The Thomas Henry "Clangora"
Page 3 of 4 [95 Posts]
PostPosted: Tue Dec 19, 2006 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
A chip that may be harder to get is the NE570 compander IC using in the Clangora . It is available at Small Bear:
http://www.smallbearelec.com/Detail.bok?no=235
Mouser carries it but in an SOIC and will require an adapter:
http://www.mouser.com/search/refine.aspx?Ntt=NE570
Here is another good supplier of electronic components and HW:
(Debco Electronics)
http://safe.dhwd.com/cgi-bin/debco/index.html
They also carry the CA3080 and LM13700: (just in case you want to use that instead of the NE570 but some modifications will be needed of course)
http://safe.dhwd.com/cgi-bin/debco/search.html
Hope these sources help ...
Bill
PostPosted: Tue Dec 19, 2006 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Bill,
isn't the NE570 a compander?
The 3080 and the LM13700 are TOAs.
PostPosted: Tue Dec 19, 2006 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Bill,
Yes, but he is not using it like a compression/expansion unit but in more of a straight VCA role. The basis of companding is the use of voltage controlled amplifiers and the close monitoring of signal levels. There are two independent sections in the NE570. With some modification of the original Clangora circuit, I would imagine that the LM13700 could be made to do the same thing as the NE570 since the OTA is the basis of most VCA's. The LM13700 is more widely available and cheaper and it has a better S/N ratio than a CA3080. Also, the Iabc control current is better isolated on the LM13700 part than on a CA3080 as I have mentioned before in other topics on the forum.
I have not looked back on the article lately in it's entirety but I believe Tom's reasoning was that two VCA sections could be made from one NE570 and that the distortion and noise specification is better using this part. So, you can make two VCA sections with one LM13700 also if you could not get a NE570.
Bill
PostPosted: Tue Dec 19, 2006 3:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for explaining that Bill.
I can see I still have much to learn. Smile
I've learned so much hanging out here, I forget sometimes that my theoretical background is a bit shaky! Embarassed
PostPosted: Tue Dec 19, 2006 6:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am happy to help always and I personally have learned from all of you. I feel like I know you all Very Happy
Photon
PostPosted: Fri Oct 19, 2007 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm now building the Clangora module and I prepared this parts placement graphic to aid in assembly. I thought I'd post it here in case anyone needs a copy. Its been a really big help.
Its basically the two images from the original article superimposed over each other with the components clearly outlined. I have a higher res. version if anyone needs.
I'll be posting more clangora updates as I make progress. stay tuned...
peter
 Filesize:  248.57 KB
 Viewed:  715 Time(s)
goodrevdoc
PostPosted: Fri Oct 19, 2007 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
does anyone have a clean looking, 1:1 copy of the PCB art? I've got the one from here, but its not sized so well. I'm in the process right now of re-doing one, but if one already exists why not just use that...
-justin
PostPosted: Fri Oct 19, 2007 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nicely done. I love this circuit. It really can make some "way out there" sounds !! Here is a picture of my breadboard. No PCB ... Shocked
Bill
 Filesize:  556.74 KB
 Viewed:  572 Time(s)
Photon
PostPosted: Fri Oct 19, 2007 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
-justin
hey Justin
Reduce it to 64% on a photocopier and you'll be all set. I had to figure this out by trial and error. I'm weird the guy at the copier holding a 16 pin IC socket to each copy and muttering to himself.
P.
Photon
PostPosted: Fri Oct 19, 2007 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bill
*very nice job*. Those little socketed modules are very cool. I've seen those before in various prototyped things at work but never worked that way myself.
I'm psyched to get this done. I etched the panel earlier today on my lunch break. I've got the PCB mostly populated so I'll post a photo this weekend.
Peter
PostPosted: Fri Oct 19, 2007 5:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I am really interested to see the result Cool
Thanks for sharing the project. Very Happy
Bill
etaoin
PostPosted: Fri Oct 19, 2007 11:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Funny how I seem to have completely missed this thread while I have been working on PCB's in this thread: http://electro-music.com/forum/topic-19835.html.
I etched the boards straight from the GIF I had (after figuring out the right scaling). Didn't run into any problems:
 Filesize:  131.35 KB
 Viewed:  506 Time(s)
http://www.casia.org/modular/
etaoin
PostPosted: Fri Oct 19, 2007 11:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
No sound samples from mine though. I already sold it on (including, sadly, three of my four LM566's...)
Photon
PostPosted: Sat Oct 20, 2007 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice job, Etaoin.
I'm surprised you sold it. Were you disappointed with it?
Mine won't be finished as soon as I had predicted. I somehow forgot to order one of the parts. Somehow I always forget something Crying or Very sad . Must be pathological...
goodrevdoc
PostPosted: Sat Oct 20, 2007 10:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I somehow forgot to order one of the parts. Somehow I always forget something. Must be pathological...
If I always ordered all of the parts I probably would have been out of DIY years ago. Its that project lapse and stock of parts that keeps me building! Also thanks for the scaling advice. I tried that originally with not much success but will give it another go before re-laying out another board.
-justin
Photon
PostPosted: Sun Oct 21, 2007 5:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Something is either back-ordered, I forgot to order it, they neglected to send it, its the wrong part, or the capacitors are HUGE! Shocked
If you continue to have trouble, I have the pcb image at the right size. I may even have it on press n peel. Let me check tomorrow and if I have it I could mail them to you. I'll let you know.
Pete
Photon
PostPosted: Sun Oct 21, 2007 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's my Frac panel design. I'll post the actual panel soon.
Peter
 Filesize:  131.88 KB
 Viewed:  403 Time(s)
etaoin
PostPosted: Sun Oct 21, 2007 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Photon wrote:
nice job, Etaoin.
I never finished it. Needed the money for something else.
PostPosted: Sun Oct 21, 2007 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I really like your FRAC layout. Very well done Exclamation
Bill
Audio files: 232
PostPosted: Sun Oct 21, 2007 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I like it too...
Scott Stites
Audio files: 96
PostPosted: Sun Oct 21, 2007 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Perhaps a little OT, but save a spot next to your Clangora. Thomas wasn't the least bit unoccupied this summer...... Wink
My Site
Photon
PostPosted: Sun Oct 21, 2007 5:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks everyone.
The panel is etched and I'll be drilling holes and trimming it to size tomorrow. I'll try to put a photo up of the actual panel soon.
Shocked I'm almost out of real estate in my cabinet.
Thomas Henry
PostPosted: Sun Oct 21, 2007 8:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Enough of the winks. Let's start a new thread and uncork this puppy for the EM crowd.
To get the ball rolling, its name is: the Mega Percussive Synthesizer.
Modesty prevents me from mentioning it is the most versatile percussion synth ever conceived. Oops, I just did. We better let Scott take this over on another thread.
And now back to your regularly scheduled Clangora...
Thomas Henry
P.S.: no hard-to-find parts!
23isgood
PostPosted: Sun Oct 21, 2007 10:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh boy. You're killing me Thomas. Keep em coming.
pete
Check out my music
bugbrand
PostPosted: Mon Oct 22, 2007 3:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Freakin' hell! Thomas & Scott = whirlwinds!
You know you're drowning us all, right?!
(though I suspect people don't mind!)
http://www.bugbrand.co.uk
