chresan
Joined: Jul 11, 2006 Posts: 150 Location: Karlsruhe, Germany
Posted: Mon Mar 10, 2008 12:50 pm Post subject:
Nomad 0.3 pre-release available for DL |
| Code: | Nomad 0.3 pre-release announcement
Hi everyone,
the second release of Nomad - Nord Modular Editor is finally out.
After 1.5 years of developing since the first release we are happy
to announce that Nomad is almost feature complete.
Apart from the basic things we implemented some new features to
improve the experience with the editor:
- embedded file browser
- macros: create tiny template patches which can be inserted into other patches
- module transformation: transform a module into another without loosing parameter values and connections
- randomizer: randomize the parameters of a patch or a set of modules
- arbitrary number of Nord Modular/Micro Modular synthesizers supported
Requirements:
- Java Runtime Environment (JRE) 5.0
- platform: platform independent
OS X users might need to install a MIDI service provider (SPI). See
http://nmedit.sourceforge.net/userpage/help.html#osx-midi
Starting Nomad:
OS X:
start the nomad application file like any other application
other platforms:
start nomad.jar like any other application
or manually using the command
java -jar nomad.jar
Downloads are available at
For support, questions, bug reports or anything else visit our forum at
http://electro-music.com/forum/forum-138.html
_________________ ----------------------
http://nmedit.sf.net |
chresan
JLS
G2 patch files: 316
chresan
Posted: Mon Mar 10, 2008 1:43 pm Post subject:
| JLS wrote: | Nice Job, but not working with my MicroModular.
Is normaly or not ?
Very thanks info about this.
Kamil |
No, the MicroModular should work quite fine. Which OS / Midi interface do you use ? Under OS x you have to install a midi service provider, see http://nmedit.sourceforge.net/userpage/help.html#osx-midi _________________ ----------------------
JLS
G2 patch files: 316
Posted: Mon Mar 10, 2008 1:49 pm Post subject:
I using WinXP on PC platform - when set midi in/out generate this error report.
Kamil
net.sf.nmedit.jsynth.SynthException: Invalid plug MidiPlug[name=In-A USB MidiSport 2x2,vendor=Unknown vendor,description=No details available] for net.sf.nmedit.jsynth.midi.MidiPort[name='pc-out',type=TRANSMITTER,plug=MidiPlug[name=null,vendor=null,description=null]].
at net.sf.nmedit.jsynth.midi.MidiPort.setPlug(MidiPort.java:110)
at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog.applyPortSettings(SynthPropertiesDialog.java:248)
at net.sf.nmedit.jsynth.nomad.forms.SynthPropertiesDialog$PortSettingsDialog$MyAction.run(SynthPropertiesDialog.java:223)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at java.awt.Component.show(Unknown Source)
at java.awt.Component.setVisible(Unknown Source)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.showSettings(SynthObjectForm.java:1257)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$2.actionPerformed(SynthObjectForm.java:609)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source) _________________ https://www.youtube.com/@kamilondrousek6973
https://soundcloud.com/1jls
https://soundcloud.com/user-819966312-266044932
https://github.com/jlswbs
https://www.instagram.com/ondrousek.kamil/ |
wesen
Posted: Mon Mar 10, 2008 1:56 pm Post subject:
Hey,
I'm sorry to hear about the problem you encounter, we haven't done much testing under windows, except with my usb adapter baord, and it worked alright. I'll try it with windows and my midisport 4x4 and let you know when it's fixed.
Cheers, Manuel |
chresan
Posted: Mon Mar 10, 2008 2:05 pm Post subject:
Kamil, we know that Java + MidiSport has caused problems on the linux platform. Perhaps the solution works for you too: Connect your nordmodular with the A-In/Out ports and see if this helps.
The exception you encounter is caused because Nomad could not find or open the midi device. Perhaps it is currently in use by another application. Also it is possible that your midi cables are connected wrong (MIDI-IN <-> MidiSport In and MIDI-OUT<->MidiSport Out) _________________ ----------------------
JLS
G2 patch files: 316
chresan
Posted: Mon Mar 10, 2008 2:27 pm Post subject:
| JLS wrote: | I tested in both my usb converter and same error.
