cd4040 q1 not working
Page 1 of 1 [5 Posts]
ello
PostPosted: Sat Sep 08, 2018 5:06 am    Post subject: cd4040 q1 not working Reply with quote  Mark this post and the followings unread
hello, i am facing a strange issue. i have a cd4040 with a stable clock and a led to test the outputs. every output besides q1 makes the led blink according to the division. but q1 only creates a weak glow. this is happening for different 4040 chips, so i cannot believe they are all broken.
any ideas what can cause this?
ello
PostPosted: Sat Sep 08, 2018 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you have the reset input (pin 11) connected to ground ?
ello
PostPosted: Sat Sep 08, 2018 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, thank you. i soldered it and it seems my breadboard is crap. dunno, i have tested it on three different boards and all are faulty.
kaputtpanzer
Audio files: 15
PostPosted: Fri Sep 28, 2018 8:00 am    Post subject: Reply with quote  Mark this post and the followings unread
I had the same issue with a 74 HCT 4040. Q2, Q3, Q4 and so on were working but Q1 not. I think the HCT ic is the problem, it does not even have buffered outputs Evil or Very Mad I will buy some CD 4040 and try it again. Did you use HCT or CD ics?
ello
PostPosted: Fri Sep 28, 2018 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
i am using the cd4040be. and was definately the breadboard. i guess the pins are not 100% isolated to each other.
