Interested in Tau Pipe Phaser / Flanger boards ?
Page 16 of 26 [640 Posts]
Goto page: Previous 1, 2, 3, ..., 14, 15, 16, 17, 18, ..., 24, 25, 26 Next
Fernando
PostPosted: Thu Jan 31, 2008 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
yusson wrote:
I have finished the Tau-Phase Shifter module for my YUSYNTH modular. Here is a photo of the finished module.
very very nice!
eframp
PostPosted: Sat Feb 02, 2008 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there a simple way to hook a 2-wire bi-color LED up to the two LED outputs? I'm using the Bridechamber front panel which is set up for only one LED. I'd like to use the MOTM standard Lumex LED's, but I don't see a 3-wire version of their bi-color, just the 2-wire. Thoughts?
thanks
eric
jhaible
PostPosted: Sat Feb 02, 2008 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm afraid no.
But IMO it'd be enough to have a single LED to visualize the LFO sweep.
JH.
funkyfarm
PostPosted: Sun Feb 03, 2008 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
I'll experiment with an Even+ide-style Bounce circuit, adapted to the Tau, for this. If it will be sucsessfull, I'll post the circuit. I'll build this on veroboard
humm...
But isn't a Bounce effect related to time delay-based effect ?
phasers are all pass filter array ; "phase" related to time process ?
thanks,
ff
jhaible
PostPosted: Sun Feb 03, 2008 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
funkyfarm wrote:
humm...
thanks,
ff
Delay and phase are just two ways to look at the same thing.
Mathematically, group delay is the derivative, with respect of frequency, of phase: tg = dPhi / df.
In other words, if you plot the phase response vs. frequency of any filter on paper, the "steepness" of the slope represents a time delay.
Now the main difference is that for a straight delay (BBD device etc.), you get a constant tg vs. frequency (this "constant" can be modulated by variation of the delay time, of course!), and a linear phase - while on a filter in general, and analogue allpass filters in particular, phase is not linear, and thus tg depends on frequency.
So you get a different sound. Different number of notches in a phaser and flanger. Different spacing of notches, too. If you're using a BBD for chorus or vibrato, all signal frequencies will be modulated equally. If you're using an all pass filters, some signal frequencies will be modulated more than others.
But for very long all pass filters, the method becomes similar to a straight delay in some respects. That's why the Tau is often refered to as a "Flanger", even though it's not 100% compatible with what I learned as the word's meaning.
JH.
funkyfarm
PostPosted: Mon Feb 11, 2008 2:34 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you very much.
(i'm so excited Cool )
Al least, I finally decided to leave off the two outputs potentiometers as I don't really understand their usefulness.
two sources, one output, you need a pot for varying blend (as for a Dry/Wet pot)
but, with two sources (main, aux), two outputs, mixing and panning would be made in the main mixing desk...
Peake
PostPosted: Mon Feb 11, 2008 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
As you found earlier, Juergen, the Pipe's ability to bend pitch makes for a nice chorusy sound. Multiple all-pass filters are fun Smile
jhaible
PostPosted: Fri Feb 22, 2008 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Apparently my 20-pole "Tau" phaser project http://www.jhaible.heim.at/tau/jh_tau.html has created more demand than I had expected.
The PCBs were sold out soon, and I've started to keep a waiting list, to see if another manufacturing run would be justified at some point.
I have now reached this point, not least due to a big order of Tau PCBs from Scott Deyo of Bridechamber. Smile
If you want to have one or more Tau boards as well, please let me know as soon as possible.
Pricing is "as usual": EUR 27.00 per board, plus EUR 4.00 shipping flatrate.
(Ask for a discount if you want 5 boards or more, and expect higher shipping
costs if you want them sent by registered mail.)
You probably know about my infamous order forms by now. Smile
I really need the orders in that form, because of my clumsy means of
book-keeping.
Dont forget to use the required email subject line (that's the text that is
visible without opening the email. Smile )
Please send an email in this form, if interested:
(my email adress can be found at the bottom of my homepage, http://home.debitel.net/user/jhaible/hj.html . No Forum PMs, please.)
Subject Line of your email:
"Tau Reissue Order [n] PCBs" (where [n] is the number of boards you want to order)
Email Text:
"I'm ordering [n] Tau Reissue boards (fill in number of boards again)
for EUR 27.00 each
plus EUR 4.00 shipping flat rate
I know that I'm only buying a printed circuit board, not kit, and have no
guarantee to build a working Phaser from this. As a buyer, I'm responsible for all aspects of safety for the device I'm building with this PCB; no such responsibility may be assigned to the seller and designer of the PCB. The descriptions how to build a Phaser, given by the silkscreening on the PCB, on the internet and elsewhere, are just to be considered helpful hints, and do imply any responsibility of the seller / designer for damage and danger that may arise from what the buyer is building with the PCB.
By ordering one or more PCBs, I expressly agree to these terms.
[Your Name]
[Your shipping adress as it will appear on the shipping envelope,
including ZIP code and Country]
My paypal adress is
[fill in yout paypal adress]
Looking forward to hear from you!
JH.
PS.:
As my waiting list contains a pottpurri of actual pre-orders and just signs
of showing interest, I'm sending this mail out to all on the waiting list directly, too. Regardless of what you've mailed me before, please send the
order described above, if you're still interested.
Peake
PostPosted: Wed Feb 27, 2008 10:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi, I was wondering... The strength of the design is the large number of allpass filters...I wonder what it would sound like if you tapped the output of half the total number. Just musing aloud. Thanks again for the project; I'm glad that so many are finding one of my favorites to be as useful and unique as I've found it to be.
germaniac
PostPosted: Thu Feb 28, 2008 12:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Peake!
