MS20 LPF clone cutoff
Page 1 of 1 [7 Posts]
palmiarz
PostPosted: Fri Jul 19, 2019 4:45 am    Post subject: MS20 LPF clone cutoff
Subject description: problem with cutoff
Hello! I have a problem with MS20 lpf clone from Look Mum no Computer https://static1.squarespace.com/static/5912db7ee6f2e1435dbab4fd/t/5be83649f950b776709434cc/1541944936737/MS20+filter+stripboard+layout?fbclid=IwAR15jZssS-iknvwsfbrYAsA4IiNHQOdJthgAJ38KGhbb9rkjtLrnofTtr3M When I switch on this filter, all is ok, but after 5 seconds sound becomes a little smoothy and cutoff begins working as volume control. My voltage is +/-9v. Does anyone know what's wrong?
wackelpeter
Audio files: 10
PostPosted: Sun Jul 21, 2019 1:57 am    Post subject: Reply with quote  Mark this post and the followings unread
can you post some Images of the top and Bottom side of your PCB with a good Resolution?
PostPosted: Sun Jul 21, 2019 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did you connect all three connectors to ground? In the comment it just says that the black wire etc. but the input jack at the lower left site has no black wire so that may be confusing.
my synth
palmiarz
PostPosted: Mon Jul 22, 2019 1:09 am    Post subject: Reply with quote  Mark this post and the followings unread
It's soldering on universal board Smile
palmiarz
Yes, I did it.
wackelpeter
Audio files: 10
PostPosted: Mon Jul 22, 2019 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
doesn't matter, just post it, so that People can see and give some Feedback if everything Looks okay or if they see something suspect.
Posting a link to the shcematics/build guide used is Always a good idea but additional Pictures of the board are the cherry on top of the cake. Wink
palmiarz
PostPosted: Fri Jul 26, 2019 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I found a problem - cold solder on transistors. Thanks for replies!
