assign mod wheel
Page 1 of 1 [6 Posts]
Rix
G2 patch files: 25
PostPosted: Wed May 16, 2007 2:18 pm    Post subject: assign mod wheel Reply with quote  Mark this post and the followings unread
It may sound strange, we can't assign the modwheel. Feeling rather stupid tonight, I don't know.
When assigning MIDI controllers the input options start at controller 2.
So how does one assign controller 0 and 1?
Rix, electri-fire
Audio files: 309
PostPosted: Wed May 16, 2007 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
The mod wheel is tied to one of the morphs, so you could use that I guess ?
davep
Audio files: 10
G2 patch files: 73
PostPosted: Thu May 17, 2007 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I have never understood why the G2 and NM1 are different in this respect. On the NM1 you can directly assign the mod wheel to a parameter but you can't on the G2. On the G2, you have to use up one of the Morph groups to assign the mod wheel, even if you only need to assign the Mod Wheel to one parameter, which seems like a waste of valuable Morph assignments to me.
But as usual, there is a work-around. Depending on what you are trying to do, you can drag the DEVICE module (from the In/Out tab) into the patch and you can patch the mod wheel directly to a parameter that way. This also gives you the ability to process the Mod Wheel response by sending it through shapers or whatever, which can be helpful.
Dave Peck
G2DREAM
PostPosted: Thu May 17, 2007 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I love the Device module! I too recommend it to you!
_____________
cyber-evolution
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu May 17, 2007 9:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like device module. Especially the stuff you can do with the pitchstick Wink
/Dasz
iPassenger
G2 patch files: 78
PostPosted: Fri May 18, 2007 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I never use it (device mod) but as you all proclaim its brilliance perhaps i should.
hmm...
iP (Ross)
