Midi Question Lead3
Page 1 of 1 [4 Posts]
Nordleadagent
PostPosted: Fri Jan 30, 2009 1:23 pm    Post subject: Midi Question Lead3 Reply with quote  Mark this post and the followings unread
Will a Midi-signal received on Ch1 (f.e. a bass pattern from a sequenzer) be send on Midi-out on Ch1?
I won´t play this slot (Ch1) on the keyboard but use Slots 2-4 only.
Andreas
Nord Lead3, CS6x, SonicCell,
Wavestation-SR,Tenori-On,
Rm1x, E-MU XL1
Hear my music: http://www.last.fm/music/Soundagentenori?setlang=en
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Jan 30, 2009 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's the same as in the NordLead2X: only active Slots will send Midi, although all the time also the non-active Slots will react to Midi, so, in your set up: don't activate SlotA and don't send any Midi-In on the channels used by three other Slots. Just for the record, I would change the locations in SlotA to SlotC active and controlled by the KeyBoard; SlotD controlled by extern Midi.
Wout
Nordleadagent
PostPosted: Fri Jan 30, 2009 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Could you explain, why you would change to A-C for the panel voices and D for the external control voice?
Andreas
Rm1x, E-MU XL1
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Jan 30, 2009 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I can't find it in the Manual and I'm not in the mood to check it out, but other Clavia synths have a special feature in there architecture: all Slot react to the left-most Slots Midi channel, so using Slot D isn't interfering with the three others...
Wout
