bc560b vs bc560c
Page 1 of 1 [2 Posts]
norman phay
PostPosted: Mon Mar 17, 2008 8:30 am    Post subject: bc560b vs bc560c Reply with quote  Mark this post and the followings unread
Hello!
I was soldering components into the K-rock phaser board, when I discovered that the big lot of BC560 transistors I bought are suffixed with a "B" instead of a "C". Checking the triple chorus boards, they're all "B" suffixed as well, and they're all neatly soldered in! Is this likely to have made a difference? I thought I'd bought 560Cs for some reason, grumble grumble.
jhaible
PostPosted: Tue Mar 18, 2008 3:41 pm    Post subject: Re: bc560b vs bc560c Reply with quote  Mark this post and the followings unread
Norman Phay wrote:
Hello!
C types have higher current gain.
In most cases, the B types are more than good enough. I just specify the C type because you can get it for the same price as the B type, and it's closer to "ideal".
JH.
