NEEDED - Trigger to MIDI - Circuit Schematics or Module
Page 1 of 1 [3 Posts]
Alexandra
PostPosted: Tue Apr 29, 2008 9:57 am    Post subject: NEEDED - Trigger to MIDI - Circuit Schematics or Module
Subject description: Trigger to MIDI Interface - Circuit Schematics or Module for MIDI Marimba that I am building
Trigger to MIDI Interface - Circuit Schematics or Module for MIDI Marimba that I am building.
what ever I build or buy needs to handle 5 octaves or 64 notes capacity.
I suppose midi notes #33 t0 #99.
I am looking for a device or circuit that can interface between a MIDI Marimba, that I am building with touch and velocity sensitive Triggers, and a sound modual.
PLEASE: No drum triggers. I need something polyphonic, velocity and pressure sensitive, and has a wide note range of 64 note minimum span.
I am willing to build the circuit board from scratch if need be but prefer one already built.
Alexandra
Pittsburgh, Pa.
electromusic@catjammies.com
cappy2112
PostPosted: Tue Apr 29, 2008 10:59 am    Post subject: Re: NEEDED - Trigger to MIDI - Circuit Schematics or Module
http://www.zzounds.com/item--ROLTMC6
http://homepage.mac.com/davedbw/midiDBW.html
http://timara.con.oberlin.edu/~jtalbert/MTrig/mtrig.htm
The Akai S900 sampler has a trigger to midi converter built in, but that's somewhat expensive, very bulky and may be hard to find. It was a very popular sampler in the 80's though.
Alexandra
PostPosted: Tue Apr 29, 2008 1:52 pm    Post subject: NEEDED - Trigger to MIDI - Circuit Schematics or Module Reply with quote  Mark this post and the followings unread
Thanks Cappy, Good suggestions. you were on the right track.
The website http://timara.con.oberlin.edu/~jtalbert/MTrig/mtrig.htm was more like what I am seeking.
what ever I build or buy needs to handle 5 octaves or 64 note capacity.
I suppose midi notes #33 to #99.
Alexandra
Pittsburgh, Pa.
