LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Wed Oct 17, 2012 11:03 pm Post subject:
this sounds...errr... funny?
no, not funny.
just a wild guess: maybe something got loose? it is embarrassing that this would happen on two modules, though!?
are the x-4046 from the same batch? and/or the matched pair? _________________
Tech Buddy at Random*Source |
LektroiD
Posted: Wed Oct 17, 2012 11:11 pm Post subject:
The PCBs were from the same batch...
The 4046 ICs were from the same batch...
The transistors were from the same batch, hand matched...
Everything was working fine but they have gotten to an unusable state now. I tried wiggling all the components by hand one by one, as well as all the pots & sockets, yet failed to stabilise the pitch.
I can't think of anything else that would cause this (the audio is a mild example, it gets a lot worse). _________________ LektroiD |
Posted: Thu Oct 18, 2012 3:24 am Post subject:
for me it still sounds like a loose contact.
but why is it that you experience these problems on two modules, but not on two others?
i would try to think about what was different when building these. solder, potentiometers, other parts...
what is different right now when using them? other cabinet/powering method?
since nobody else experienced such an issue so far we can only try to analyse it. _________________
LektroiD
Posted: Thu Oct 18, 2012 4:46 am Post subject:
I built the 4 oscillators as a batch. I was just wondering what components regulate the pitch (other than the matched pair), if the 4046 might be the culprit, I could swap that out... I'll retouch all the joints and post my results... _________________ LektroiD |
Posted: Thu Oct 18, 2012 5:12 am Post subject:
| If your chips are socketed, can you switch one from a working module to a non working module? |
Posted: Thu Oct 18, 2012 11:41 am Post subject:
and maybe try different pots.
anyways, two modules at the same time??? _________________
LektroiD
Posted: Fri Oct 19, 2012 5:37 pm Post subject:
| fonik wrote: | and maybe try different pots.
anyways, two modules at the same time??? |
| LektroiD wrote: | | one went unstable after about 6 months, and now the second one... |
...I'm just waiting for the third
Anyway, I couldn't manage to true the waveform of any of my oscillators. I'll post the photos to see if what I have is normal, or maybe this is an underlying problem that also needs to be sorted. I guess because the square is not a real square, that's why they sound thin compared to my other synths / oscillators?
| Sawtooth... This is the best I could get it... |
177.73 KB |
| Viewed: |
41410 Time(s) |
| Triangle: After hours of perseverance, this is the best outcome |
161.29 KB |
| Viewed: |
41410 Time(s) |
160.02 KB |
| Viewed: |
41410 Time(s) |
208.03 KB |
| Viewed: |
41410 Time(s) |
166.64 KB |
| Viewed: |
41411 Time(s) |
_________________ LektroiD Last edited by LektroiD on Sat Oct 20, 2012 4:59 am; edited 1 time in total |
Posted: Fri Oct 19, 2012 8:07 pm Post subject:
| It looks to me like you've got some kind of extra capacitance on the line, dragging you back to ground. All the waveforms are exhibiting it. |
Mongo1
Posted: Fri Oct 19, 2012 9:28 pm Post subject:
If you used film capacitors in the oscillator core, you may have overheated them while soldering. They're very easy to damage, and I've had them do exactly what you're talking about - start out fine, and then get 'sick' over time. Just a thought...
Good luck
Gary |
LektroiD
Posted: Fri Oct 19, 2012 9:40 pm Post subject:
| elmegil wrote: | | It looks to me like you've got some kind of extra capacitance on the line, dragging you back to ground. All the waveforms are exhibiting it. |
These waveforms are exactly the same whether I use the bench supply or the PSU in the synth (I recently switched over to a dedicated PSU, solely to drive the oscillators; still the same output). I thought it was normal, since all oscillators are exhibiting the same...
So what would be the cure? _________________ LektroiD Last edited by LektroiD on Fri Oct 19, 2012 11:38 pm; edited 1 time in total |
LektroiD
Posted: Fri Oct 19, 2012 11:36 pm Post subject:
| Mongo1 wrote: | If you used film capacitors in the oscillator core, you may have overheated them while soldering. They're very easy to damage, and I've had them do exactly what you're talking about - start out fine, and then get 'sick' over time. Just a thought...
Good luck
Gary |
I used 'Wima' red box capacitors, would they become faulty/leaky?
Maybe I'll swap them out anyway.
Which capacitors are most likely to stabilise the pitch on these oscillators? _________________ LektroiD |
Posted: Sat Oct 20, 2012 6:19 am Post subject:
I meant the audio path, not the power supply.
