laura woodswalker
Joined: Oct 06, 2007 Posts: 463 Location: phoenixville pa
Posted: Mon Sep 09, 2019 5:58 pm Post subject:
first time streamer? |
Hi! After going to Neemfest, Bill Fox invited me to be in the Streaming event & I thought I'd try. Never did streaming before. I was never a chatroom person so I'm clueless on that. I did install the Butt software & I don't know what's next. _________________ The most important gear is the brain behind the instrument. |
Joined: Apr 03, 2004 Posts: 24549 Location: The Netherlands, Enschede
Audio files: 301
Posted: Wed Sep 11, 2019 3:49 am Post subject:
Laura, did you try the links PHOBoS gave? Could you be specific as to what bits you want help with? _________________ Jan
laura woodswalker
Posted: Thu Sep 12, 2019 5:42 pm Post subject:
| Blue Hell wrote: | | Laura, did you try the links PHOBoS gave? Could you be specific as to what bits you want help with? |
I just made it thru the maze & found it. On to the next level! _________________ The most important gear is the brain behind the instrument. |
laura woodswalker
Posted: Thu Sep 12, 2019 5:44 pm Post subject:
Oh, for starters, where is the link to BUTT .16? _________________ The most important gear is the brain behind the instrument. |
JovianPyx
Audio files: 224
Posted: Fri Sep 13, 2019 5:43 am Post subject:
| laura woodswalker wrote: | | Blue Hell wrote: | | Laura, did you try the links PHOBoS gave? Could you be specific as to what bits you want help with? |
Oh, for starters, where is the link to BUTT .16? |
Hi Laura,
If you've just recently downloaded the BUTT software, then you already have the latest version ( 0.1.18 ). So you should be fine with the software you have.
I know this is a bit frustrating, but there are times during which there is nobody "paying attention" in the chat room. I know I stay logged in constantly, but when I'm busy, the chat window isn't visible. I know I'm not the only one that does that. You might consider checking into the chat room periodically to see if anyone is "alive". Note that as we move closer to the event date, there are usually more people in chat who can do the streaming test and who can help you if there are problems making the connection and doing the stream test.
Hope that helps a bit. _________________ FPGA, dsPIC and Fatman Synth Stuff
laura woodswalker
Posted: Fri Sep 13, 2019 1:49 pm Post subject:
| JovianPyx wrote: | | laura woodswalker wrote: | | Blue Hell wrote: | | Laura, did you try the links PHOBoS gave? Could you be specific as to what bits you want help with? |
Hi Laura,
I had the old software from the last attempt I made at streaming. I just googled it & got #18.
Hope that helps a bit. |
OK, I will keep checking back. Thanks. I'm not normally a chatroom user, I usually just hang out on facebook. _________________ The most important gear is the brain behind the instrument. |
