fri May 14, 2004 6:09 pm Post subject:
XT |
Hi! IMHO, DEFINITELY buy an XT if you can afford one! (I'm sorry i sold mine).
This synth makes sounds like no other! If you like non-trad sounds, and "something completely different", THIS is the synth to buy!
For a sampling on the kind of way-out sounds it can make, go to my site (below), then onto the "Ambient" page.....listen to "The Scarecrow Flies At Night"......
That's 100% XT!
This synth is destined to become a Classic!
Norm _________________
Normusic !
