ReaktorFreak
Joined: Sep 28, 2007 Posts: 65 Location: Jakarta, Indonesia
Posted: Fri Sep 28, 2007 3:43 am Post subject:
Audio To Pitch/Gate and MIDI Converter |
Hi, this instrument i made convert monophonic audio sources to pitch/gate and MIDI, but the MIDI still had lots of problems. It is based on Frequency Tracker Instrument from library and i've customized it to receive signal from my electric guitar. Anyone kind enough to give it a try and tell me your opinion ?
The Instrument is now moved to the bottom of this page. Last edited by ReaktorFreak on Tue Nov 13, 2007 8:12 pm; edited 2 times in total |
ReaktorFreak
Posted: Sat Oct 06, 2007 7:21 am Post subject:
Hi, this is my latest update for Elektro Guitar. MIDI Out is now functioning but no pitchbend yet. Lots of stuff added. I also add a screenshot. Last edited by ReaktorFreak on Wed Nov 07, 2007 6:51 am; edited 1 time in total |
W.T.
Joined: Jul 11, 2004 Posts: 272 Location: The Netherlands
G2 patch files: 11
Posted: Mon Oct 08, 2007 3:58 pm Post subject:
this cool, thanks.
i am playing with it right now  |
ReaktorFreak
Posted: Thu Oct 11, 2007 2:27 am Post subject:
Thanks W.T. , hope you enjoy it as much as i do.
Fix some problems when changing control rate to other than 400 hz, and a lot better MIDI Out, although still not complete (no retrigger, PBend). I guess i just take a break for a while... coding MIDI is so frustrating. Last edited by ReaktorFreak on Wed Nov 07, 2007 6:51 am; edited 1 time in total |
ReaktorFreak
Posted: Sun Oct 14, 2007 11:54 pm Post subject:
Whew, finally i got my ins the way i wanted it. Everything's been working quite well and very playable, so i guess i could start my music project that has been left out since i started building my ins. Last edited by ReaktorFreak on Wed Nov 07, 2007 6:52 am; edited 1 time in total |
Luka
ReaktorFreak
Posted: Tue Oct 23, 2007 8:59 pm Post subject:
Some ideas from trying out several synths that i put on this version. Also i've tried with vocals and it works quite well. And i guess this is the final version of my ins. Last edited by ReaktorFreak on Fri Sep 11, 2015 6:31 am; edited 3 times in total |
ReaktorFreak
Posted: Tue Oct 30, 2007 8:23 pm Post subject:
Another try in building audio to MIDI converter.. i got the idea for this one from hearing guitarist talk about their hardware guitar synth, that they can play drums on low E string, bass on A string, trumpet on D string, and so on. It makes me wonder if i could build a MIDI converter that could function like their hardware stuff did.
Beside that, i also want to try the method of using static resonators, unlike my prev ins that based on Frequency Tracker Ins' moving resonator. This method results in very accurate pitch tracking that there's almost no glitches at all, which i think that will simplify the MIDI function to 'understand' the pitch data, because the pitch from audio input is sort - of - quantized by the resonators.
On the downside though, the pitch from audio input has to be almost perfectly in tune to be recognized by the resonators, and the 'infamous' audio to MIDI latency also occurs in the conversion.
Maybe anyone knows other method/technique for tracking pitch ? Last edited by ReaktorFreak on Fri Sep 11, 2015 6:32 am; edited 1 time in total |
ReaktorFreak
Posted: Tue Nov 13, 2007 8:18 am Post subject:
This one's just like Elektro Guitar, but customized for vocals or speech (just like the original Freq Tracker Ins), with an input signal amplitude to free-form envelope converter added. Last edited by ReaktorFreak on Fri Sep 11, 2015 6:34 am; edited 1 time in total |
ReaktorFreak
Posted: Thu Nov 29, 2007 10:50 pm Post subject:
This has major changes since v1.17, so i guess that version is not final yet... . And because of that, i think i'll keep the 1.17 version posted.