MidiMan MidiSpot2x2
Motu midiExpress 128
In Clavia editor both converters working fine.
My next test download new Java and reinstaling. |
There is another post with the same error. I looked through our source code and now I am 99% sure that this is a Java-JRE bug - I still have to confirm this though. Would you be so kind to post the logfile.txt which you can find in the nomad directory. _________________ ----------------------
JLS
G2 patch files: 316
Posted: Mon Mar 10, 2008 2:34 pm Post subject:
INFO : logging system initialized
INFO : application root is C:\00\nomad-0-3-pre
INFO : got SAX parser factory - com.sun.org.apache.xerces.internal.jaxp.SAXParserFactoryImpl@1f20eeb
INFO : configured, stopOnError=false, isValidating=true
INFO : plug-in and fragment descriptors registered - 15
INFO : integrity check done: errors - 0, warnings - 0
INFO : application plug-in is net.sf.nmedit.nomad.core
INFO : plug-in started - net.sf.nmedit.nmutils@0.1.0 (active/total: 1 of 15)
INFO : plug-in started - com.jgoodies.looks@2.1.4 (active/total: 2 of 15)
INFO : plug-in started - com.jgoodies.forms@1.1.0 (active/total: 3 of 15)
INFO : plug-in started - org.apache.xerces@2.9.0 (active/total: 4 of 15)
INFO : plug-in started - net.sf.nmedit.nomad.core@0.2.2 (active/total: 5 of 15)
INFO : plug-in started - org.w3.sac@1.3.0 (active/total: 6 of 15)
INFO : plug-in started - org.apache.xmlgraphics.batik@1.6.0 (active/total: 7 of 15)
INFO : plug-in started - org.mozilla.rhino@0.0.0.1_6R5 (active/total: 8 of 15)
INFO : plug-in started - net.sf.nmedit.jpatch@0.1.0 (active/total: 9 of 15)
INFO : plug-in started - org.jdom@1.0.0.xcvs (active/total: 10 of 15)
INFO : plug-in started - net.sf.cssparser@0.9.4 (active/total: 11 of 15)
INFO : plug-in started - net.sf.nmedit.jtheme@0.1.0 (active/total: 12 of 15)
INFO : plug-in started - net.sf.nmedit.jpdl2@2.0.0 (active/total: 13 of 15)
INFO : plug-in started - net.sf.nmedit.jsynth@0.1.0 (active/total: 14 of 15)
INFO : plug-in started - net.sf.nmedit.nordmodular@0.1.0 (active/total: 15 of 15)
INFO : Activating services...
INFO : Connected extensions: 7
INFO : Service implementation / Service: net.sf.nmedit.jsynth.nomad.Installer (description=JSynth installer) / net.sf.nmedit.nomad.core.service.initService.InitService
INFO : Service implementation / Service: net.sf.nmedit.nordmodular.Installer (description=Nord Modular plugin installer) / net.sf.nmedit.nomad.core.service.initService.InitService
INFO : Service implementation / Service: net.sf.nmedit.nomad.core.service.initService.ExplorerLocationMemory (description=remembers explorer locations) / net.sf.nmedit.nomad.core.service.initService.InitService
INFO : Service implementation / Service: net.sf.nmedit.nordmodular.NmFileService (description=Nord Modular patch 3.0) / net.sf.nmedit.nomad.core.service.fileService.FileService
INFO : Service implementation / Service: net.sf.nmedit.nordmodular.NewNordModularService (description=Nord Modular factory) / net.sf.nmedit.nomad.core.service.synthService.NewSynthService
INFO : Service implementation / Service: net.sf.nmedit.jtheme.InstallerService (description=Module Pane Installer) / net.sf.nmedit.nomad.core.service.initService.InitService
INFO : Service implementation / Service: net.sf.nmedit.jpatch.nomad.InstallerService (description=JPatch Installer) / net.sf.nmedit.nomad.core.service.initService.InitService
