seraph
Editor
Audio files: 33
Posted: Sun Sep 02, 2007 12:06 am Post subject:
| Quote: | Not Found
The requested URL /midipb.htm was not found on this server. |
 _________________ homepage - blog - forum - youtube
| Quote: | | Don't die with your music still in you - Wayne Dyer |
Dragon's Lair
Joined: Dec 29, 2006 Posts: 205 Location: Hope BC, Canada
Posted: Sun Sep 02, 2007 12:58 am Post subject:
The PICs are only in my Midi Pedal, the midi patch bay just uses opto-isolators and some hex inverters, it's actually a pretty simple circuit, just think of it as 8 - 1x8 midi through boxes ganged together.
The hardest part was making the rack case!
I have been using this one for almost 15 years now, with no problems, and a friend of mine is still using the 4 channel one I built before this. |
jksuperstar
G2 patch files: 18
Posted: Sun Sep 02, 2007 1:11 am Post subject:
Stein, sorry I missed this one earlier. Are you not interested in a used one? I have an Emagic AMT8 (ala Unitor8). It was designed for Logic, within which it can pre-queue midi, such that on the next clock, all 8 channels go out, so timing is improved. It has both serial and USB interfaces, can operate stand-alone, and the unitor adds some of the video sync stuff.
Works flawlessly in windows, and since it was originally used with MACs, that says alot.
Comes in the amt4 (4x4) as well. |
Joined: Apr 03, 2004 Posts: 24676 Location: The Netherlands, Enschede
Posted: Sun Sep 02, 2007 7:32 am Post subject:
Not Found
Apache/2.0.45 (Win32) Server at 207.81.1.73 Port 100
edit: oops, Carlo had discovered this already _________________ Jan
Dragon's Lair
cappy2112
Joined: Dec 24, 2004 Posts: 2508 Location: San Jose, California
Posted: Sun Sep 02, 2007 3:01 pm Post subject:
| Dragon's Lair wrote: | just uses opto-isolators and some hex inverters, it's actually a pretty simple circuit, just think of it as 8 - 1x8 midi through boxes ganged together.
Not a bad idea!. Simple and cheap, and NO SOFTWARE involved
Can this route 1 input to more than one output? |
Posted: Sun Sep 02, 2007 3:20 pm Post subject:
| jksuperstar wrote: | Stein, sorry I missed this one earlier. Are you not interested in a used one? I have an Emagic AMT8 (ala Unitor8). It was designed for Logic, within which it can pre-queue midi, such that on the next clock, all 8 channels go out, so timing is improved. It has both serial and USB interfaces, can operate stand-alone, and the unitor adds some of the video sync stuff.
Hey! yeah.. well I dunno.. I guess I should research how the AMT8 is being supported in Logic 7 and 8 ? I almost managed to grab a Unitor a year or two back but the seller suddenly demanded 3 times more for it. The Motu XT seems promising? The tape sync stuff seems useful. I have old 8 and 16 track tapes with click sync.. for use with those Roland VCA compu mixers, some tapesync boxes I made, the MC202, the TRs and some other shit. I only need to buy back those 8 and 16 tracks in order to restore the old projects. or maybe not.. I´ve transferred most stuff to a zillion files that I have manually synced and stretched and tweaked.. I guess I don´t want to do it all again.. or do I?  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr Last edited by elektro80 on Sun Sep 02, 2007 10:32 pm; edited 1 time in total |
Dragon's Lair
Posted: Sun Sep 02, 2007 10:29 pm Post subject:
| cappy2112 wrote: |
Yes it can |
Posted: Sun Sep 02, 2007 11:11 pm Post subject:
A DIY midi patchbay seems like an excellent project. However, what I really need is a device like the Motu Express XT.  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
cappy2112
Posted: Sun Sep 02, 2007 11:17 pm Post subject:
| Dragon's Lair wrote: | | cappy2112 wrote: |
Yes it can |
Would you show us a schematic & parts list? |
Dragon's Lair
Posted: Mon Sep 03, 2007 1:35 am Post subject:
I don't have the schematic handy, I'm getting ready to move so a lot of stuff is already packed away, but I do have the pc board layout in EAGLE format, all the parts and connections are on the layout.
