etaoin
Joined: Jun 30, 2005 Posts: 761 Location: Utrecht, NL
softfin
Joined: Oct 11, 2006 Posts: 271 Location: Far in the north
Posted: Fri Jan 11, 2008 2:41 am Post subject:
That's an interesting project for sure!
Do you know any cheap and reliable sources where to buy those 5672 tubes? |
etaoin
Posted: Fri Jan 11, 2008 2:45 am Post subject:
I got one from Jeroen, but I don't where he got them from.
Packing date March 1958! _________________ http://www.casia.org/modular/ |
softfin
synthmonger
Posted: Fri Jan 11, 2008 10:30 am Post subject:
What type of resistors does this use? Sorry I'm a newb when it comes to tubes  |
etaoin
Posted: Fri Jan 11, 2008 10:32 am Post subject:
This is a low voltage tube so bog standard resistors. _________________ http://www.casia.org/modular/ |
Funky40
G2 patch files: 5
Posted: Fri Jan 11, 2008 4:14 pm Post subject:
| thanks alot for that links |
synthmonger
Posted: Fri Jan 11, 2008 4:29 pm Post subject:
| That filter sounds sick! I'm definately going to build this one when I get ahold of some tubes. |
zipzap
Posted: Fri Jan 11, 2008 5:06 pm Post subject:
Those samples sound perfect! Love that 12v tube stuff. I´m triying to figure out how it works. WHat about C2 and C3? should be of same value, i guess? Can someone explein what the 130n-130k at the gate of the Fet are doing? _________________ http://www.myspace.com/lorolocoacousticpop
music and transcribed jazz basslines |
zipzap
j.baars
Posted: Fri Jan 11, 2008 6:04 pm Post subject:
Hi everyone,
Its so nice you like my filter design.
if you can't get any tube's , I still have some.
I am working on a design similar to this one,but with an other tube which is more common.
so, soon there will be lots more of synth design.(tubes and semiconductor)
I opened up my 70s design books to publish.
just keep an eye on,
www.synthforum.nl
www.electricdog.eu
www.bfxweb.nl
www.bfxmusic.com
bye,
jeroen baars |
Joined: Apr 03, 2004 Posts: 24577 Location: The Netherlands, Enschede
Audio files: 308
Posted: Fri Jan 11, 2008 7:52 pm Post subject:
Jeroen.
nog geen tijd gehad om te luisteren helaas, morgen !! _________________ Jan
Audio files: 308
Posted: Sat Jan 12, 2008 1:00 pm Post subject:
| Blue Hell wrote: | | morgen !! |
that's a pretty disturbing filter - I love some of the sounds it makes  _________________ Jan
Luka
Posted: Sat Jan 12, 2008 7:52 pm Post subject:
| zipzap wrote: | | If you can´t get a 5672 i´m sure most tubes will work somehow in this circuit. raising the voltage to 30v (or +-15) might help if a tube sounds like it´s broken. |
i have a bunch of the 1j24b tubes from the cgs timbral gate module, does anyone know if they could be substituted, ? _________________ problemchild
melbourne australia
http://www.last.fm/user/prblmchild |
andrewF
Posted: Sat Jan 12, 2008 10:04 pm Post subject:
| Luka wrote: | | zipzap wrote: | | If you can´t get a 5672 i´m sure most tubes will work somehow in this circuit. raising the voltage to 30v (or +-15) might help if a tube sounds like it´s broken. |
i have a bunch of the 1j24b tubes from the cgs timbral gate module, does anyone know if they could be substituted, ? |
should be fine, maybe a few resistor changes needed.
There is a good list of sub-mini tubes here -
http://pw2.netcom.com/~wa2ise/radios/penciltubes.html
Look for pentode f: 1.25vDC, 0.05a . Any of those should work with possibly some minor tweaks (and will work in the CGS tube VCA).
Some will be better than others.
You want pentodes preferably with 1.25v heaters.
Most regular tubes need 6.3V or 12.6V on the heater at 300mA or more, there goes half of your power supply.
Usually 1.25V sub-mini tubes only need 50mA or so. Last edited by andrewF on Sat Jan 12, 2008 11:53 pm; edited 1 time in total |
Luka
andrewF
Posted: Sun Jan 13, 2008 3:26 am Post subject:
| Let us know how you go! |
Luka
zipzap
Posted: Mon Jan 14, 2008 9:30 am Post subject:
Whatever i say, these are only my observations. This is rather experiance than reall knowlege. Please correct me...
i have been experimenting with the 12sh1p. It needs 12V, but only very little current. Although it´s designed for anode voltages around 250V it works good with 30V, giving a gain of about 5-10. Whenever triyng a new tube it is of course important that the heating is correct. Another thing is that the tube won´t like beeing overpowered, but that is hardly gonna happen in designs like this. So just install the tube, make sure the heating is correct, the other connections are made depending on direct or nondirect heating, pentode, triode, etc, and start tweaking the anode and kathode resistors. In Class A designs like this one you want to set those resistors so that with 0V input the output is around half the supply voltage, otherwise headroom will be limited.
For low power, low voltage stuff 10k-100k is a good range for the anode resistor. _________________ http://www.myspace.com/lorolocoacousticpop
etaoin
Posted: Wed Jan 16, 2008 1:15 am Post subject:
I've updated my PCB design (links in the first post). Connected an unconnected ground plane, fixed a cap value and changed some hole sizes and the FET footprint.
Sound sample:
http://www.casia.org/modular/SF/tubevcf.mp3
Pic:
 _________________ http://www.casia.org/modular/ Last edited by etaoin on Wed Jan 16, 2008 3:57 am; edited 1 time in total |
etaoin
janvanvolt
Joined: Nov 24, 2005 Posts: 285 Location: Mainz, Germany
Fernando
Joined: Dec 30, 2006 Posts: 286 Location: Barcelona & Emporda, Spain
Posted: Sun Jan 20, 2008 5:32 am Post subject:
This filter sounds great, thank you!
I also have some 1J24B and 1AG5 tubes , so it would be good to know how to adapt the circuit for them.
niiice sound!
EDIT: it seems that the direct equivalent is the DL69.
Anyhow the 5672 is quite easy to find for $3-$6, plus shipping, of course (some people ask up to $20 only for the tube, sick!) Other theoretical equivalents can be found for $1-$4...
EDIT II: I know it's obvious, but I just realized this filter's crazy resonance can be VC using an external (tube?) VCA
. Last edited by Fernando on Sun Jan 20, 2008 12:54 pm; edited 1 time in total |
Fernando
Posted: Sun Jan 20, 2008 12:02 pm Post subject:
While looking for possible equivalents of the 5672 I looked at the table Andrew pointed.
I looked for heater voltage of 1.25V and 50 mA or less, down to 10mA.
I also looked for same pinout (2E31 pinout).
Then I realized that most of the tubes matching with these specs had a much smaller amplification factor than the 5672.
---> So my question is, for VCFs and VCAs, wich amplifying factor range should be apropiate?
The 5672 has 0.065 W as a reference, but many of them are in the 0.001-0.040 W range...
---> Also, what's the influence of the load (5672 = 20k, others up to 1200k)
. Last edited by Fernando on Mon Jan 28, 2008 3:04 am; edited 1 time in total |
ickystay
Posted: Wed Jan 23, 2008 5:16 pm Post subject:
Thanks for the link! Good price, good service!
So, do the heaters light up enough to put behind a window or some other show-offy thing? |