INFO : Setting UIDefaults ClassLoader in net.sf.nmedit.jtheme.clavia.nordmodular.JTNM1Context@163de4e: {PluginClassLoader: uid=11124894; {PluginDescriptor: uid=net.sf.nmedit.nordmodular@0.1.0}} (class org.java.plugin.standard.StandardPluginClassLoader)
INFO : Shutting down {net.sf.nmedit.nomad.core.NomadPlugin: manager=org.java.plugin.standard.StandardPluginManager@13caecd, descriptor={PluginDescriptor: uid=net.sf.nmedit.nomad.core@0.2.2}}
INFO : plug-in stopped - net.sf.nmedit.nordmodular@0.1.0 (active/total: 14 of 15)
INFO : plug-in stopped - net.sf.nmedit.jsynth@0.1.0 (active/total: 13 of 15)
INFO : plug-in stopped - net.sf.nmedit.jpdl2@2.0.0 (active/total: 12 of 15)
INFO : plug-in stopped - net.sf.nmedit.jtheme@0.1.0 (active/total: 11 of 15)
INFO : plug-in stopped - net.sf.cssparser@0.9.4 (active/total: 10 of 15)
INFO : plug-in stopped - org.jdom@1.0.0.xcvs (active/total: 9 of 15)
INFO : plug-in stopped - net.sf.nmedit.jpatch@0.1.0 (active/total: 8 of 15)
INFO : plug-in stopped - org.mozilla.rhino@0.0.0.1_6R5 (active/total: 7 of 15)
INFO : plug-in stopped - org.apache.xmlgraphics.batik@1.6.0 (active/total: 6 of 15)
INFO : plug-in stopped - org.w3.sac@1.3.0 (active/total: 5 of 15)
INFO : plug-in stopped - net.sf.nmedit.nomad.core@0.2.2 (active/total: 4 of 15)
INFO : plug-in stopped - org.apache.xerces@2.9.0 (active/total: 3 of 15)
INFO : plug-in stopped - com.jgoodies.forms@1.1.0 (active/total: 2 of 15)
INFO : plug-in stopped - com.jgoodies.looks@2.1.4 (active/total: 1 of 15)
INFO : plug-in stopped - net.sf.nmedit.nmutils@0.1.0 (active/total: 0 of 15)
INFO : shutdown done
INFO : logging system finalized
INFO : ---------------------------------
WARN : unknown listener org.java.plugin.standard.StandardPluginManager$1@1128ee5
INFO : shutdown done _________________ https://www.youtube.com/@kamilondrousek6973
Posted: Mon Mar 10, 2008 2:43 pm Post subject:
First of all:
for this amazing piece of work that you have created. Judging by the screencasts this is a slick product indeed, surpassing the G2 in parts.
I got it working on my OSX 10.4.11 after a little hassle. I already had mmj installed (I've fiddled a bit with MIDI from Java earlier), but that didn't seem to agree with Nomad, so I had to remove the existing extension and install your bundled stuff instead. Then i got an error message but after a couple of trys I got it connected to my NM Key. Woohoo!
The only remaining issue now is that I don't see any modules in the left-hand pane. I can right-click on the grey background and add modules that way. I tried clickin more and the + - icons. I'm going to fiddle a bit more with this tomorrow - can't wait to try out those macros!
Great work!
gomidas
Joined: Jul 09, 2004 Posts: 365 Location: La Ciotat, France
G2 patch files: 6
Posted: Mon Mar 10, 2008 3:31 pm Post subject:
Re: Nomad 0.3 pre-release available for DL |
| chresan wrote: |
INCREDIBLE!!!AMAZING WORK!!!!
AND ABOUT MACROS...I WAS ABOUT TO CRY...WE SHOULD HAVE THIS FEATURE FOR THE G2 A LONG TIME AGO!!!! FOR MY NORD MODULAR, IT IS A SECOND LIFE!!!
BIG THANKS TO THE TEAM  |
chresan
Posted: Mon Mar 10, 2008 5:31 pm Post subject:
| Antimon wrote: | ...
The only remaining issue now is that I don't see any modules in the left-hand pane. |
Hi Stephan,
thanks for pointing this out. This happens when making code changes 5minutes before releasing
We fixed the problem and updated the release. Just download Nomad again and you will find all modules where they should be.