I tried uploading the EAGLE .brd file, but it is not a recognized file type, so I uploaded a bitmap of it, if you want the .brd file, pm me with your email address, and I'll send it to you
| Description: |
 Download (listen) |
| Filename: |
MidiPB.bmp |
| Filesize: |
2.81 MB |
| Downloaded: |
447 Time(s) |
| Description: |
 Download (listen) |
| Filename: |
MidiPB.zip |
| Filesize: |
15.47 KB |
| Downloaded: |
367 Time(s) |
Last edited by Dragon's Lair on Tue Sep 04, 2007 4:29 pm; edited 1 time in total |
Posted: Mon Sep 03, 2007 2:29 am Post subject:
A zipped version will probbaly be allowed as an attachent.  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Dragon's Lair
Posted: Tue Sep 04, 2007 4:30 pm Post subject:
Thanks, I added a zipped version of the .brd file to the above post.
I haven't added any of this stuff to my webpage yet, I am in the process of selling my house and moving to another town, and it depends on where I end up, whether I can set up the server again.
I am looking at a place just south of Nakusp, a block away from the lake, NO Cable or ADSL!, so I'm also looking into a direct satellite connection, but they are pretty pricey, I may just end up with a dial up connection  |
lamarcph
Joined: Oct 21, 2004 Posts: 40 Location: Montreal, Canada
G2 patch files: 4
Posted: Mon Nov 12, 2007 8:12 pm Post subject:
Where is everyone in their quest for a 8x8 midi card? With all those cheap knob box, I wonder how the average user is connecting everything.
I need a midi interface that will do some basic routing when the computer is not connected.
I could get for a few bucks an old Motu Midi Express XT, the serial version.
A serial adapter to USB adapter is also a few bucks.
Is this doomed to fail?
Else, I would have to buy a new Motu Midi Express XT usb... anyone had experience with it?
I have a Motu 828mkii and it work perfectly, I can play thru the internal mixer, then connect my laptop and boom, all the input are available for recording. If I could have this functionality with a midi card, it would be perfect. |
jksuperstar
G2 patch files: 18
Posted: Mon Nov 12, 2007 10:16 pm Post subject:
My bandmate has a MOTU Xpress XT. Works as you describe, as do most other interfaces I've used. The only thing that you should understand about all the intefaces: they claim to have routing tables, filtering, etc. But these only work in standalone modes (no computer). Once the computer is attached, all those functions are disabled and the MIDI basically is just IO to computer. So, the Computer has to do the routing & filtering for you  |
XpanderXT
Joined: Oct 22, 2007 Posts: 137 Location: the flat universe
Posted: Fri Dec 28, 2007 12:49 am Post subject:
I'm looking over this because I'm having issues with the internal routing of the MOTU MIDI Express XT and Logic 7. My system has two 8x8 interfaces, the USB MIDI Express XT and a Serial port MOTU MIDI Timepiece (the original one). I have a G-port serial interface on my G4 Mac.
I am having a couple of problems with this set up.
1. both interfaces seem to drop some MIDI data on a regular basis leaving stuck notes or sysex streams that get interupted.
2. the MIDI Express XT is too "smart". I hate the built in routing. You need to use their application to set your User presets. It has a bunch of factory presets, and it has nothing that lets me know that the computer is handling all routing when it's working in Logic. I get it rerouting MIDI clock in loops and all kinds of things.
The old MIDI Timepiece works OK. I also have a serial interface Unitor but it's about as good as the others.
I really want a 16x16 interface that works in standalone nicely, will allow the computer to take over and route things properly, doesn't drop MIDI data and has a USB connection....I know, dream on.
The new solution is one that Waldorf is using with Blofeld, make it USB.
The problem is I already have a 4 port USB 2.0 port on my computer, the 2 built in ports and a 4 port hub hooked up to one of the 2.0 ports and I'm out of ports! I'm sick of USB audio products. I want an interface I can chain like firewire (without the driver nightmares that every audio interface is having). |
GovernorSilver
Joined: Apr 26, 2004 Posts: 1349 Location: Washington DC Metro
Posted: Fri Dec 28, 2007 1:58 pm Post subject:
I still have my MOTU MIDI Express 128, which is the dumb version of the XT - it needs a computer to do its mapping.
