 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
And it goes on.....
Page 1 of 1 [2 Posts]
benway
PostPosted: Thu Mar 27, 2008 7:19 am    Post subject: And it goes on.....
Subject description: Bugs micro no conection
Hello,
after running a short period without problem, problems appear.
I'm useing the Osx 10.4.11 on PowerPc with hammerfall Dsp and mmj.
Settings show RME Hammerfall but when pushing button micro modular do not pop up :
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:411)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.setConnected(NordModular.java:881)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.trySetConnectedState(SynthObjectForm.java:958)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$1$1.run(SynthObjectForm.java:599)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jnmprotocol2.NmMessageAcceptor.waitForReply(NmMessageAcceptor.java:111)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:400)
... 10 more
gomidas
G2 patch files: 6
PostPosted: Thu Mar 27, 2008 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Connection Timeout?...Did you try to change the midi clock to "EXT" in the MicroModular Editor http://www.clavia.se/downloads/software/nord%20modular/Nord%20Modular%20Editor%20OSX%20BETA.sit ?
