Sync problem with "standard" loop config
Page 1 of 1 [5 Posts]
jamos
G2 patch files: 41
PostPosted: Mon Jan 03, 2005 9:21 pm    Post subject: Sync problem with "standard" loop config Reply with quote  Mark this post and the followings unread
I'm having a problem with chained (serial) sequences; I just figured out enough about it to ask for help.
In the attached patch, there's a sync problem if I stop the sequencer in the 4th measure and then restart. I get an extra beat in the first measure immediately after restarting. This does not happen if I stop in measures 1, 2, or 3.
I'm using the internal master clock for this. OS = 1.24
Does anyone else experience this? Is there a solution?
TIA
Basic Beat Box.pch2
 Filename:  Basic Beat Box.pch2
 Filesize:  7.36 KB
 Downloaded:  1746 Time(s)
varice
Audio files: 29
G2 patch files: 54
PostPosted: Mon Jan 03, 2005 10:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I changed the 3 ClkDiv module modes from "Gated Mode" to "Toggled Mode" and that seemed to fix the problem. Not sure why the way you have it patched does not work.
varice
jamos
G2 patch files: 41
PostPosted: Mon Jan 03, 2005 10:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, that did indeed do the trick.
varice
Audio files: 29
G2 patch files: 54
PostPosted: Wed Jan 05, 2005 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
jamos,
I traced the problem to an issue with the calculation order of the first and last sequencer modules. The last seq module needs to be calculated before the first. See page 122 of the G2 manual for more about the calculation order of modules. This serial sequence module scheme is actually a feedback loop which confuses the system into not being able to determine which module needs to be calculated first.
At first I thought that the problem with your patch had something to do with the fact that you had placed clock divider modules between the clock generator and seq modules, but I checked and found that the problem you descibe exists with a serial seq setup just like the example in the manual.
My testing shows that if the clock is stopped while the seq position is in the last module (with an exception explained below), when the clock is restarted, the first step of the first seq module will take 2 clock pulses before advancing to step 2 on the third clock pulse. Of course, the seq should advance to step 2 on the second clock pulse. Now the seq will be behind by one step. If you have an event trigger set on the first step (like your patch), the seq trigger output will send 2 triggers at step 1 before the seq advances to step 2 (that causes the double trigger of the drums in your patch at step 1).
The exception: If you happen to stop the clock at the very last step of the last seq module, the restart problem will not occur.
Solutions to the problem:
1. In the Editor, move the last seq module(s) either to the left of or above the first seq module to force the last seq module(s) to be calculated first. But this looks mighty damn ugly!
2. Add a Logic Delay module between the ClkGen clock pulse output and the seq modules clock inputs, set the delay to the shortest time (0.10ms). After a clock restart, this clock pulse delay allows the first seq module to read both the Reset and Loop inputs before the first clock pulse arrives. (See the online help about the seq modules common parameters for more info about these inputs).
I'm still not sure why changing the mode of the ClkDiv modules seemed to fix the problem in your patch. Maybe this mode takes an extra calculation cycle or two?
varice
Audio files: 308
PostPosted: Wed Jan 05, 2005 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
A related problem and some solutions can be found at http://electro-music.com/forum/post-28574.html
Jan.
