Where are the memory protection settings in v1.2 ??
Page 1 of 1 [6 Posts]
W.T.
G2 patch files: 11
PostPosted: Thu Jul 15, 2004 1:43 am    Post subject: Where are the memory protection settings in v1.2 ?? Reply with quote  Mark this post and the followings unread
In the new software version 1.2 you can no longer change the memory protection on/off in the synth settings. (and the sort by)
doe anybody know why? Confused
Or if there is an other way how to do so.
jamos
G2 patch files: 41
PostPosted: Thu Jul 15, 2004 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
They are present on my instrument - G2, not engine; in the System menu, as before.
In the editor, Memory Protect is in the Synth Settings dialog. I don't know where Sort is located in the Editor...
Audio files: 233
PostPosted: Thu Jul 15, 2004 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Sort by is there. In the patch browser, right-click on any patch and you'll see it.
Fozzie
G2 patch files: 49
PostPosted: Thu Jul 15, 2004 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I have an engine, but I don't believe that makes a difference as the memory protection setting is done in the 1.2 editor (win-PC in my case). In the lower-left corner of the synth settings window. Along with an indication (in %) of the free memory that's left.
W.T.
G2 patch files: 11
PostPosted: Fri Jul 16, 2004 12:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed Oops, stupid old me Exclamation
Thanx Foz. (Wat een duffe foutvan mij)
Fozzie
G2 patch files: 49
PostPosted: Fri Jul 16, 2004 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
That's ok. Ik heb het ook op de mailinglist moeten vragen voordat ik snapte waarom 'save in synth' altijd grijs was (protection was 'on') Embarassed
