<on air> Cancelled due to equipment failure - Sorry Chez Mosc
808-style pattern sequencer
Page 1 of 1 [21 Posts]
zipzap
PostPosted: Wed May 02, 2007 12:32 pm    Post subject: 808-style pattern sequencer Reply with quote  Mark this post and the followings unread
Hi together
I´m planing a big sequencer for an drumbox. 8 Rows of 2-16 steps.
Instead of wiring (and buying) 128 switches there should be some other approach.
First of all i´m thinking of 16 step buttons with status leds and 8 buttons to select the row. how would you do this?
I could imagine a flipflop for each step that can be turned high or low with the button. Then the flipflop out can be anded with the sequencer.
the buttons are connected to the row that is selected, via some more circuitry, maybe also and gates.
So i need 128 flipflops, 128 and gates and lots of gates or switches for the row selection. lots of pins to solder. Not very smart, right? All i know bout is cmos...
A PIC job?
Or something else? 8 Pics?
And here are some more things on the wishlist:
Save patterns
select patterns, eg by a second sequencer that is running at 1/16th speed
have 4 direct pattern select buttons - good for live - throw in a fill/break/etc
Accent - like on the old roland machines
what do you think? anyone done this already? (i can´t programm Embarassed )
cheers
http://www.myspace.com/lorolocoacousticpop
music and transcribed jazz basslines
modularkomplex
PostPosted: Wed May 02, 2007 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
have a look on the Midibox SEQ. You can strip the surface down to your needs. But its definately worth to build in the complete version.
Mike
zipzap
PostPosted: Wed May 02, 2007 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
i know that, it´s great!
But i´m talking about plain logic trigger outs, not midi.
Was just thinking: If you go the cmos way, how about shift registers?
Cascade 2 8 step registers for 16 steps. Parralel-Load them with 16 buttons - clock it - connect drum to serial out.
However:
you would see no status leds - unless parallel out registers are used. That would make the status led move with each steps - different, but maybe cool. maybe a 4035 - 4 for each row
It´s not possible to programm the thing while it´s running, right?
Don´t know much about shift registers. ;aybe there is one that has a pin to disable parallel loading - then it would be possible to connect the step buttons to all rows in parallel. All the rows, except the one that is selected, will ignore the buttons.
zipzap
PostPosted: Wed May 02, 2007 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Still, the midibox seems great for this... big project though
sneakthief
PostPosted: Wed May 02, 2007 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
you want an 808? here's an 808!!
- http://eight-oh-eight.org/phpbb2/forums.html
the first kits for this 808-clone are being shipped this week. it's basically a clone of the analog section and includes the original rare components.
the sequencer, mb808, is a MIDIbox derivative featuring both midi & 12 gates outs will also be available separately here:
http://www.midibox.org/dokuwiki/doku.php?id=mb808
Sneak-Thief - raw electrofunk
midgetfidget
PostPosted: Wed May 02, 2007 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sneakthief, are you getting one of the first kits too?
I can't wait to get building.
sneakthief
PostPosted: Wed May 02, 2007 11:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'm on the waiting list but not on the first round.
bdu
PostPosted: Fri May 04, 2007 7:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
But I am ;0)
I got an email verifying my home address for shipping yesterday, so I think the base kit should be on it's way soon. Unfortunately, I won't have much time to put together an order for the other parts and get building until the end of the month.
That said, the sequencer portion of this project is almost exactly what the original poster was looking for, yeah? I wonder if he could get the layout from Jeff and chop off the voice boards, send it out for a one-off...
goodrevdoc
PostPosted: Fri May 04, 2007 8:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Isn't the sequencer for that just a slightly altered midiboxseq? I imagine if one could obtain the specific PIC, it could be made on the regular midibox boards, no?
-justin
bdu
PostPosted: Fri May 04, 2007 9:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
-justin
Yeah, if you're willing to spread it across five or six smaller boards that each contribute to the end functionality.
sneakthief
PostPosted: Fri May 04, 2007 10:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
no you guys have totally misunderstood - mb808 is *also* going to be released as a sequencer for the MIDIbox platform, so all you really need is the "core" module and maybe a "digital-out" board for the gate outputs.
the 808-clone is just a regular MIDIbox that happens to be hard-wired to 808 voices.
bdu
PostPosted: Fri May 04, 2007 10:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
And a couple din boards for the encoders and switches, and an LTC to get around the midi bug with the newer PIC, and a bankstick for storage...
;0)
sneakthief
PostPosted: Fri May 04, 2007 10:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, what he said Wink
2 Digital-In boards? I didn't realize there were more than 32 switches.
bdu
PostPosted: Fri May 04, 2007 11:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
33 lit switches, plus some encoders for tempo and shuffle. Actually, given the LEDs in those switches, make that 2 or more DOUTs too.
goodrevdoc
PostPosted: Sat May 05, 2007 5:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, that's what i meant. Ive already got some boards I etched from Here, I was just gonna tack on all of the sequencer stuff when I got around to it. This mb808 sounds perfect!
-justin
Peake
PostPosted: Sun Mar 23, 2008 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've found this thread rather late- has anything happened since? The MIDIbox site doesn't seem to have much info.
Most importantly, does it have the feel of the 808? The 808 appears to push and pull different instruments away from the regular clock, giving it a really nice feel.
Thanks for any information on this incredibly good idea.
sneakthief
PostPosted: Sun Mar 23, 2008 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
1. yes, the project is still active. in fact, Thorsten Klose (the developer of the midibox platform) has now taken control of the firmware development:
http://www.ucapps.de/midibox_808.html
check out the forum to find out more:
2. re. timing of a real 808: that's a bit of a nebulous question, no?
just listen for yourself to the mb-808 demos:
http://www.eight-oh-eight.org/
3. there are a couple of diy-ers who'll be custom-manufacturing cases for this project:
Peake
PostPosted: Sun Mar 23, 2008 5:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks sneakthief!
Edit: Sominabiche! A group-buy thingie and I've missed the first run. Preft!
Regarding timing: The handclap sounds too tight.
sneakthief
PostPosted: Sun Mar 23, 2008 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Peake wrote:
Thanks sneakthief!
my feeling is that there will eventually be another groupbuy.
re. timing: then simply take a peek at the code, shift the timing of the clap and recompile. it's not nearly as daunting as you might imagine.
besides, that's the spirit of the MIDIbox platform - you know, getting your hands dirty in things you haven't necessarily dabbled in.
Luka
PostPosted: Sun Mar 23, 2008 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
it also has swing control Smile
problemchild
melbourne australia
Peake
PostPosted: Sun Mar 23, 2008 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I shall gladly do these things-- when the next chance comes around. Crying or Very sad