I thought about selling it, but now I actually have enough MIDI devices to justify the need for it. Needing a computer kind of sucks, but our band uses my aged iBook G3 for recording anyway. Soon we're going to use it for basic sample playback as well. _________________ Current and recent work on Soundcloud
Some old stuff on VIRB |
EdisonRex
Audio files: 172
Posted: Tue Jan 01, 2008 9:08 am Post subject:
| GovernorSilver wrote: | I still have my MOTU MIDI Express 128, which is the dumb version of the XT - it needs a computer to do its mapping.
I thought about selling it, but now I actually have enough MIDI devices to justify the need for it. Needing a computer kind of sucks, but our band uses my aged iBook G3 for recording anyway. Soon we're going to use it for basic sample playback as well. |
I have one of those in my studio. I don't mind it in there. It wouldn't work for gigging unless I was going to use a computer, which isn't worth the hassle.
In a box, I have a Digital Music Corp. MX-8 MIDI Patchbay, dating from I guess 1988 or so. I did use that for gigging. I guess I retired it from studio use maybe 15 years ago, when I got my first MOTU midi patchbay. The problem with the MX-8 was that it didn't have anything but MIDI - no serial, it only has a sysex implementation to make it do anything, so it was a bit unwieldy for studio work. But it had a lot of preset-ability so it worked nicely outside of the studio.
Not very useful when all I gig with is two boards now. _________________ Garret: It's so retro.
Posted: Thu Jan 24, 2008 3:47 am Post subject:
It seems like I´ll have to go for the MOTU Midi Express or the MOTU Midi Express XT. Seemingly these are the only options. I´ll reckon I´ll have to get it from Turnkey. These cost 3 times more in Norway than in the UK. Only problem is that they are often out.. last time I had someone walk into Turnkey in order to buy one for me they were out and there were at least 3 weeks waiting time.  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
BobTheDog
Audio files: 32
Posted: Thu Jan 24, 2008 4:19 am Post subject:
| Have you tried /www.thomann.de |
Posted: Thu Jan 24, 2008 4:31 am Post subject:
Yup, nice price.. I´ll check if they can handle delivery to Norway. They list the items with swedish sales tax included.. hmm.. this looks promising..
But if I go Thomann then I won´t have an excuse for visiting new and old friends in the London area. Or??  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Thu Jan 24, 2008 4:40 am Post subject:
OT:
But I´m also trying to decide on a decent midi keys controller thingie..
I can never get enough of them and now I´m out of two.. long story.. I need to stock up. I want at least one with decent aftertouch. I like both the springy plasticky sloppy light vintage synth keyboards as well as well weighted hammer action. Actually, I need both types.. and I also need at least one with 88 keys.
Is the CME UF80 OK? The CME forum is mainly full of customer complaints of the "you silly bastards" kind.
And that M-Audio 88 keys + lotsa controllers and shit is getting lotsa nasty user comments all over the web as well.  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Sun Feb 03, 2008 6:41 pm Post subject:
I got the Kurzweil SP2X. I´m also considering looking for an old Kurzweil MidiBoard. That one has polyphonic aftertouch. I reckon it would mix well with the Arturia CS80 softclone.
I also got a Motu Express USB thingie. I might have to get another one later. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
SineSurfer
Posted: Sun Feb 03, 2008 11:03 pm Post subject:
Hi there!, a possible solution for the lack of 8x8 MIDI interfaces:
anyone had tried using two M-audio Midisport 4x4 on the same computer?
I have one of those, and will need to add some more ports soon... that would be the easiest way to do it, but don't know anyone with one of those to test both connected  |
CJ Miller
Posted: Sat Apr 12, 2008 11:32 pm Post subject:
I use mostly an Opcode Studio4 and Emagic AMT8. Also I have made a few single port interfaces from scratch - no PIC required. Studio4 is solid but doesn't offer any extra features. AMT8 gets points for RS232, RS422 and USB operation. Apple indeed have been updating the Emagic MIDI drivers! People balk because they are not offered online as a separate downoload, but they are installed with Logic. Of course, I doubt that Apple will support them forever, but they have so far.
My dream MIDI is the Opcode Studio5lx, 15x15 with patch bay capabilities. I intend to score a MOTU parallel interface because there is ALSA support in Linux, but I haven't tried so I don't know how good it may be.
One project for later in the year is a combination simple MIDI interface with a monitor and active multiple outputs. This is for all-around troubleshooting and dealing with equipment with simple MIDI facilities such as no "thru" jacks, or one-port machines like my Ataris. I'm looking here for monitor ideas:
http://www.ucapps.de/midimon.html |