I haven't even built my Tau yet due to other projects, but since you're musing aloud, I've always got time for that. Very Happy
Tapping off different phaser stages intrigues me too, and here's and experiment I've been planning: a stereo configuration tapping odd stages for the left output and even stages for the right output. I'm figuring they could just be passively mixed. I've bounced this idea around with Scott Stites a while back, and IIRC, he tried it with his 32-stage Multi-Phaser with good-sounding results. Anyway, just thought I'd add some more food for thought. . . .
Regards,
Joe
Scott Stites
Audio files: 96
PostPosted: Mon Mar 03, 2008 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Note: At this point, the Tau Pipe Phaser/Flanger thread spawned a topic so intriguing that it deserves its own thread (The Dimension T thread). The subject has been split off to here:
http://www.electro-music.com/forum/topic-24529.html
My Site
v8pete
PostPosted: Mon Mar 03, 2008 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
On the topic of SMD parts, this is how I see it:
As long as you select the SMD parts at a sensible size (ie. 0805 resistors, regular eg. S08 ICs with a pin spacing of 1.27 mm, the occasional 0603 part) & you have a half-decent soldering iron & some good tweezers the whole process is really no more difficult than building a regular board. We might as well face up to it sooner or later !!
Where I get frustrated is when some of the nice modern parts, eg matched pair transistors, are only available in stupid small, 0.5mm pin spaced outlines! Now although these can be done by hand, you'll soon get a headache!!
So guys, don't be afraid, it really isn't half as bad as you might think! Make sure that you have some proper solder with lead in it too, none of this lead free stuff (OK its a very good idea to make all the disposable white goods with this stuff - but yet another pain for the home constructor).
Pete.
funkyfarm
PostPosted: Mon Mar 17, 2008 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
can anyone easily add another cv linear input ?
adding an 2k7 resistor between R56 and R55 ? or at U5A -IN (pin 2) ?
BTW, the SMOOTH function (which only consists of a cap tied to ground ?) is great.
 Filesize:  51.45 KB
 Viewed:  239 Time(s)
jhaible
PostPosted: Mon Mar 17, 2008 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
funkyfarm wrote:
This CV path, while linear in terms of delay time, is 1/x-law in terms of pole frequency and ladder current.
That means, the range must be set precisely in order to get a cool effect: You have that 22Meg resistor for one end of the range (R51), and only 5.4k (2.7k * 2) for the other end.
Simply adding another 2k7 resistor may reduce the range because of mutual loading of the different CV paths.
So in order to combine more CV paths here, you'd have to buffer the input (left side of R56) and do the summing befor that point, and you'd have to make sure that you stay in the "good" range. (Whatever this means ... well, try it, experiment ...)
JH.
funkyfarm
PostPosted: Mon Mar 17, 2008 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Coool !
And don't get furious...but this was just a question ! Very Happy
jhaible
PostPosted: Mon Mar 17, 2008 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Far from it!
JH.
eframp
PostPosted: Tue Mar 18, 2008 9:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just finished my Tau Pipe with a Bridechamber front panel. I decided to leave off the output trims. It looks like this:
jhaible
PostPosted: Mon Mar 31, 2008 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tau Re-issue boards arrived some days ago - prototype from this run built and tested.
I'll be sending invoices this week - don't send money befoire you get an invoice.
First shipment will go to Bridechamber, who helped to make the new run possible.
JH.
Cat-A-Tonic
PostPosted: Mon Mar 31, 2008 4:15 pm    Post subject: Tau PCB Reply with quote  Mark this post and the followings unread
I would like a Tau PCB please.
jhaible
PostPosted: Mon Mar 31, 2008 4:22 pm    Post subject: Re: Tau PCB Reply with quote  Mark this post and the followings unread
I would like an order mail then, please. Smile
book-keeping.
want to order)
Email Text:
for EUR 27.00 each
guarantee to
aspects of safety
assigned to
just to
designer
the PCB.
[Your Name]
My paypal adress is
JH.
Luka
PostPosted: Thu Apr 03, 2008 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Juergen is there many pcbs left?
I would love one but cant do much for another month or so
Will it be safe to wait another month or should i do something like sell my parents Wink
problemchild
melbourne australia
jhaible
PostPosted: Thu Apr 03, 2008 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Plenty left.
I didn't want to risk to go thru a 3rd run. Smile
JH.
jhaible
PostPosted: Fri Apr 04, 2008 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Everyone who has pre-ordered boards from my re-run of 20-Stage "Tau" Phaser
boards should have received an invoice by now.
I've shipped them today to all who have paid already.
Next batch will not go out before 12. April, because I'm on a business trip
next week.
JH.
Stavros
PostPosted: Wed Apr 16, 2008 8:06 am    Post subject: Tau Pipe Phaser re-run PCBs Reply with quote  Mark this post and the followings unread
Hi Jurgen, I just got my Tau Pipe Phaser(re-run) PCBs. Thank you.
A couple of issues I need your help.
1. I have seen in the “Deluxe Version” of the “Tau” connections that on the output there is provision for a 10μF non polarized Electrolytic and a 100k resistor that do not exist on the “Basic Version”.
I have read the relative messages and have understood the issue.
Is this also applicable to the Solina-Triple Chorus output connections?
2. I have problem in finding a Tempco resistor. I have looked at Reichelt/Banzai/Das Musikding, but have not seen any code for Tempco resistors. I may have missed it. I will appreciate some supplier suggestion and/or an order code number for a 1k one.
Many thanks and Best Regards
Stavros
softfin
PostPosted: Wed Apr 16, 2008 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Got my boards today. Thanks again JH!
