Clock Divider
Page 1 of 1 [2 Posts]
PostPosted: Thu Apr 23, 2015 12:15 am    Post subject: Clock Divider Reply with quote  Mark this post and the followings unread
Soldered up a Yusynth Clock Divider! It takes the incoming clock and divides it down, either by two, or three, all the way to dividing by eight. Yves Usson's page is a lot better at describing this: http://www.yusynth.net/Modular/EN/DIVIDER/index.html
But if you looked at the wiring diagram on his page, there is a lot of wires. I hate doing wires. So I fired up Eagle. Yes, those rotary switches come in 1P8T as well as 2P4T. The 1P8T cost a lot and only come from Mouser, though.
This one was a complete SWINE to lay out. And I got the rotary switch layout wrong (which is why the jack board is a newer revision than the engine board.) But it is now working! (I had the LEDs sitting loose in the holes for them -- I plan on soldering them in when I get a faceplate made and can do the right length for them that way.)
Yves, I'd like to thank you again for all your wonderful, wonderful projects. They always work, and are always marvellous!
yusynth
PostPosted: Thu Apr 23, 2015 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
You're welcome AlanP, neat job you've done too.
Yves
