copy morphe groups
Page 1 of 1 [7 Posts]
bdhm
PostPosted: Thu Mar 13, 2008 5:21 am    Post subject: copy morphe groups Reply with quote  Mark this post and the followings unread
hi'
I am not often writing on this forum.
one question:
how can I copy quickly the 8x morph-groups to the other 7x variations?
thanks for any tip!
ps. the "new" NORD reminds me of a POLY-800. real 80th style!
"wuah"
bd
Audio files: 299
PostPosted: Thu Mar 13, 2008 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe the following procedure will work for you.
Select the modules that have morphs on them, then press CTRL+C to copy them, then change variation and press CTRL+E (or paste parameters from the menu) to paste just the settings and not the modules (do not change the module selection in between, the module selection has to be the same for the copy and the paste otherwise it will not work).
This will also copy the non morph settings for those modules, but at least the other non morph related modules will not be changed.
bdhm
PostPosted: Thu Mar 13, 2008 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
hi,
thanks a lot for your help'''''
the "E" is the trick!
hope in the update will be a handy way to do this.
best wishes,
bd
bdhm
PostPosted: Thu Mar 13, 2008 10:02 am    Post subject: B- version ? Reply with quote  Mark this post and the followings unread
hi Blue Hell
now I have tried to copy the morph groups by this:
but it is not working.
is this a bug?
"COPY A MORPH GROUP FROM ONE SOURCE TO ANOTHER
The special Copy/Paste function can be used to copy an entire Morph Group with all its assigned
parameters from one Morph source to another. To copy and paste a Morph Group, do like this:
First, press the MORPH button. Then, press and hold the FOCUS/COPY button and while holding it,
press a MORPH GROUP button. Release all buttons. Press and hold SHIFT+FOCUS/COPY (Paste) and
while holding them, press the new destination MORPH GROUP button. You can copy MORPHS to
another VARIATION by first selecting that VARIATION before pasting."
best wishes
bd
Audio files: 299
PostPosted: Thu Mar 13, 2008 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh I didn't even know it existed Shocked
Edit : ah right that's in the synth itself, I have engines Very Happy
bdhm
PostPosted: Thu Mar 13, 2008 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
[-_-]
and is it working ?
for me not .. no idea what I am doing wrong [*I*]?
bd
bdhm
PostPosted: Thu Mar 13, 2008 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I see.
could anyone with a synth try this <?
thanks!!
bd