Christian _________________ ----------------------
m:o
Posted: Mon Mar 10, 2008 6:01 pm Post subject:
| Great release guys but besides that Nomad won't recognize my Midi Interface, how do i delete patched cables ? |
chresan
Posted: Mon Mar 10, 2008 6:13 pm Post subject:
m wrote: | | Great release guys but besides that Nomad won't recognize my Midi Interface, how do i delete patched cables ? |
Either right click on the connector and then select "Disconnect" in the menu or double click a connector and drag'n'drop the cable into the nirvana The cables themself are not clickable. _________________ ----------------------
m:o
Posted: Mon Mar 10, 2008 6:24 pm Post subject:
| chresan wrote: | m wrote: | | Great release guys but besides that Nomad won't recognize my Midi Interface, how do i delete patched cables ? |
Either right click on the connector and then select "Disconnect" in the menu or double click a connector and drag'n'drop the cable into the nirvana The cables themself are not clickable. |
it's not working (both ways). no contextmenu on right-click. also when i right-click on the backgroung of the editor (i think you can access module menus this way) nothing happens. |
hinotori
Posted: Mon Mar 10, 2008 9:55 pm Post subject:
after some messing about with plumstone (no luck) and your midi bits (also no luck) i installed mmj and it works. . . AMAZING WORK !
(btw..im using an ibook g4 to connect to an NM1 keyboard using a midisport 2x2 .)
many many thanks for all the time youve put into this . the additions will really speed up the creative workflow . . . great stuff . .. now back to the joys of patching  |
EIII
Posted: Tue Mar 11, 2008 2:04 am Post subject:
lucky ? unlucky ! |
Firt of all , huge thanks for the hard works.
i'm on Xp , using a midisport 2*2 as a midi interface for the Nm1.
got the same error :
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.Dialog$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Window.setVisible(Unknown Source)
at java.awt.Dialog.setVisible(Unknown Source)
I hope you will find a way ! i'm dying to start on working with the new release
Cheers :! |
Posted: Tue Mar 11, 2008 4:44 am Post subject:
| chresan wrote: | | Antimon wrote: | ...
Hi Stephan,
thanks for pointing this out. This happens when making code changes 5minutes before releasing |
No problem, you fixed it quickly enough. I am eager to get home from work to try out Nomad some more.
frabo
Posted: Tue Mar 11, 2008 6:40 am Post subject:
seems to be a very good work !
But I did not get a wire to my NM-Keyb.
I get always a Midi Timeout error!
I'm on 0sx 10.4.11 and I tryed it with some devices:
- RME Fireface
- Novation remote SL
- evolution EV-10 (single midi-interface)
and I tryed with osxmidispi.jar and with mmj.jar
her is the error log:
net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:411)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.setConnected(NordModular.java:881)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.trySetConnectedState(SynthObjectForm.java:958)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$1$1.run(SynthObjectForm.java:599)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jnmprotocol2.NmMessageAcceptor.waitForReply(NmMessageAcceptor.java:111)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:400)
... 10 more
thank you for any help
nathan
Posted: Tue Mar 11, 2008 7:59 am Post subject:
hey !
same as mine i think.
check the other topic.
not that i figured it out yet. ( well, manuel is trying to)  |
frabo
Posted: Tue Mar 11, 2008 8:13 am Post subject:
Hey,
I got it ! Yess !
I changed the midi clock to "EXT" in the NM-Keyb. !
It seems to get in trouble when the NM send all the time the Clock sysex
wesen
Posted: Tue Mar 11, 2008 8:20 am Post subject:
Ah good, that may be a reason why it gets into trouble. I'll check this  |
nathan
Posted: Tue Mar 11, 2008 8:47 am Post subject:
haha!!!
yes! thats it!
all working here now!
thanks a lot guys!
and Wesen>>> thanks for your time and offcourse all the developmenttime yuo put into this editor! |
wesen
Posted: Tue Mar 11, 2008 9:08 am Post subject:
You're welcome. You really have to thank christian for this, I must admit my goal was a little bit selfish, as I really wanted to edit nord patches in a comfy way. So I pushed christian to finish all the stuff and added some UI ameliorations for comfyness. And macros definitely rule  |
