 Forum index » electro-music.com
Electro-music.com Chat Room now operational
Page 2 of 2 [35 Posts]
Goto page: Previous 1, 2
Audio files: 235
PostPosted: Wed May 17, 2006 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think it is a good thing to have Java enabled on you computer, not just for the electro-music.com chat room.
Still, if you don't want to use the Java client, you can use any IRC chat
program.
Here is the needed info:
    Server: irc.blitzed.org
    Port: 6667
    Channel: #electro
PostPosted: Thu May 18, 2006 2:47 am    Post subject: Reply with quote  Mark this post and the followings unread
But in my internet options it says that scripting of Java applets is enabled. What else do you have to install/enable?
PostPosted: Thu May 18, 2006 4:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Java scripting is a sort of a scripting language built into the web browser. For running Java programs you need to install the Java Runtime Environment. See http://www.java.com/en/download/index.jsp
PostPosted: Thu May 18, 2006 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan,
Sorry for being such a noob (still)
I've never used any Java anything until we started scripting in my Web design course about 3 mths ago. Everythings up and running fine now. Cool
PostPosted: Thu May 18, 2006 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Its pretty confusing of course to have two different things by nearly the same name. I remember me using some stronger wording than above when I first discovered this Very Happy
KHI
PostPosted: Fri Jun 01, 2007 9:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Download mIRC, its free, and its easy to set-up.
You can get it here : www.mirc.com
Nth L0gik
PostPosted: Tue Aug 21, 2007 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks to everyone that kept it going
i've met a few very decent ppl in the chat room access and would like to continue using it instead of the IRC client
Audio files: 235
PostPosted: Tue Aug 21, 2007 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure, use any IRC client you like.
PostPosted: Sat Aug 04, 2012 6:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Scot - There are plenty of free irc clients online. do a search and you will find one for your os.
JacobWatters.com
PostPosted: Sat Aug 04, 2012 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry Jake, that was a spam setup.