Added some fun stuff and more tweaking accessibility, now it is more than just a pitch/gate converter, it can be used as an effect to generate trigger or random pitches from other sources beside electric guitar and vocal (try drum loops). Last edited by ReaktorFreak on Fri Sep 11, 2015 6:34 am; edited 3 times in total |
ReaktorFreak
Posted: Sat Dec 01, 2007 3:15 am Post subject:
This one is actually consist of two ins. First one is sort of audio to 'MIDI Keyboard' converter and the second is some simple additive sine organ and a drum loops to organ converter that its fundamental pitch can be played via MIDI. Last edited by ReaktorFreak on Fri Sep 11, 2015 6:34 am; edited 1 time in total |
ReaktorFreak
Posted: Fri Dec 14, 2007 8:49 pm Post subject:
This is a tribute to Freq-Tracker Ins which i really loved. Now i've added MIDI capability that can be used to control another Reaktor Ins via internal MIDI connections or external device via MIDI Out.
Have fun using it, feel free to change/use anything. Last edited by ReaktorFreak on Fri Sep 11, 2015 6:35 am; edited 1 time in total |
ReaktorFreak
Posted: Tue Apr 29, 2008 1:38 am Post subject:
Another monophonic pitch to MIDI converter, in this one i try different approach on 'translating' the detected pitch into MIDI data (note on/off, pitchbend, velocity). And because it transmits MIDI signal, it can be used to control external synth like VSTi or recorded in a sequencer. Last edited by ReaktorFreak on Fri Sep 11, 2015 6:35 am; edited 3 times in total |
ReaktorFreak
Posted: Wed Jul 09, 2008 1:16 am Post subject:
A polyphonic pitch to MIDI converter, it's quite stable now compared to the previous version. Last edited by ReaktorFreak on Fri Sep 11, 2015 6:35 am; edited 2 times in total |
ReaktorFreak
Posted: Sat Oct 04, 2008 2:14 am Post subject:
A voice-controlled synth, doesn't have MIDI option but has a quite low latency. This one uses a different method from the previous Freq-Tracker based ones, and has an 'intelligent' harmony generator. Last edited by ReaktorFreak on Fri Sep 11, 2015 6:36 am; edited 1 time in total |
ReaktorFreak
Posted: Mon Dec 01, 2008 7:45 am Post subject:
A technique i've just learned in this one, this time i use AMDF (variation of Autocorrelation) method to convert the audio (monophonic) to MIDI. It has the advantages over the previous zero-crossing and BP Filter method that it is much faster on low-frequency source. It still has several problems though, like octave jumping and random notes coming out at the attack of the note. Also if the signal is too constant on the amplitude (i.e. pure saw wave) the detection is going to be failed because it cannot decide which periodicity is the fundamental. Last edited by ReaktorFreak on Thu Aug 15, 2019 5:05 pm; edited 83 times in total |
mihai
Posted: Tue Dec 02, 2008 1:53 pm Post subject:
Hi everyone Subject description: downloading |
Hey everyone,
i just bought my g2 and i was working on a pitch to midi patch
Now i see you have a lopt patches made for this pitch to midi and i tried to download them but i cant get the .pch2 files i only get a folder that i cant open or a file with extention .ens
sorry for beeing a rookie but how can i check out the patches you guys put here on this forum to download?
Thanks im looking forward to try this audio converter like electro guitar v1.21
i would aprecciate. thanks
Mihai |
Joined: Apr 03, 2004 Posts: 24632 Location: The Netherlands, Enschede
Audio files: 321
Posted: Tue Dec 02, 2008 2:04 pm Post subject:
Mihai,
the patches here seem to be for Reaktor and not for the G2 ... you can try and look here if there are any pitch converters ... like maybe this one ... but there are some more ...
And congratulations with your new synth! _________________ Jan
mihai
Posted: Tue Dec 02, 2008 2:12 pm Post subject:
thanks for helping me out so quickly
im gonna try them out
thanks |
Audio files: 321
Posted: Tue Dec 02, 2008 3:12 pm Post subject:
I split off your question to the G2 section, it seemed more appropriate there  _________________ Jan
jordpeck
Posted: Sat Feb 27, 2010 11:27 pm Post subject:
| Hey. I keep trying to open your folders but it says I do not have sufficient privileges??? I'm really excited about trying your stuff! Thanks. |