I would start with caps closer to the output and pull back. I'm assuming those are the output waveforms, do you have anything any better if you probe closer in to the oscillator core or within the oscillator core? |
Mongo1
Posted: Sat Oct 20, 2012 6:35 am Post subject:
| Quote: | I used 'Wima' red box capacitors, would they become faulty/leaky?
Which capacitors are most likely to stabilise the pitch on these oscillators? |
I haven't used that exact type before, so I'm not sure if they have the same problem. The little silver tootsie-roll film caps are very sensitive. One trick for those is to attach an alligator clip between the caps body and solder point to act as a heat-sink when you solder.
I'm not sure if that applies with the redbox type, but it might be worth swapping them out. Couldn't hurt....
Gary |
Posted: Sat Oct 20, 2012 7:31 am Post subject:
| So thinking about the "over time" aspect ... What kind of solder did you use? Did you clean the board when you were done? Is it possible that flux has caused bridges to areas that will cause trouble? |
LektroiD
Posted: Sun Oct 21, 2012 2:58 am Post subject:
| Mongo1 wrote: | | Quote: | I used 'Wima' red box capacitors, would they become faulty/leaky?
Gary |
If I'm right, I think you're referring to polystyrene, like these:
I didn't use those in my build, I used mainly this type:
Maybe the ones I used are the wrong type for this build...?
I'll have a go at swapping them out, but to be honest, I'm probably heading towards digital oscillators now. Analogue ones are evidently too unstable to rely on. _________________ LektroiD Last edited by LektroiD on Sun Oct 21, 2012 3:15 am; edited 1 time in total |
LektroiD
Posted: Sun Oct 21, 2012 3:06 am Post subject:
| elmegil wrote: | | So thinking about the "over time" aspect ... What kind of solder did you use? Did you clean the board when you were done? Is it possible that flux has caused bridges to areas that will cause trouble? |
I use 60/40, I can't get on with lead-free stuff, it just doesn't flow like 60/40. I've been using that for years with no problem, I've retouched all the joints, but doesn't seem to have cured anything.
I always clean my boards with isopropyl alcohol and a toothbrush after they're built, so there's no flux residue.
I'm clueless as to what it could be really... If I can't get to the bottom of this, I think I'm going to see about sourcing some digital oscillators (suggestions?). Seems analogue are too troublesome, but then that is common knowledge anyway. _________________ LektroiD |
Posted: Sun Oct 21, 2012 5:38 am Post subject:
the effects you experience are too heavy to be realted to just the capacitor type.
BTW did you replace the 4046 allready? or replace the pots? did you re-heat all solder joints related to the expo and the 4046? _________________
Posted: Sun Oct 21, 2012 5:39 am Post subject:
yep. there is a slope added to all waveforms. _________________
Posted: Sun Oct 21, 2012 6:23 am Post subject:
| Sorry if my questions about flux are things you've known how to deal with for ages, just trying to brainstorm for ideas.... |
LektroiD
Posted: Sun Oct 21, 2012 10:08 am Post subject:
| elmegil wrote: | | Sorry if my questions about flux are things you've known how to deal with for ages, just trying to brainstorm for ideas.... |
Of course. I'm really looking forward to getting this back on the road, so please don't apologise. It's sometimes easy to miss the obvious, so every suggestion is very much appreciated. _________________ LektroiD |
diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Sun Oct 21, 2012 1:36 pm Post subject:
check the value of C3 and how it is soldered in
should be .01uf
less likely but also possibly relevent did you use LF442 for IC2 ? or just a TL072
LF442 has substantially better offset specs _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any |
elanhickler
Joined: Jun 24, 2008 Posts: 152 Location: Gilbert, Arizona
G2 patch files: 6
Posted: Sun Oct 21, 2012 5:17 pm Post subject:
Did you try removing the coarse tune pot from the circuit? also try removing the fine tune after that. Use DC offset to get it to an audible pitch.. or try 100k trimmers.
sounds like bad pots.
did you try PUSHING on the knob of the pot? So push down as if you were trying to force the knob further on the shaft. See if that affects the pitch deviation. Give it a push pull push pull to see if you hear the pattern. |
LektroiD
Posted: Mon Nov 05, 2012 9:56 am Post subject:
That's another one just gone down (same symptoms), I only have one oscillator left now. At this rate it won't be long before my synth is kaputt.
I'll try swapping pots, I just used cheap Alphas. Wiggling them in or out makes no difference, but I'll swap them out and report back... _________________ LektroiD |
Benjamin AM
Posted: Mon Nov 05, 2012 12:24 pm Post subject:
| LektroiD: Just out of curiosity, what are you using for a power supply? |
