 Forum index » Instruments and Equipment » Cwejman Sound
Cwejman Rack Released!!!
Page 1 of 1 [8 Posts]
monads
PostPosted: Fri Jan 18, 2008 8:58 pm    Post subject:  Cwejman Rack Released!!!
Subject description: finally!!!
Well, it's finally here!!! After a year and half from my orignal posting of getting some modules I finally racked all my modules that've been boxed for some time (and never used sadly). I took some pictures for you to see of my small set up Wink It's important to note the powersupply for the rack can power up to 3 racks (daisy chained)!
If you want to hear samples of specific modules (that I have) let me know. I'll try my best to give a good example. Other's have given great demos of some modules posted on this site, but I could be here forever posting examples because I've barely scratched the surface with this combo. I'm currenly learning my way around all modules since I've never used them awaiting the rack's release. Bringing the S1 into play just opens more 'routing' doors/options. I have one empty space in the rack I'm not sure what I'll fill with yet.
For those curious I'm using the Kenton Pro Solo Mk1 for my Midi to CV sources. Depending on taste I'll either use one of my keyboards as a controller or a hardware sequencer to trigger the modular.
Let me know what you think or any questions.
monads
modules and rack
 Filesize:  3.69 MB
 Viewed:  1153 Time(s)
All racked :)
 Filesize:  3.24 MB
 Viewed:  1246 Time(s)
Jari Jokinen
PostPosted: Sat Jan 19, 2008 6:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Impressive setup!
I wouldn't mind some brief examples from NS-4. Especially, what kind of smooth random output can it make.
Jari Jokinen
monads
PostPosted: Mon Jan 21, 2008 6:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Jari Jokinen wrote:
Impressive setup!
Well I recorded some samples for you tonight. They're all running through the MMF on the S1.
1st one is just noise as follows (MMF on S1 Open all the way):
S1 White, NS-4 White, S1 Red, NS-4 Red, NS-4 Pink. The 'Red' sounds different and deeper/lower in tone on the S1.
2nd sample is the S/H from the NS-4 (w/some reverb added, MMF on S1 about half way Open). This is feeding the Cutoff of the MMF. I took 2 oscillators from the S1 and used them to drive the Rate & Lag CV on the NS-4. I then adjusted the knobs on the NS-4 to taste. Only 1 oscillator (sawtooth) was going to the MMF of the S1 and that is what you hear 'changing'.
Let me know what you think. I didn't compress or eq these samples.
monads
Cwejman Noise.mp3
just noise ;)
 Filename:  Cwejman Noise.mp3
 Filesize:  715.1 KB
 Downloaded:  1495 Time(s)
SH.mp3
NS-4 S/H with some reverb added.
 Filename:  SH.mp3
 Filesize:  2.47 MB
 Downloaded:  1559 Time(s)
Jari Jokinen
PostPosted: Fri Jan 25, 2008 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you. I wonder, if NS-4 can make smooth random CV as demonstrated here:
http://www.ear-group.net/model_24.html
"Smooth Output 1 - A really boilerplate example..."
http://www.ear-group.net/smooth2.mp3
monads
PostPosted: Tue Sep 23, 2008 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm just curious, but has anyone else purchased the rack for use with their Cwejman modules?
tompty
PostPosted: Tue Sep 23, 2008 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
i am tempted to buy the rack, its beautifull!
however i think im limiting my choices for the future when i want other modules ( well just two i want currently, the malgorithm and zeroscillator ).
Cat-A-Tonic
PostPosted: Wed Sep 24, 2008 7:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome Setup!
How does the 3 Band Parametric EQ compare with the Quad Resonator?
monads
PostPosted: Fri Sep 26, 2008 10:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Cat-A-Tonic wrote:
Awesome Setup!
Thanks Cat! They have their similarties. They both have the same frequency range. With the RES-4 you do get that extra band and the Notch output. It really depends on what you want to do. You can really dial in frequencies with the VCEQ-3.
You need another module to take advantage of the FREQ, BW, LEVEL inputs on both modules. Either the D-LFO or another favorite the PH-4.
